Question about Dryers
I own a whirlpool gold dryer about 4 years old. I empty the lint catcher frequently. I noticed however, that sand has accumulated inside the dryer, I hear the sound when the dryer starts tumbling. How can I get this sand cleaned out?
    Genius:
  • 1,073 Answers
Not as hard as it will sound here we go
remove the lint filter
remove the 2 phillips screws at the filter housing top you will see these screws after you have pulled out the lint filter
unplug the dryer
remove the back panel
on the left side is the lint filter housing it is held in place with 4 1/4 inch screws remove them
lift up on the filter housing and pull forward you will find the sand inside the filter housing use a vac to **** it out and reassemble the dryer, no more sand
Posted on Apr 26, 2008
Why is my Zanussi dryer stopping after 4 minutes it is heating and tumbling
As you are aware, every year manufacturers of products in this country try to make their products safer, and in the case of clothes dryers, they try to make them less susceptible to fires from accumulated lint.
To that end, it is probable that your clothes dryer has accumulated lint internally, and either some fuse (or fuses) or one of the "shut-off-thermostats" is kicking in every time you start it.
Someone will need to take the whole machine apart and clean out the lint, and check the fuses and thermostats with an electrical tester.
The lint that accumulates is not caught by the lint screen, it is throughout the inside of the machine in the tubing.
God bless your efforts.
( P.S. I have taken several machines apart and found a whole shoe-box full of accumulated lint inside.)
Jun 30, 2016 | Zanussi Dryers
Whirlpool duet dryer
When the dryer is not is use, it is recommended to leave the dryer door open. What you are experiencing is probably due to outside air coming back thru the dryer vent (the louvers don't always close well due to lint). The temperature difference between the outside air that accumulates in the dryer and the inside air causes condensation.
Aug 05, 2014 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Burning smell when on.
You could have an issue with lint that has accumulated surrounding the heat element, motor, etc., or there may be some faulty wiring. Contact an appliance service company.
Apr 14, 2010 | Whirlpool GEW9200L Electric Dryer
I smell a burning smell from the dryer. I was running dryer a lot today and tonight I smelt something burning when I opened the door. I noticed my light catcher was full, could this be the problem?
Yes it could have been the lint igniting in the bottom of your dryer in future clean lint trap after every load and take trap door out and vacumn inside trap at least once a month If you ignore the lint trap you could end up with a serious fire so take care of it when you remove screen a certain amnt of the lint falls down into the bottom of dryer and after time a buildup can ignite.. more serious with a gas dryer as the igniter and burner is at the bottom of most gas dryers
Dec 17, 2009 | Whirlpool GEW9200L Electric Dryer
I need a part number for the lint screen fora 9200l series dryer i lost the manual please help
Hello there:
Whirlpool recommends
8557884 Whirlpool Kenmore Lint Filter (screen)
This Genuine Whirlpool dryer lint filter is used on Whirlpool, Kenmore, KitchenAid and Roper dryers.
Special Note ***** Does your filter have a black spacer below the handle?.
************ If so you may need the Whirlpool Dryer Filter 8557857
The 8557884 Whirlpool Kenmore Lint Filter (lint catcher) is about 17 and 1/2 inches long and has a white handle
Hope this is helpful for you
best regards Michael
Nov 30, 2009 | Whirlpool GEW9200L Electric Dryer
My Dryer not that old, takes all day to dry a small load.
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Aug 31, 2009 | Whirlpool LER5636P Electric Dryer
A nickel fell in the lint catcher and the dryer stopped
Take the back off. You will see the blower housing. Take the 1/4" screws out and pull the cover off the housing. You will find the nickel inside binding the blower wheel. Remove and put back together. There should not be any problem.
Please rate solution
Aug 27, 2009 | Whirlpool Dryers
Increased drying time; removal of lint behind tumbler ???
I have a top loading Kenmore High capacity dryer that is over 10 years old, it has been working very well, unfortunately when cleaning the lint filter my wife dropped a piece of paper down the lint duct hole. The paper evidently fell to the bottom of the lint duct. I am unable to reach the paper from the top of the dryer where the lint filter is inserted.The dryer now makes a grinding type noise when it is turned on. Can you tell me how to reach the paper and remove it
Mar 28, 2008 | Frigidaire FEX831CS Top Load Stacked...
Roper dryer by whirlpool- gas dryer
You have a severly blocked vent, its not removing the moisture to the outide but instead getting trapped in vent.reccomned reventing unit with solid duct pipe, not the vynyl flex tubing and mke sure the outside exhaust port is totally free of obstruction a well
Feb 24, 2008 | Dryers
Dryers Logo
905 people viewed this question
Top Dryers Experts
