Question about Brother HL 1440 Laser Printer
Paper Jam Paper has jammed behind the cartridge, and can't get cartridge out. Help??
    Novelist:
  • 105 Answers
Have you opened the back cover to see if you could extract the paper there?
Have you removed the paper tray, and attempted to extract the paper from the bottom side of the unit?
Posted on May 13, 2008
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
I AM RECEIVING PAPER JAM AT MY BROTHERS INTELLIFAX-2820 THERE IS NO PAPER JAM AT ALL( I CHECKED IT COMPLETELY). AND FAX MACHINE KEEPS RUNING UNTIL I PUSH THE STOP KEY AND GIVES THE PAPER JAM MESSAGE.
Where is the paper jam?Jou can take the cartridge out and look if the sensor actuator is in it's plase.if you open the back door look for small pease of paper that might stay behind or a paper that did not go through otherwise take the paper tray out and look in the botom of the machine for sensors or peases of paper
Jun 13, 2011 | Brother IntelliFax-2820 Laser Fax
I had a paper jam a few days ago. Turned printer off then cleared jam and when I turned it on again it still had the E3 error code indicating it is still jammed. There is no paper in it anywhere. I have...
Check the paper feed tray for bent papers. Also, try blowing over the sensors to clear any debris. Check for small pieces that may have been left behind. If all fails, unplug it from the outlet, then start it up. Good luck!
May 06, 2017 | Xerox WorkCentre XE90FX Laser Printer
MF4350d gives a paper jam error when it has no paper in it.
I hired a technician who came to house and showed me where the paper jam was hidden... found technician on craigslist for $50 flat rate, came out on Saturday. He solved the paper jam problem in 20 minutes. One place to check for paper jam you cannot see until to look behind a hinged plastic flap above the cartridge area. Remove cartridge.Above the cartridge area is a width-wide plastic piece, about 1 to 1 1/2 inch wide from top to bottom, hindged along the top edge, moves but is attached along the two lower corners of the piece by small springs (one at each corner) to the housing of the machine. You cannot easily lift the plastic flap up to look behind it for paper jam until you remove the springs. I used forceps to remove them. Tweezers may work. Don't lose them! Once you remove the springs you can easily lift up the plastic flap (it is hinged) and look behind it into the crevices for any paper. That is where we found a small piece of paper. We needed a skinny forceps to reach into the crevice to get the paper out.
Feb 16, 2011 | Canon ImageCLASS MF4350d Laser All-in-One ...
Tray is not feeding paper properly. Its making a weird clicking noise when paper is being fed. Paper gets jammed on most attempts.
Remove the paper tray and try to see some paper jammed somewhere around it. When pulling off paper jam. Just pull gently and slowly so that you can remove all and nothing left behind and doesn't damage the part when removing unwanted paper jam. Maybe it is the cartridge just repalce new cartridge if not the fuser drum maybe damage.
Dec 08, 2010 | Brother MFC-7820N Printer
Paper jam???
Follow these steps :
1.1
Remove all paper from the trays. This will prevent further jams during the clearing.
2.2
Remove the covering to the printer's outer case to expose the jam. Locate the jammed paper to ensure there is not another problem causing the stall.
3.3
Pull gently on the jammed paper, taking care not to tear it. In most cases, this will remove the jam.
4.4
Press the flashing "Printer Jam" button. This will allow the rotors to turn and facilitate the release of the jam.
5.5
Turn off the printer and firmly pull on the jammed paper. Be careful not to tear it.
6.6
Remove remaining paper shreds. if a tear occurs, remove any residual paper that may hamper printing.
7.7
Refill the paper tray and try printing again. If the jam persists, repeat the process and search for more paper.
Oct 29, 2010 | Canon ImageClass D861 Printer
I got a paper jam. I can not get to the paper. I see a small bit a paper but I can not get to it. I can not open the rear access panel. I can not pull the jam from the front. How do I clear the jam out?
I removed the cartridge, pulled out the skewed paper and it ripped leaving a very small piece behind. This continued the notice 'paper jam'. I had to remove the two side springs, remove the two star headed screws nearby the springs and prise up the grill to remove the paper shred. Replace everything and the error message is gone and printer normal.
May 19, 2010 | Canon ImageCLASS MF4350d Laser All-in-One ...
Ricoh AC 104 copier
If the paper jam occured behind the toner cartridge, did someone pull it out and leave a piece behind the toner? Look to see if there is a small piece of paper jamed in the connector of the toner / developing unit. Also look for any small piece of paper in the paper path.
May 24, 2008 | Office Equipment & Supplies
Printer cartridge jam
Oh dear, you may have a paper jam preventing it from movin, Open up the unit cover, get a torch and check thoroughly around it and rollers and down the back where paper goes behind unit too. I am willing to ber you find a tiny jam. Post back if it still won't print. Hint: sometimes you nedd to reset printer default settind and turn off and on again when jam is cleared to reset warnings.
Aug 27, 2007 | HP PhotoSmart 7760 InkJet Printer
Brother HL 1440 Laser Printer Logo
61 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
