When you double click the Printer and Faxes icon in the Control Panel
you will see the printer that your computer is currently using. See....
if the printer image is clear it is online and ready to use, if its
blurred then its in offline mode and cannot be use.
To correct
offline printer.. some possible reasons is on the usb cable.. check if
there is no open wire along the cable...Inserting the USB connector on
the other usb slot of the cpu sometimes work just wait first until it
is read.
If the printer is still blurred and offline after
checking the usb connection, the 2nd thing to do is check the
properties of the printer if it is set to offline mode. how? Double
click your printer icon. It will display the print jobs window. Click
on the Printer tab and uncheck on the "Use printer Offline". Cancel all
pending print jobs, close the printer window and try again to print.
