Question about Kenmore Refrigerators
Side by side - freezer works fine but refrigerator not getting cold enough.
  • Kenmore Master
  • 8,220 Answers
Most of the newer type refrigerators have a damper which opens and allows cold ar in from the freezer.Side by side - freezer - db9bc85.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 05, 2010
Freezer side not cold enough, similar temperature as Refrigerator side
It could be many things. My first guess would be the defrost. The coil that gets cold in your freezer builds ice on it and the only way to get the ice off is to run a heater near the coil long enough for the ice to melt. All freezers have something built in to defrost and domestic are typically just an electric heater on a timer. When your freezer stops working again, you may want to pull open the panel of your freezer and see if your coil (a heat exchanger that probably looks a lot like your car radiator) is covered in ice. If it is, it could be the timer or the actual heater that is bad.
Nov 12, 2013 | Refrigerators
Freezer side working fine - fridge side simply not cold enough even at highest setting
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 17, 2010 | Frigidaire FRS3R5EMB Side by Side...
Freezer Working Frig not getting cold enough at max setting
unplug 24 hrs with doors open plug in again if it works better you have a defrost problem. it may be the defrost termination switch.. burned out element or bad timer
Aug 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Fridge side not getting cool, freezer works great
is the fan running in the freezer?.
is ther ice build up on the back wall of the freezer?
check fridge control, set midway, same with freezer control
Jul 01, 2009 | KitchenAid (KSRD22FKST) Side by Side...
MY refrigerator is running but is not getting cold.
Hi thanks for the question. check the freezer ,is the fan running. check the back freezer wall for frost build up. pull fridge from wall. remove back panel. clean all coils . thanks the appliance doc
Oct 06, 2008 | Maytag MSD2454G Side by Side Refrigerator
Admiral side by side
All the cold air from your freezer gets pushed into the fridge with a fan in your freezer section. So your problem is from the fact that this cold air isn't get to your fridge.
- the door that allows this cold air into the fridge, normally in the top left corner of the fridge, is stuck shut and needs replacement.
-the freezer isn't defrosting and restricting the air flow
-the temp controller for the fridge is damaged and thinks that the fridge is cold enough.
Nov 15, 2007 | Admiral 26 cu. ft. Side-By-Side...
Refrigerators Logo
53 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
