Question about Wurlitzer Jukebox CD Player
I have a Wurlitzer Juke Box (One More Time, 1015, Vinyl) & need to replace one of the florescent bulbs in the turning, side cylinder. Someone said to turn the color cylinder a quarter turn & it easily comes out, but I'm not having any luck. Anyone have pictures showing how to do this?
    Champion:
  • Wurlitzer Expert
  • 211 Answers
The actual light tube slides sideways into the socket and then is rotated 90 degrees so it clicks (quarter turn). It is physically impossible so wurlitzer added a black plastic cap at the top and bottom of the tube with a bit sticking out that you can use to turn the tube. So look at the very top and bottom of the actual light tube and try turning the black part.
Posted on Aug 11, 2010
How do I replace the column GE tubes on a 1015 Wurlitzer?
HI,
Here i have added picture of Wurlitzer 1015 rear side picture. from this picture you can identify which side you have to remove to see the tubes. In th picture you can see the tubes. two out put tubes. one rectifier and two pre amp tubes(black).
Wurlitzer 1015
Jul 24, 2012 | Wurlitzer Jukebox 1015 One More Time...
How do I replace the light bulb in my 45 wurlitzer juke box in the round spinning tubes?
It depends how old it is. On the newer type there are two black tags on the ends of the light tube to help you turn it. It twists 90 degrees then pulls out backwards from the sockets along with the colour tube around it.
On the older type you need to remove a screw or two at the top plate, lean it backwards and lift up and out.
Dec 24, 2010 | Wurlitzer Jukebox 1015 One More Time...
Need parts....song list on front of juke box ....24 shown with no numbers .....plays on slot 00
The 24 songs shown are for decoration only....The original 1015 made in 1946-47 held only 24 records, so these "fake" title strips are placed there on the "One More Time" to retain the original look. If you have any other questions or need repair, my name is Rod and I can be reached at tech@wurlitzer-ohio.com.
Jun 29, 2010 | Wurlitzer Jukebox 1015 One More Time...
I have a wurlitzer super star juke box. the
I think I can clear things up for you. The free play switch you're referring to is just to add credits. If you want continuous free play, I sell you a jumper plug to bypass the credit unit, commonally called BOAC, if you have a 3600 series Super Star. Please email tech@wurlitzer-ohio.com.
Mar 11, 2010 | Wurlitzer Jukebox 1015 One More Time...
I broke one of the glass bubble tubes. How can I get an replacment tube for my 1015 One More Time Black Onyx juke bos
I have bubble tubes in stock. You just need to tell me which one you need. I can tell you the replacement procedure also. Please email tech@wurlitzer-ohio.com.
Feb 04, 2010 | Wurlitzer Jukebox 1015 One More Time...
How can I take out the side florescent bulbs encased in plastic?
Usually the plastic tube has two end caps that hold the plastic tube onto the lamp. These end caps allow the connection pins to go through a slot in the end of the cap.
If the lighting fitting is the turn type then turn the complete tube and over tube by the end caps and remove the tube/over tube. If it is in a lighting fitting where you just push the connection back and pull the pins out of the fitting.
The end caps will have a ridge that the plastic tube fitts into at each end.
I have seen some overtubes have screw on end caps.
Regards
Alan Hood
ami-man
UK
Aug 10, 2009 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 CD 50 disk - florescent bulbs change
You have to rotate the tube 90 degrees until you hear a click, then it pulls straight out of the sockets at the top and bottom (towards you). In order to grip the tube Wurlitzer put a black plastic cap on the end of the tubes with a bit sticking out for you to get hold of. On models where the colour cylinder is flexable you can actually squeeze it in the middle and grab the tube that way.
Dave.
Nov 02, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer arm keeps running
check the white plastic actuator next to the gear box, it is probably broken and not actuating the microswitch underneath it, these often fail, it may look ok,, but it actually is loose and the set screw on top of it is not clamping it to the rod.
Aug 18, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer Juke Box One More Time Elvis Presley Edition
Check the fuses in the small pcb in the middle of the front door. If they are ok. it's the amp end of things.
Jun 20, 2008 | Wurlitzer Jukebox 1015 One More Time...
Wurlitzer 1015 OMT Disc spins, then stops....
When the disc is taken from the carousel and put on the player how long does it take for it from the time it is placed onto the player to being returned to the carousel? Also is the cd spinning when its on the player or not spinning at all. The answers to these questions should help in pinpointing the actual problem.
Mar 16, 2008 | Wurlitzer Jukebox 1015 One More Time...
Open Questions:
See all Wurlitzer Jukebox CD Player Questions
Wurlitzer Jukebox CD Player Logo
275 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
John Robertson
John Robertson
Level 1 Expert
jasbo
jasbo
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
