My ac unit will not go below 77 degrees. It quit working about 1.5 weeks ago, and I had a service technican come and look at it. He replaced the capacitor and the unit started back up and would cool to 75 degrees (where I usually have it set). He checked the pressure of the unit as well and said that it was fine. However I came back from a trip and the thermostat read 77 degrees even though I have it set on 75, and the temperature will not go any lower. This is the same thing it was doing before it quit the last time. The filters are clean, and I routinely clean the coils outside, and the technican said that I do a good job with that as they were clean when he came to fix the unit. It has been crazy hot this summer (I live in KY) and we have had 100 degree temperature with the heat index just about all summer. Is there something else that could be causing this? Like the inside coils needing to be cleaned? The coils are sweating inside by my furnace.
    President:
  • 1,515 Answers
Hi, It sounds to me like you have covered all of the basis. The evaporator coil should be clean if you keep your filter clean and the condensation is showing that it is cooling properly. Normally, when the temperature increases outside, you will loose as much as 35% of your units efficency as it it working very hard. 77 degrees is very good temperature if the outdoor temperature is in the triple digits or a little less. It may be that your thermostat is off just a little also. If you clean your coils and keep it up like he said, that is great! I wish more people would do this. You should have a 18 to 25 degree temperature difference between the supply air from you vents and the return air at your filter. Example, if your supply air is 56 degrees, and the return air is 76 degrees, a 20 degree difference or TD, that is excellent. You can check this with a thermometer. I live in Northern Ca and it gets up to 116 degrees here in Redding!! We are lucky to have it 80 degrees in our home, no kidding!!. If you are unhappy, call this tech about it and see what he says. Your indoor coil is fine if you have no ice and I know you keep your filter clean. If you lost a capacitor again, you would have no cooling. Like I say, keep a eye on it, it could be the stat not accurate. Check the supply at the vents and filter to see what you have. If its lower then 18 degrees or higher then 25, you have a problem. If you are in the triple digits, this will cause this. I wish you the best and keep up the good work on that unit! That' great! Please keep me posted and please be kind when rating me as I know you will. Let me know the out come.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Aug 05, 2010
Testimonial: "great info thank you"
  • Robert Horton
    Robert Horton Aug 06, 2010
    Thank you for the great rating, and I wish other people could read your story on how to service there a/c units!!
    Shastalaker7
    Genius:
  • 1,363 Answers
Most a/s's are designed for a 95 degree ambient. and higher and you start loosing effiency.
Posted on Jun 19, 2015
Olds aurora 95 ac -- freon good. starts good in am. runs great. ac blows ice cold 60 degrees ( using a lazer temp gauge) out side temp 77 degrees -- ran for 2 hrs. ice cold. Then outside temp over 85...
About the only thing that it could be is a dirty coil,or some one over charge the system, I have seen just a layer of dust cause the compressor to cycle off to its thermal over load. Clean the coil.
Jul 08, 2011 | Heating & Cooling
One year old Amana ASZ 16 (replaced inside and outside units last year) - works fune until the last two weeks, now home at 5pm, reset the thermostat from 82 degrees to 76 or 77 to cool off house (which...
Sounds like the system is either over charged with freon or under sized. Call the same people back out ask for a supervisor to come out and check out the system any other company will charge you.
Jun 10, 2011 | Amana Heating & Cooling
Top freezer quit freezing. Refrigerator works.
Good day,
Yes, the cold weather is the cause.
Your machine is cycled off and on by the thermostat located in the fresh food compartment. When the fresh food compartment is satisfied, it will shut off the entire machine.
Any temperature below 55 degrees will reduce running time until the freezer will not function, or at best poorly.
Engineers designed domestic refrigerators to balance properly between 70 and 95 degrees. It should be in your user manual.
Thank you for using FixYa
Jan 12, 2010 | Frigidaire 20.6 cu. ft. Top Freezer...
Can not get temp below 77
Is the thermostat set up for automatic change over from heat to cool? If so, the heat is probably set for 75, you will need to lower the heat setting in order to Lower the cooling. the stat won't let these settings with in 2 degrees of each other so the heating and cooling don't fight each other.
Aug 25, 2009 | Heating & Cooling
Sideby side whirlpool- 3 years old- ice maker stopped working 3 weeks ago. today everything in freezer is melting
Verify condenser fan is running. Check evaporator coils for frost. IM will quit if freezer does not go below 5 degrees. The cooling was slowly dieing and finally warmed enough to defrost the food.
Eric
Jul 16, 2009 | Refrigerators
AC unit is running, but the house doesn't get cooler.
a/c is either on or off,there no in between.check air filters make sure they are clean.also keep in mind a/c will only bring temp down about 15 degrees from outdoor temp
Jun 23, 2009 | Honeywell Electronic Programmable...
Heating & Cooling Logo
427 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
