Question about Sony Car Audio & Video
Hi i got a sony xes-m3 amp can u tell me what rms watt it is
Cerfer39
  • 709 Answers
SOURCE: confused
Hi jimmyjames,
How do you have the wires hooked from the sony reciever to the inputs on the mtx?
 Sounds like your Remote wire is way too big. it should be 14 guage.  It only sends a low voltage low amp signal.
Another thing that could be messing up the sounds is the routing of the wires.  you should have the power supply wires separate from the Audiop signal wiring.  Power should run down the Driver side and Audio down the passenger side.
When you answer I may be able to tell you more.
Posted on Oct 19, 2007
  • 8 Answers
SOURCE: whats the RMS on my 1000watt 4ch amp???
hi
Ive done some research and i haven't found any conclusive ending however the best i can do is tell you the round about RMS which is approx 200 to 150 unbridged.
Posted on Dec 18, 2007
  • 631 Answers
SOURCE: Amp getting really hot
Disconnect the speaker wires and the RCA jacks from the amp.
If it still gets hot, the amp needs to be repaired.
If it doesn't get hot, check the impedance of the speakers and make sure they're wired properly.
If they are wired for the proper impedance, check each voice coil with an ohm meter to make sure none of the voice coils are shorted.
Posted on Apr 11, 2008
blueextc3221
  • 15935 Answers
SOURCE: adjusting wattage on kenwood kac 9103 class D mono amp
That amplifier is 900W x 1 @ 2ohms.
If your subs are 4ohm SVC wired Parallel, resulting in a 2 ohm load, each sub will only see 1/2 of the rated power. (450W ea.)
Your gain (sensitivity) setting should be between 75% and 85% to max. You will be fine.
Posted on Jan 03, 2009
  • 56 Answers
SOURCE: can a 1000 watt amp run 800 rms subs and best wiring option
yeah it will run them but you won't get your full power because the rms for your subs is high. try bridging them with some 8 gauge wire, and of you got a crossover it will help you out alot
Posted on Feb 22, 2009
Hi,I have two 250w speakers at 8ohms ,could someone tell me if I need to get a amp with higher watts than the speakers?k
Speakers are rated either at RMS (root mean square) average power or Peak Power. An RMS of about 125 watt is equivalent to 250 watt peak. To match the radio and speakers they both need to be consistent. Also do not be confused with total radio power out vs per channel.
So if the speakers are 250 watt peak power then a radio with 125 watt per channel or 250 watt peak per channel would be a good match.
If the speakers are RMS 250 watt then the radio would be 250 RMS/channel and usually with a four channel radio a total of 1000W RMS
With that much power the neighbors should hear you coming!
Dec 02, 2015 | Car Audio & Video
Want to buy a sony subwoofer XS-GTX120LT. Just dont know what amp to buy.
You need to look at the RMS of the sub. If it say 1200 watts max you RMS is around 100 watts. By a amp that the Rms is the same or slightly lower so you don't blow the sub
Sep 17, 2012 | Sony Car Audio & Video
What watt amp would be best for my 1100 watt 10 inch xplod?
I have a 1100 watt sony xplode the silver one 4 ohm rms 3 00 with a 3000 watt 400 rms pyle amp? 8 ohm
Sep 16, 2011 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
My stereo in 1997 chevy caviler is turning off and on when turned up to a high volume. I have a sony xplod 52 watt by 4 channel radio. With two 6x9 sony xplod 50 watt rms and 300 watt peak power in the...
Most likely cause is heat. The clearances behind the radio are often not sufficient to provde the proper air coolling that the higher power radios need. The heat sinks on the rear of the radio require a certain amount of air flow to dissipate the heat generated under high load conditions. If you add summer heat to the equation, you can have the radio going into thermal cutout to protect it circuity.
May 27, 2011 | 1997 Chevrolet Cavalier
My car is a 92 ford falcon when u play bassie music u can only just here it out side the car but when u pop the bot u can realy here it wat can i do to make it louder out side the car
crack the windows and drop the sony bull **** and get your self a nice mono block class d amp 1000 rms should be loud enough btw bild your stereo based on rms power not max power rms is the true power you got so like 2 500 watt rms 12s on a 1000 watt rms amp or just a 1000 watt woofer it will be jsut as loud as the 2 12s
Mar 30, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
What size amp do i need to run 4 1000 watt pyle 10's bridged
well first of all you cant bridge subs... you can bridge an amp... and for 2 they are probablly not 1000 watts, make sure you understand RMS and what the sub can ACTUALLY HANDLE properly... i would get a 1000 to 1500 watt RMS that is RMS RMS RMS RMS amp not one that says 2000 watts MAX POWER cuz thats cheap ****... get a kicker JL hifonic alpine or something in that category that actually tells you the TRUE power output of the amp... then run those 4 subs in a parallel circuit so its like really only having 2 subs. make sure then these subs do not run less then 2 ohms at the terminals while in a parallel, then bridge these subs acting as 2 subs not 4 to your TRUE 1000 watt amp and you should have a good powerful system
Mar 19, 2010 | Pyle 10'' Subwoofer Tube w/Amplifier Car...
Amplifier For Powering Sony Xplod xs-l121p5
Pump the brakes!
You need to know the RMS power rating of the sub you are powering.
Dont exceed the RMS power rating of the sub by more than 25%.
If you see a peak power rating on either the sub or the amp, ignor it, means nothing. Always compare RMS ratings.
Example: a Sony 12" Xplod sub, boasting 1200 watts, will only handle, 350 watts RMS, so the amp you choose to power the sub should be 350 watts RMS as well, and should not exceed more than 25% of the RMS power handling (487.5 watts).
Bottom line, know your RMS numbers, not Peak.
Byron
www.distinctbeat.com
Dec 06, 2009 | Sony Car Audio & Video
I installed a sony 600watt amp and it works but old rockford fosgate 200 hit harder how do i make my amp louder and evenly spread throughout my car
Hello jmanbutt99,
The old Rockford-Fosgate was probably producing the rated power. The Sony is most likely overrated. But, it's supposed to be stable on each individual channel down to 2 ohms and will deliver 65 watts RMS into that load. So to get the most from it, your best bet would be a pair of 4 ohm speakers paralleled to each channel. A relatively efficient speaker like the Kicker 07DS600's shown here should provide pretty good sound.
http://www.crutchfield.com/p_20607DS60/Kicker-07DS600.html?tp=105
These will work with as little as 6 watts RMS and can handle up to 50 watts RMS so the Sony should power them really well. They're 4 ohm so a pair in parallel will present a 2 ohm load.
Hope this helps
Oct 30, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Is amp big enough for speakers
To run 2 subs, the amp would be a little small. The subs will run OK, they just won't be very loud.
It's usually better to compare and match up the RMS power rather than the peak power. The Sony XS-L10P5B sub has a peak power handling figure of 1200 watts, but the RMS is 300 watts. The Sony XM-ZZR3301 monoblock amp puts out 1100 watts peak, but only 330 watts RMS. They would work great together, 1 sub, 1 amp. But if you add another sub, each one would only be getting about 165 watts. They'd work OK, just not as loud as they could be.
Hope this helps!
Mar 28, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Confused
Hi jimmyjames,
Oct 19, 2007 | Car Audio & Video
Car Audio & Video Logo
146 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
