Question about GE Hotpoint Top-Freezer Refrigerator
I have a hotpoint refrigerator, model number HTS17GSERWW. It was a noisy appliance from very beginning. For last 2 weeks the noise has gotten very loud, it is inside the freezer compartment - when I open the freezer door it is louder. If I hit or tap on the rear panel inside the freezer, it goes away for some time but then comes back on. My guess would be that it is the fan - there is no ice build up inside the freezer. Any ideas? How to go about troubleshooting the problem?
    President:
  • 1,218 Answers
Good day,
The only moving part in the freezer is the fan motor. Unless the fan blade broke one of it's blades you will need to replace the motor with a new one. They are not repairable. At the same time buy a new blade as well, since an out of balance blade could have started this problem.
To access the motor, remove the ice maker, if it has one (3 screws and an electrical plug. The cube tray holder if not).
Remove the screws from the back panel, and remove the panel.
The motor change is a straight nuts and bolts job and fairly easy.
Any decent sized appliance parts house will carry the motor and blade. Take the model number with you.
Posted on Aug 05, 2010
Testimonial: "Solid, simple instructions. Will try the solution and will provide feedback on success."
Hotpoint wdpg8640 very noisy on fast spin, noise has increased in the last week. Should I be concerned?
yes very concerned it could be a loose weight or bearings failed both need attention asap.
Jun 26, 2014 | Hotpoint Aquarius WD640 Front Load...
Noisy Whirlpool WRN28RWG6 Refrigerator
Tom J, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (Tom J), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 19, 2017 | Whirlpool Refrigerators
I have a GE Hotpoint side by side Model HSM25GF7A Serial # VL224529 It is making a loud squealing noise whenever it is running. It also seems to not be cooling as cold as it usually does? I took the...
The noise i suspect is coming from one of the 2 fans...if you hear the noise coming from inside the freezer it will be that fan thats noisy and if from down by the compressor that will the fan thats noisy. the part numbers for the fans are
fan in the freezer (evaprator fan) WR60X10185
fan by the compressor (condenser fan) WR60X10220
They could be purchased from your local appliance parts store or online at,
searspartsdirect.com
apdepot.com
repairclinic.com
apwagner.com
partselect.com
GENE
Sep 07, 2011 | Hotpoint (HSM25IFTSA) Side by Side...
Noisy side by side hot point. It has been keeping us up at night. Repair man says nothing wrong. It was not this loud when new three years ago. Any thoughts? Model # HSM25GFTA
Often the noise is the condenser fan underneath the frdge... the bearings get worn and then the fan starts to make a horrible racket...see if you can pin the noise down to that and then order a repalcement...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 08, 2010 | Hotpoint HSS25GFP Side by Side...
Loud buzzing/rumble when running
Try this website "appliance partspros.com" You enter your model numer and the have compete breakdowns with pistures and how too instructions. the best part is if you join the websites blog......there you ask questions and an expert appliance reapir person sends you a reply. I have used the website for a few years and have never been steered wrong.
Jul 22, 2009 | GE Profile PFSF6PK Bottom Freezer French...
Grinding noise about 30 seconds after starting
Sounds like starter isn't disengaging, get that checked pronto, you could be damaging the flywheel (very expensive). Could be any appliance also; a/c compressor, idler pully, alternator, etc. Don't wait.
Jun 10, 2009 | 2007 Dodge Charger SRT8 Sedan
Hotpoint CDT00G Very Noisy
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Mar 16, 2009 | Hotpoint NBXR463EBWW Electric Dryer
Hotpoint Superplus 7822 dishwasher
At the beginning of the cycle the dishwasher is attempting to pump out any residue water in the waste pipe and sump. It could be that the motor is sticking but you would probably also suffer from it not draining properly.
It may just be noisy pump. I have a similar model and it is also quite noisy but nothing extraordinary.
When the dishwasher is pumping out at the end of the washing cycle it may be quieter when there is water in the pump/pipes but then gets noisy as it 'pumps air'.
Jan 29, 2008 | Hotpoint 23 in. BFI62 Built-in Dishwasher
Noisy compressor
Is a Hotpoint refrig?? Ge (who makes hotpoint) is having trouble with the freezer fan howling. Check out posts on Ge SxS PSS models. Some say its the main board, i disagree.
Dec 02, 2007 | Hotpoint HSM25GFRSA
Refrigerators Logo
143 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
