Question about Canon iR 1600 Laser Photo Printer
DEAR I AM FACING PROBLEM IN IR2000 ROM ERROR SO I NEED FIRMWARE FOR THIS MODEL OR GIVE ME A SOLUTION. THANKS
When the ROM Error message is displayed on the control panel, this will indicate an issue with the Flash DIMM on the Image Processor PCB.
re-flash the system software/or replace the DIMM Assembly.
When replacing the DIMM, you may be required to flash the system software to it's latest version.
iR 1600/2000 FG6-9978-000, Dimm assembly.
As a temporary work around, power on the iR while holding down the STOP key. This may boot the iR to a ready state and copies can be made.
Service Mode=Additional Functions #
Posted on Feb 19, 2011
Can any one help m please, I have a Konica minolta bizhub C450 and i have a malfunction code C152, can any one tell me how to fix it please as soon as possibl thanks to all
i found this after a brief search
Straight from the service manual....just use the last 4 digits when doing a search, makes it easier to find the specific code as not all manuals are the same in how the code is displayed.
CC152 ROM contents error upon startup (Scanner)
• A fault is detected in a sequence of ROM contents check of the PWB-C during starting.
16.5.79 CC151: ROM contents error upon startup (MSC)
16.5.80 CC152: ROM contents error upon startup (Scanner)
16.5.81 CC153: ROM contents error upon startup (PRT)
16.5.82 CC154: ROM contents error upon startup (PH)
1 Check the ROM version. - -
2 Rewrite the firmware. - -
3 Replace the appropriate board.
TSB entry
Description
C-C152 at power up, the counters display as 0 and the operation panel display is in Japanese.
Solution
CAUSE: Main body firmware is corrupt.
SOLUTION: Flash or re-flash the firmware to the latest level.
As for the 2152 code,
16.5.6 C2152: Transfer belt pressure welding alienation
Dec 04, 2014 | Konica Minolta bizhub Office Equipment &...
I downloaded fifa 2011 and i launched the game and then it stopped loading and sayd rom loading failed load rom error=-4 please reset system, how shuold i fix it
This is a non patched version. It has something to do with Antipiracy..
Solution 1: Update your r4 or card to the latest firmware
Solution 2: You will need a patched version of FIFA 2011 (not available yet)
Please give some more info about your card.
Example: Firmware Version, Card
May 24, 2011 | Nintendo DS Console
Brother DCP-165C gives error print unable 46
The error message "Print Unable 46" is an indication that the machines ink absorbers are almost full. The ink absorbers hold liquid and dried ink after it has been purged from the print head. These absorbers can control enough ink for the expected life of the machine.
There is a possibility that this message may have occurred in error. Upgrading the firmware of the Brother machine may resolve the issue. Follow the procedure below to determine if a firmware update is required:
-if the display screen is displaying an error message, press the STOP/EXIT key to change the LCD to the main screen.
-press the # and * key at the same time. The first 2 characters on the top row will determine the ROM version.
If the ROM version is OE or greater (example: OF, OG, OH, etc), the firmware does NOT need to be upgraded. If the ROM version is OA, OB, OC or OD, follow the procedure on this link to upgrade the firmware.
If the message "Print Unable 46" continues to appear on the display the Brother machine after completing the firmware upgrade and your machine is within warranty (even if it's not under warranty you have to do the same thing), you have to take it to a Brother Authorized Service Center. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000059/faq002659_000.html?reg=us&c=us&lang=en&prod=mfc290c_all&Cat=11
Jan 17, 2011 | Brother DCP 165C Compact Color Inkjet...
I am facing the problem of clean unable 46 and clean unable Af please give me solution
The error message "Clean Unable 46" is an indication that the machines ink absorbers are full or almost full. The ink absorbers hold liquid and dried ink after it has been purged from the print head. These absorbers can control enough ink for the expected life of the machine.
If the message "Clean Unable 46" continues to appear on the display the Brother machine after completing the firmware upgrade and your machine is within warranty (even if it's not under warranty you have to do the same thing), you have to take it to a Brother Authorized Service Center. http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002600/000059/faq002659_000.html?reg=us&c=us&lang=en&prod=mfc290c_all&Cat=11
Dec 17, 2010 | Brother MFC-290C Printer
My canon ir2000 copier says: System Error E000!!! what can i do for this kind of error. my exact copier model is Canon IR2000. sorry for product identification i didn't get my model from the list thus why...
That means that you have fixing error.Try next:
press MENU and #, with cursors go to clear, press ok, select err or all and ok.
If the problem was only fluctuaction in temperature the machine would work normally.
If not call service, because you have problem with heating lamp, or thermistors, or...
hope that helped
May 13, 2010 | Canon iR 1600 Laser Photo Printer
My xbox 360, had the E74 error problem, with 1 red light! I fixed that, but now it starts up as a working xbox but when i put a game in it wont play it, and just says play Dvd, can u help Please!
Hello rickster32
As you have mentioned that you got a E74 error problem which you got fixed up, E74 problem is a hardware related issue so the problem you are now facing is linked to a messed up dvd rom firmware issue.
It is very much possible that post you have fixed E74 problem your dvd-rom firmware could have gone corrupt and now is not recognizing the game discs and only playing dvd's
It would be advisable to send your unit to MS support if in case it is under warranty
Nov 12, 2009 | Microsoft Xbox 360 Console
System error E000 in conon ir2000
Sir,
The error can be cleared in the service mode.
Contact Canon Consumer Products 800-828-4040
Press Additional Functions key
Press #
Press > to #7 Printer Function
Press Set
Press > to #4 Printer Reset
Press Set
Press <
Unplug printer and repower it.
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Thanks
Good Luck
Apr 28, 2009 | Canon imageRUNNER 2000 Copier
NAND FLASH ROM ERROR - 2490MF
Konica before fixing the issue used to ship out the controller board.
Now a simple firmware upgrade will solve your issue
Aug 11, 2008 | Konica Minolta magicolor 2490MF Laser...
Thanks for the info on canon IR2000 fuser code reset. Do You Know if This procedure works on all IR models? And Thanks again for your prompt reply. Ernie
posted by ernie52 on Jul 14, 2008
Yes it will works on all IR models! I try it many times for all my customer here in Saudi Arabia and it works all the time!
Christopher
Jul 14, 2008 | Office Equipment & Supplies
Canon iR 1600 Laser Photo Printer Logo
494 people viewed this question
old marine
old marine
