Question about Swintec Office Equipment & Supplies
Swintec 2600-My cartridge is stuck on the left side -making a continuous beeping noise-how do I fix it
  • Swintec Master
  • 3,594 Answers
Look for debris in the area left of the printhead, anything that stops it from going all the way to the side frame.
DickyO
Posted on Aug 05, 2010
My carrier will only go about half way then it stops and starts beeping. how do i fix this? it is a swintec 2600
the long silver rod down inside your machine is sticky you need to lube it with some light machine oil then slide the carrage back and forth and clean the rod then reoil it again. this should take care of you issue.
Mar 27, 2017 | Swintec Office Equipment & Supplies
How to replace correction tape?
From the looks the typewriter is not electric but electrononic. Wind it the same way the old lift off tape was guided. The full spool on the left hand side around the guides in the front of the printwheel to the right side with the empty spool. Simple.
Feb 12, 2016 | Swintec 2600 Electric Typewriter
During typing, daisywheel spontaneously readjusts itself and then the machine beeps and will not continue. Will it be expensive to fix? Ballpark cost?
Daisy wheel is kind of old school nowadays, you might have to go to a office supply store like staples etc, to possibly get it fixed
Feb 11, 2015 | Swintec 2600 Typewriter
Need user manual for swintec 2600
You can purchase one here... http://www.swintec.com/typewriter-manuals/111-swintec-2600-manual.html
Jul 16, 2014 | Swintec 2600 Electric Typewriter
Sticker is stuck on carriage and can't reach it to remove it
PLATEN (Rubber Roller) does come out, knob on left side pulls off.
It is easier to do with top cover removed. 2 screws down in holes in back corner, on screw in middle where power cord comes in. Lift from back and gently pry off front. Once off on left side there is what we call a spring clip or keeper, gently pry off. We call these "JESUS CLIPS" because when they fly off you may not find them again, so hold hand over this clip. Once clip is removed the platen can slide to the left. Some have small plastic swing clips that spring out from a hole and pivot. Then you cna clean under palten and feed wheels.
Sep 30, 2013 | Swintec 2600 Typewriter
A swintec 2600 is making a beeping noise and it doesn't work, what can I do?
Give the silver shaft that the carrier slides on a **** of WD40, look for debris in the carrier area.
DickyO
Jan 05, 2011 | Swintec 7040 Typewriter
Swintec 2600 - turn it on, it doesn't respond.
Check to see if there is a key stuck down, if not you probably need a tech.
DickyO
May 14, 2010 | Office Equipment & Supplies
Swintec 8016 Typewriter making grinding noise all functions froze
Try some WD40 on the silver shafts that the carrier slides on they do get very gummy.
DickyO
Apr 26, 2010 | Swintec Office Equipment & Supplies
Constant beeping
sounds like your selection sensor has got a wire broken. if you look at the wire bundle coming off of carrier, three of those are for selection sensor. 1 blue, 1 red, and 1 black. one of those are most likely broke from continuous movement of carrier back and forth. common problem on this machine. that repair would have to be done by a tech however, as it is not easy.
hth,
razors
Dec 19, 2008 | Swintec 7040 Typewriter
220 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
