Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Mower deck belt pulley gone - Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
How do i lock idler pulley in place so i can unscrew the bolt to replace belt?
Posted on Aug 26, 2010
  • 3 Answers
There is what they call the spindle assembly. Some times if the bearing is not lubed enough or just plain old it will sieze up . When this happens the pulley shears off of the rod it spins on. The deck must be removed and you can buy a new spindle assembly. In most cases you need your old pully however or you will need a new one of those as well. The other possible solution could be the bolt came loos and it simply fell off . In that case you need a new pulley , bolt to hold it on , and a washer in the middle. Good Luck I just had this same problem on a mower I purchased to fix up. It cuts great now.
Posted on Aug 06, 2010
2 Suggested Answers
2strokeguy
  • 183 Answers
SOURCE: what is the deck drive belt length for this mower
Your mower uses the #144200 belt by A.Y.P. This belt is 1/2" by 88.3" You must use a wrapped belt for this application. The #144200 is available through www.searspartsdirect.com and will also be readily available at your local repair shop.
Posted on Sep 10, 2010
I need help putting rear end back together on a 10 hp30 Murray riding lawnmower
Safety and Preparation Serious injury can occur if the engine or mower blades accidentally start while you are working with lawn tractors. To prevent this, drive the Murray lawn tractor onto a flat work surface and disengage the mowing deck cutting blades. Engage the parking brake to keep the mower from moving; chock the wheels with a wooden block or brick. Adjust the mowing deck to the lowest position. Turn off the engine and remove the key from the ignition. While not necessary, you may even wish to disconnect the spark plug wire from the spark plug. Mowing Deck Removal You must remove the mowing deck on a Murray lawn tractor to gain access to the belts. Remove the adjustment rod hairpins, followed by the adjustment rod pins from the front left and right sides of the mowing deck. At the rear on the left and right sides, pull out the retaining hairpins and slide the mowing deck suspension links from the adjuster plates to separate the rear mowing deck from the frame. Remove the blade control rod stud, including the hairpin and washer, from the top of the blade control lever shift linkage at the left rear of the deck. Remove the front hanger rod, including the hairpin and flat washer that hold the rod in place. Loosen the belt guide retaining bolts with a socket wrench and remove the engine stack pulley belt so you can slide the mower deck out from under the tractor Transmission Drive Belt Installation Slide the new transmission drive belt between the engine stack pulley belt guides, over the belt guide plate and under the engine stack pulley. Fit the transmission drive belt around the top engine stack pulley. Push the free end of the transmission drive belt up through the transmission shifter hole in the lawn tractor floorboard. Slip the transmission drive belt loop over the transmission shifter. Pull the transmission drive belt down through the transmission shifter hole. Fit the transmission drive belt around the transmission drive pulley and tighten the transmission drive pulley belt guide retaining bolts to hold it in place. Fit the transmission drive belt flat side around the idler pulley. Slide the idler pulley onto the idler pulley stud while holding the belt in place. Tighten the transmission idler pulley retaining nut with a socket wrench to secure the idler pulley to the idler pulley stud. Mowing Deck Drive Belt Installation Pull back on the right side mowing deck mandrel pulley spring-tensioned belt retainer. Guide the new mowing deck drive belt around the right side mandrel pulley and release the belt retainer. Pull the drive belt spring-tensioned retainer away from the mowing deck idler pulley, guiding the deck drive belt around the idler pulley. Fit the mowing deck drive belt around the left side mandrel pulley and under the rear mowing deck cross link rod between the right and left side mandrel pulley. Slide the mowing deck under the right side lawn tractor frame, reconnecting the deck to the frame in reverse order of removal. Engage and disengage the mower deck while driving the mower to test the belt for proper operation.
Sep 28, 2016 | Murray Garden
Can you show me the correct diagram for the drive belt on a 44in Dixon zero turn mower
Hope this helps. Serpentine Blade Drive Belt
1 Lower the mower deck to its lowest position.
2 Route the serpentine blade drive belt (part number 6109) onto the V-pulleys located on the mower deck. One double pulley is located at the front of the deck near the center. The other two pulleys are located near each side of the deck. Route the belt around the outside -- the side toward the outer edge of the mower deck -- of each pulley. For the double pulley near the front of the deck, route the belt around the lower pulley (part number 6058) only. If pulleys are fitted with belt guards, work the belt in between the pulley and shield.
3 Push the idler pulley toward the center of the deck with your hand. The idler pulley (part number 6059) is the fourth pulley on the deck and is located near the rear of the deck. It is the only movable pulley on the deck. Wrap the belt around the side of the pulley nearest the edge of the deck. Release the idler pulley to place tension on the belt. No adjustment is necessary because the serpentine idler spring (part number 6065), located on the idler pulley, adjusts the belt to the correct tension.
May 10, 2016 | Garden
I need to replace electric starter with manual starter for ariens 948401-210e series cultivator
you must go to the supplier manufactue to request service manual for this procedure. However you can do this:
Remove the mower deck:
  1. Make sure that the parking brake is locked.
  2. Place scrap lumber under the front and rear of the deck.
  3. Use the deck lever to lower the deck.
  4. Remove attachments from the deck.
  5. Remove the blade drive belt from the front pulley.
  6. Remove the front and rear deck fasteners, following instructions in your owner's manual.
  7. Use the deck lever to raise the deck.
  8. Remove the scrap lumber.
  9. Remove the deck from under the mower.
Adjust the drive belt:
  1. Remove the belt from the large idler pulley.
  2. Remove the belt from the adjustable idler pulley.
  3. Carefully remove the spring-loaded large idler pulley.
  4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it-or move it toward the front to loosen it-and retighten the pulley.
  5. Replace the belt.
  6. Check belt tension and readjust as needed.
Nov 20, 2013 | Garden
I need a belt diagram on a sentinel 12 hp riding mower
Are you still looking for that belt diagram..? Is this for the motor to trans (which is pretty simple) or the belt to the deck..? Couldn't find a diagram so hope my drawing comes out right.. This is for the deck belt routing..!!!
Left pulley (O\ /O) Right pulley
. Tension \ \@/ / Pulley
. Engine \ @ / Pulley
Front of mower here. Main thing is, you take the belt from BETWEEN the right & left pulleys, pull it down and around the tension pulley..
Apr 09, 2013 | Garden
Is there a way to tighten the deck belt? i have gone through 2 belts and they dont seem to be tight around the pulleys.
Your deck should have a couple "idler" pulleys on them in addition to the main mandrell pulleys that have tension on them via springs to keep tension on your deck belt. Maybe you need to really examine the condition of those "idler" pulleys and also the main pulleys to find the problem.
Sep 10, 2011 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
My Motion Drive Belt slipped of it's pulley on a Husqvarna Riding Mower Model 917-289570. Do I have to remove the rear tire to put the belt back on?
i had a 2148. you remove the mower deck as the first step. feed the belt over the pulley on top the transmission, then put it over the engine pulley. then have someone push the clutch pedal in so the tensioner pulley moves, put the belt in the guide pulley and on the tensioner. release the clutch put the deck back on and you are good to go. notice there are little keepers welded to the frame for the front, engine, pulley and it is easy to mistakenly put the belt over them instead of under them.
a general rule is that a pulley shaped like a Vee takes the V of the belt whilst a pulley which is flat takes the flat back of the belt. if you bear that in mind you will not have a problem putting belts back on. also there is a little decal on top the deck showing how the deck belt and deck drive belt go.
Sep 09, 2011 | Husqvarna Riding Lawn Mower 42 Inch Cut...
I have a hl454sp lawn mower and it wont propell itself does that mean a belt has gone and how do i change it and what part no will it be
This is just an adjustment problem. If the belt is broken then you will need to replace the belt in addition to adjustment. Look in the area of the belt. Look for an adjustment screw, or a bolt that moves a pulley or removes a pulley. Look underneath your mower deck the adjustment maybe under the deck. Take your time, you'll be fine. GOOD LUCK.
Jun 27, 2011 | Garden
I have a MTD lawn mower is believe is 21hp with a 42 inch cutting deck, its been chewing up deck belts, i just recently had it gone thru and had the tech replace the deck brakes one was severely worn and...
sounds like one or more of the pulley bearings is frozen or turning very hard just jack up the mower and check each pulley how easy it turns replace bad one hope this helps
Apr 18, 2017 | Mtd LAWN MOWER PART # 753-0698 KIT-DECK...
I have a Sears Garden Tractor with a 48" mower deck. By working in long, thick grass I broke the mower belt -- not the one that transmits power from the engine, but the belt that sits in a pulley on...
I believe that tensioner pully has to be loosend up and moved.
Here are the instructions for this.
  • Place the deck in the lowest position using the hydraulic piston (if applicable) or the manual cutting-height adjuster.
  • 2
    Remove the deck-to-PTO belt from the PTO by releasing tension on the idler-arm pulley. This is a spring-loaded handle that turns in only one direction by hand and relieves the tension on the belt. Slip the deck-to-PTO belt off the PTO pulley after the tension is relieved.
  • 3
    Remove the deck from underneath the mower or tractor.
  • 4
    Locate any belt stops and loosen them with the ratchet wrench and proper socket. Belt stops are located on the deck and are the small metal brackets that guide and secure the belt to the pulleys so it will not jump off when under heavy use, or stretch from normal wear.
  • 5
    Remove any pulley covers by removing the retaining screws using the ratchet wrench and a socket.
  • 6
    Loosen the idler-pulley retaining bolt (located on the underside of the mower deck) to replace the deck-to-PTO belt. Removing the bolt is not necessary. Loosen the pulley enough to wiggle the belt free from the pulley and remove and replace the belt.
  • 7
    Remove any arbor covers (if applicable) that conceal the arbor pulleys by removing the retaining screws with the ratchet wrench and a socket to replace the mower arbor belt.
  • 8
    Locate the tensioner pulley on the mower arbor belt to replace it. Loosen the tensioner pulley bolt enough to slide it and release tension from the belt. Remove the belt from the arbor pulleys and replace it.
  • 9
    Slide the tensioner pulley back leaving about 1/2-inch of play in the belt and tighten the bolt. Reverse the procedure to put the rest of the mower deck back together and reinstall on the mower or tractor.
  • May 10, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
    Owners manual
    Maintaining Riding Mowers Regular maintenance can reduce repairs. pagetools_04a.gif spacer.gif spacer.gif
    Components of a typical riding lawn mower. (click to enlarge)
    It's fun to ride around the yard on the mower, watching scrubby grass (and weeds) turn into trimmed lawn. However, when the grass looks as bad after you mow as it did before, or the mower doesn't want to start, riding mowers aren't as much fun. That's when it's time to put on your Fix-It Club hat and have some more fun.
    A riding lawn mower is a gas-powered machine for cutting grass. The engine turns a rotating blade that cuts the top off the grass blades to a specified height. The operator sits atop the mower on a tractor-type seat with speed and height controls nearby. Riding mowers also can be used to pull small utility carts for other yard jobs.
    To remove the mower deck:
    To adjust the drive belt:
    4. Loosen the adjustable idler pulley and move it slightly toward the rear of the mower to tighten it[md]or move it toward the front to loosen it—and retighten the pulley.
    Apr 12, 2009 | Garden
    Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
    121 people viewed this question
    Top Poulan Garden Experts
    Jim Parker
    Jim Parker
    Phil Walker
    Phil Walker
    roeb
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
