When i turn the computer on a external exception eo6d7363 appears over and over
    Genius:
  • 3,587 Answers
Sounds like it's time to re install your operating system..got a recovery disk?
Posted on Apr 26, 2008
On attempting to open ExpertPDF8Pro, the following mesage appears: ----message starts---- Exception EexternalException in module KERNELBASE.DLL AT 0000c41f. EXTERNAL EXCEPTION C06d007e. ----message...
just after installing this app?
or first run
or after many runs? context?
what OS? XP,w7 or W8
is the program APP matching the OS you are running.
its no suprise running XP APPS on w7 or w8 , they are more protected.
here is my solutions>
1: DL the app that matches your OS.
2: or ask the makers of said app for help.
3: ore join their forum and ask for help there.
Sep 28, 2013 | Visage software eXpert PDF Professional...
My computer wont read my iomega external hard drive but read before now its just local disk c ...try to open but will freeze ...have a lot of stuff on hard drive so i cant just format it again...
This is quite a tough one, First does the external hard drive appear when on your computer at all? I would assume disk "c:" that you mention is your main drive or your internal harddrive. If you don't see your external on the computer when you have it plugged in and turned on. Then there is a promblem. 1) Make sure driver is installed, usually when you turn on the external harddrive or plug it in to the computer, the windows sound (found device) usually pops up. 2) Check all connections if all is properly made, and if you have another computer, test it on that computer if you get another different result. If same result is made, and all connection are properly secured. Then you external harddrive enclosure, or the harddrive disk inside it is bad. 3) Listen to your harddrive to see if you hear the drive inside it spins, or if it is making any noise. If spin you could be ok, if it is humming or clicking loudly like it's stuck, then you are kind of done for and could pretty much say goodby to all those files and stuff (with exception) 4) You can take the hard disk inside the external enclosure and hook it up to a computer (if you need help how to, let me know) and see if the computer is able to read it. If not, then definitly your drive is damaged. You can still recover the files, but can't gaurentee a full recovery. In that case, you can take it to bestbuy, office depot, and tell them about the promblem and have them do a data recovery. It is costly, I mean very costly. Anywhere from $250-$750+
Now, if your computer could detect it and give it a drive letter for exmaple D:, but unable to access the files, you can probraly do a error-checking when right click for propertie of the drive.
Feb 01, 2011 | Iomega 33089 250 GB Hard Drive
My i-rocks IR-9400 shows up under my device driver, however the icon is not available, and therefore the access to the files. It's not a driver issue. It also appears to be working properly with the...
Remove the drive from the external case and physically connect it to your computer. Start your computer and once it boots to whatever OS you are running, run chkdsk on the external drive. You will find the most common problem is that the file system is corrupt from being disconnected at an inapproriate moment. The only way to fix the issue is to connect it directly to the computer without the usb interface and then run chkdsk. Once chkdsk completes, double check your files are visible in explorer. Shut the computer down and reinstall the drive in the external case.
Oct 12, 2010 | i-rocks External Enclosure 3.5in. IR-9400C...
My gateway laptop does not recognise its internal dvd player or any ofthe external usb connections.The dvd player does not appear when i click my computer
upon turning the computer on the GATEWAY logo will appear. Wheb that comes on be very quik and keep pressing the F8 key. The screen will show a job to repair your computer. Use any one except for to run windows normally. This should help for it helped mine whn my CD was not regonized by my computers program
Jul 04, 2010 | Gateway MT6451 Notebook
Not recognised by computer
You gotta partition it first. http://windowshelp.microsoft.com/Windows/en-US/help/d9a4d35e-efdf-406c-a049-0860180129a71033.mspx
Except don't format the ones that already have a Letter (or u screwed urself there)
Sep 27, 2009 | LaCie External USB 2.0 500GB 7200 RPM 500...
Can't access data on external drive
Right click on the drive in my computer and click properties see what it tells you like info.
Jul 12, 2009 | Western Digital My Book Essential Edition...
HP Pavilian external monitor color problem.
The easiest thing would be to check your cable for a bent or loose pin. Next put another external monitor on the laptop. The circuitry to provide video to the laptop screen and the external monitor are separate except that they share a video processor and video memory. There can be bad electronics involved.
Apr 08, 2009 | HP Pavilion dv6000z Notebook
Navagon 5100
Hello 1234567i,
Most GPS receivers are not designed to be used for tracking. The GPS receives signals from Global Positioning Satellites and then uses those signals to calculate its current location, which it displays on the screen. However that data is not normally sent anywhere externally so there is no way for a remote user to determine where the GPS is.. Thus you cannot use a computer or any other device to track the GPS.
The Navigon 5100 appears to be no exception.
Without pairing the GPS with an external communications device (cell phone, two-way radio, laptop with a WiFi connection, etc.) the GPS lacks the ability to transmit its location reports to any external source. There certainly are ways that a GPS can be used with an external communications device as a tracker, but most GPS receivers do not have this capability out of the box.
Best Regards,
Ken
"Go Ahead. Use Us."
Jul 07, 2008 | Panasonic Navigon 5100
Computers & Internet Logo
David Payne
David Payne
