Question about Zanussi Dishwashers
HI I HAVE A ZANUSSI ZDF221 DISHWASHER THE WATER WASN'T GETTING HOT ,SO I FITTED A NEW ELEMENT BUT IT IS STILL THE SAME ,ANY IDEAS WHAT IT COULD BE MANY THANKS ALAN GRIFFITHS
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
Hi the most likely cause is the electronic mounted in the control panel behind the progamme dial. there is a relay which can unsolder itself. you can try resoldering (use lead free solder). or change the electronic.
Posted on Aug 05, 2010
Suddenly, our dishwasher has stopped washing properly. It leaves deposits of powder on everything, and isn't drying after washing. Topped up rinse aid and salt and cleaned filters, but that hasn't...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Aug 26, 2011 | Zanussi 23 in. ZDi6053SX Built-in...
Hi,ive replaced the heating element on my zsf6150s-no hot water
Try resoldering the main PCB connections, it cured my problem.
Jan 23, 2010 | Zanussi 24 in. ZSF6150 Free-standing...
Hi, my zanussi zdf221 dishwasher wont work, it makes a noise and constantly empties, any ideas please
The outlet pump is triggered by the anti flood micro switch via the polystyreene float on the base of the washer. If any water for whatever reason (leaky pipe)is on the floor the machiene automatically switches to pump out mode and only works once the water and the cause is rectified
Jan 16, 2010 | Zanussi 18 in. ZSF4123 Slim-Line...
No hot water
Hi Jon, is this a new machine that you have just got? if so it sounds like the hot and cold water pipes are on the wrong way round. If not sounds like a thermostat problem
May 29, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Dishwasher not heating Zanussi
I have an older dishwasher also and recently my wife also complained about it not cleaning right... so me being the man I am tried in vain to clean the things... Bought new spray arms online and installed them in minutes...now the thing works like new... However I have also found that if the heating element goes bad then that also can mess things up bad... So I would buy new spray arms, and also check out the heating element to make sure it is working... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
lmnbv
Mar 30, 2009 | Zanussi 23 in. ZDi6053SX Built-in...
Hi there I have a Zanussi zdf121 dishwasher which is only doing a cold wash, not heating at all. Not sure if its hot fill but the hot water is fine elsewhere. Any ideas please Pete
Do you have it hooked up to hot or cold water supply? Most residential dishwashers don't come equipped with a booster heater. If it's connected to the cold side, you'll have to replace the angle stop with a single outlet stop and replace the hot angle stop with a double outlet stop. This should help out, if not, make sure you have hot water in the faucet before starting the dishwasher. Most dishwashers need at least 120 degree hot water supply.
Mar 02, 2009 | Zanussi 18 in. DA4342 Free-standing...
I am trying to source a heating element for a zanussi dishwasher zdf221 and information on how to fit this part thanks
if in uk, try currys partmaster mor you local service force dealer. don't know this particular model but should be easy to do. remove back and element is usually held in by 2 7mm nuts. disconnect wires from element, making a note of where they go. there is sometimes also a bracket inside the oven which holds the element up and this also should be removed
Jun 22, 2008 | Zanussi Dishwashers
Wont heat or dry
hi have you tried thermostat i repaired on last week same fault
Dec 20, 2007 | Zanussi 24 in. DE6850 Free-standing...
Dishwashers Logo
320 people viewed this question
Top Zanussi Dishwashers Experts
Paul Carew
Charles T Nevin
Charles T Nevin
Are you a Zanussi Dishwasher Expert? Answer questions, earn points and help others
