Can a pop off valve be moved from the side to top of a electric water heater model EE3J40RD045V 40 gal?
    Problem Solver:
  • 10 Answers
Not Legally....... OR safely.......
Posted on Apr 26, 2008
Change anonde rod in a model 602 40 gal.electric
Maybe in a separate anode port on top of heater... or connected to hot water nipple as a combo
http://waterheatertimer.org/Replace-anode-rod.html
Gene
Sep 13, 2014 | RELIANCE ELECTRIC WATER HEATER
Where is water shut off valve for Rheem 40 gal electric water heater?
The water does not have a shutoff valve. The valve should have been separately installed, usually directly above the water heater on the cold water line.
Gary
Sep 25, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
What is recovery on a GE 40 gal gas water heater model PG40S9b
GE is made by rheem-so it should be around 38-41 gal per hour-should be on nameplate by gas valve
Jan 26, 2011 | General Electric GE SmartWater Household...
I need to adjust water temperature, and dont have a manual. i have a 81v40d C model , 40 gal electric.
Here is a tip that I wrote to help people understand how to adjust the temperature on their electric hot water heater.
Electric Hot Water Heater Temperature Adjustment
heatman101
Oct 16, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Can this water heater be reset
Red button on upper thermostat just press it to reset.
Jun 07, 2010 | Reliance & 40 Gal Electric Mobile Home...
Pop off valve keeps popping off and makes hot water run all the time
Is the water extremely hot?? If so, then I would probably recommend new thermostats for top and bottom of the unit. The only time these temperature related overflows are activated is when the water temperature reaches a certain temperature and they are there to safely relieve the pressure/temperature so the unit doesn't explode.
If water is not terribly hot from normal, then I would say the TMP valve ( the valve that you are referring to) needs to be replaced and can be done easily by turning water off, and picking one up at any home improvement store for your model and just unscrewing the one you have out, putting on pipe thread sealant on new and rescrewing the new TMP valve into the tank.
Good to go after that,
Let me know!
Chip
Apr 11, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Pop off valve dripping Rheem 50 gal electric valve at bottom
If you are reffering to the drain valve at the bottom of the hot water tank. It may be leaking due to the O ring being cracked or worn out. You can either drain the tank and replace the valve or you can buy a hosebib brass cap and thread it on the existing valve. There is no cause for alarm when doing this as this valve is just to drain the tank when replacing your hot water heater
Feb 23, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Low amount of hot water
You say a very new water heater. You won't get 40 gallons of hot water from a 40 gallon water heater because the continuing influx of cold water will cool your hot water down. However, it appears that your bottom water heater element needs replacing. If the top element is bad, you'll get no hot water. If your bottom element is bad, you'll get "some" hot water. Try replacing the bottom element. DON'T FORGET to turn off the electricity AND water first (closeby towels are also handy)!
Mar 09, 2009 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Heating & Cooling Logo
63 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
