Question about Brother GX-6750 Typewriter
Daisy wheel does not want to reset despite typing the reset function thus producing wrong letters all the time
  • Brother Master
  • 3,594 Answers
The homing pawl is probably broken, youneed a tech.
DickyO
Posted on Aug 05, 2010
Typewriter spaces the letters wrong and types the wrong letters
how to install and set the daisy wheel correctly onto the typewriter
May 22, 2013 | Brother GX-6750 Typewriter
When you type, each character you strike actually types another letter.
first try turn typewriter off, (button on left panel toward the back), then turn it back on, and while hold down the CODE button, press RESET key, the whole print head will move and reset
if that doesn't work, power off again, open the cover, release the lever to the Daisy Wheel, and inspect that Daisy Wheel - mine has a bent forward letter, and another letter was kinda stuck to the side of another letter... I gently fix both letters, put the Daisy Wheel back in, firmly lock it in place with the lever, close the cover... and voila, it works like a charm.
While you have it open you might want to dust (use the cleaning spray can duster)... You wouldn't believe what I found in my typewriter... Good luck!
If that doesn't work, I would replace the Daisy Wheel.
gkt
Jan 12, 2011 | Brother GX-6750 Typewriter
When typing with my brother gx-6750 it types weird lingo is the type set messed up or can I reset them?
Your daisy wheel letters are bended not straight.
Switchoff just remove your daisy wheel & remove the daisy wheel from its cover & see all the letters should be straight.If any of them is bended jst make them straight by your fingers dont press too hard & then fix the daisy wheel back & switch on typewriter.
Jul 20, 2010 | Brother ML-100 Typewriter
Not typing correct letters
Major fault. Daisy-wheel sensor is losing position.
Probably a a motherboard fault, and beyond economic repair. Sorry.
Apr 12, 2010 | Brother SX-4000 Typewriter
The keys will not type the letters they are labeled with.
Do you have the daisy wheel cartridge inserted correctly? The "ear" on the daisy wheel cartridge should always be on the upper right.
If that doesn't fix it .....Try doing a daisy wheel reset by Pressing [CODE] + [RESET]. This will properly index the daisy wheel.
Mar 25, 2009 | Brother SX-4000 Typewriter
HELP..BROTHER DAISY WHEEL TYPING RANDOM LETTERS AND SYMBOLS
Press the Code button and the Q/Reset button at the same time and the wheel will spin and go back to the correct place.
Feb 06, 2009 | Brother SX-4000 Typewriter
GX6750 Typing wrong letters
Linda,first of all,does the daisy wheel spin when the typewriter is first turned on? if it does,then you will feel assured that it is installed properly. Next, refer to your manual to key board settings. It will indicate that there are settings for normal standard English keyboard and somehow that setting may have been changed. It would be also be important to check the daisy wheel to see if it is compatible with standard English keyboard...Cheers, John
Oct 21, 2007 | Brother GX-6750 Typewriter
Not typing the correct letters
The ML-300 needs to be reset each time the Daisy Wheel is removed or replaced or if the Keyboard Switch changes position. According to Brother, if this is not done the typewriter will print incorrect characters. Try these steps: 1) Open the Top Cover. There is a lever directly behind the Daisy Wheel. Pull the lever back towards you. Remove the Daisy Wheel by pulling it up and out. 2) Verify that it is the Standard Daisy Wheel that came with your machine and not a Symbol or International Daisey Wheel. Write down the Pitch (10, 12, or dual pitch 1012) printed on the wheel. 3) Reinstall the Daisy Wheel (the plastic top ear goes to your right.) Push the lever (step 1) forward. 4) Press the ALT key plus the PITCH key and the number 1 key simultaneously. Verify the Pitch setting is the same as is printed on the Daisy Wheel. 5) Press the CODE key plus the RESET key and the letter Q key simultaneously. This will reset the typewriter mechanism and align (or time, in technical terms) the carriage mechanism. Check if the typewriter prints correctly now. If still incorrect, perform these additional steps. 6) Verify the three position Keyboard Switch (inside the top cover, on the right side, at the bottom) is in the I=Standard position. The other positions are: II=International and III=Symbol. 7) If the Keyboard Switch is in the correct position, slide it to position III and then back to I. (This will clean the switch contacts in case they are dirty and not making good electrical contact. 8) Press the CODE key plus the RESET key and the letter Q key combination again to reset the typewriter mechanism. Check if the typewriter prints correctly now. If still incorrect, the only other things I can think of is that: 1) an incorrect Daisy Wheel is installed that does not work in the ML-300. Brother sell a "B type" Daisy Wheel with two plastic ridges/raised slots below the center of the Daisy Wheel (viewed with the raised top tab on your left.) The B type are incompatible with your machine. 2) the typewriter has failed and needs repair.
Sep 28, 2007 | Brother ML-300 Typewriter
Cannot type letters.
Your T/W neads a new keyboard membrane, you cannot clean this type membrane so you will have to replace it.
May 26, 2007 | Brother GX-6750 Typewriter
Types wrong letters
Check keyboard setting it is a international typewriter, hold down code key and press keyboard to USA? daisy wheel is bad or motor is out.
Feb 24, 2007 | Brother SX-4000 Typewriter
Brother GX-6750 Typewriter Logo
61 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
