Question about Sanyo DS24424 24" TV
Sanyo DS24424 Menu Screen only offer the following items to adjust Audio Picture/Sound Antenna CH Search CH Scan Memory Aspect Ratio Menu Language There is no caption option on any of the above.
  • 2,322 Answers
The only way to do it will be using the original remote.
Click here to find the original remote control.
Good Luck.
Posted on Apr 30, 2008
The picture is in the middle of the screen on my sanyo tv. Is the tv playing out or can I fix it?
could be or the aspect ratio has changed
get the on screen menu up and find the scree aspect ration using the volume buttons adjust till the picture is full screen with the figures the right size( not tall and skinny or short and fat)-- ok then exit
Jun 09, 2016 | Sanyo Televison & Video
How do I set the picture to fit the screen
Go into Settings and adjust the aspect ratio. It will be one of the icons along the top of the screen after you press menu or settings.
Dec 01, 2015 | Sanyo Televison & Video
Is there a way to adjust the picture size? On some channels the picture is cropped at the bottom.
this is an aspect ratio problem ans is corrected /adjusted on the on screen menu
use the remote to achieve the on screen menu and scroll around until you find aspect ratio
use the volume buttons to select and adjust
Apr 27, 2015 | Sony 40" FD Trinitron WEGA XBR Hi-Scan TV...
Ilo tv in spanish need english
To change the menu language of the TV using the remote:
Display the menu screen.
• Press [MENU].
6 menu items will be displayed. The third item will be ENG/ESP/FRA
Select "ENG/ESP/FRA".
• Using [CH up / CH down] buttons, select "[ENG]/ESP/FRA".
Every time you press [VOL up / VOL down] buttons, the language
will be advance to the next. Select the language. When ENG is selected, exit by pressing [MENU]
If you are trying to change the AUDIO of the TV, simply press the [AUDIO] button on the remote. This will advance the selection between MAIN, SAP and MONO. MAIN is the native language of the program (often in stereo), SAP is "secondary audio program" - which is usually a second language, but may be an audio source not related to the picture at all. MONO is monophonic, or a single sound source that is the result of combining the LEFT and RIGHT stereo channels to one output or speaker. This selection is often a downgraded version of the stereo output provided by the MAIN audio selection - but may be useful under certain conditions.
You can review your manual here. Pg. 31 has details for the menu display language selection and pg. 16 has details for audio language selection.
If you found my answer to be helpful, please rate it "very helpful" Thanks & good luck!
Aug 22, 2011 | iLO IWT3206 TV
Adjust resolution on lumix dmc-tz3
Select PICT.SIZE from the REC menu. Depending on the aspect ratio, you can choose from 0.3MP to 7MP. For full details, refer to the "Using REC menu" in the manual (page 52 in my copy).
Jul 09, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
I cannot change the aspect ratio on the TV. When I go to the menu, Aspect Ratio is in red and I cannot select it. On certain channels the screen is too big and I can't see the edges of the broadcatsed...
This is a quote of what Sanyo told me: "The aspect ratio can only be changed when the unit is in the video mode." So I tried switching modes with the input button and it worked but went to like a letter box/wide screen type of picture, which doesn't help me. We have dishnetwork and on the Panasonic plasma we can adjust the ratio with their remote so I have two options there but not with my Sanyo unfortunately. Hope this helps
Jul 22, 2009 | Sanyo DS24425 24" TV
Sanyo Flat screen
try to check the settings of your tv if all ok. if ok its a problem in your TV circuit board try to resolder maybe some sections is cold solder. if not its a service mode. trust me!
May 20, 2009 | Sanyo DP26648-R 26 in. LCD TV
Grey Screen
Try the reset on the remote. Press this key twice to restore factory settings. The TV will automatically start Channel Search and clear all customized settings. These features will automatically reset: ? Picture/Sound Adjustments: Color, Tint, Contrast, Brightness, Sharpness, Color Enhancer, Tone, and Surround Sound ? Channel Memory ? Audio to Stereo ? Caption to OFF ? V-Guide to OFF ? Aspect Ratio to 4:3 (normal) ? Menu Language to English ? Sleep Timer (if previously set) ? Video to TV (if previously set) If desired, personal settings can be made again using the menu options
Jun 23, 2007 | Sanyo DS32224 TV
Aspect ratio
You may have a vertical circuit problem causing the picture to stretch out. This is called "over scan". You need to have a tech check it for you. Stargazer
Apr 19, 2007 | Sanyo DS24425 24" TV
TV screen on video 2 and remote died
The only way your going to change the video mode is with the original remote. If you need another remote go to http://remotes.com or call 1800 remotes Theres a button on the upper left hand side of the remote called video mode. A universal most of the time will not work this function. You could ask around to your friends and buddies or relitives if anyone has a working Sanyo remote or go to a local retailer that sells Sanyo and see if he would let you borrow one for a little while so you can switch out of the video mode. Good Luck
Aug 20, 2006 | Sanyo DS27800 27" TV
Sanyo DS24424 24" TV Logo
121 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
