Printer does not work. - Office Equipment & Supplies
    Genius:
  • 3,422 Answers
HI,
Can you please give more details on your problem so that i can help you fix it?
Waiting for your reply
Posted on Apr 26, 2008
  • 4,102 Answers
Hi what make and model is it
  • paul proctor Apr 26, 2008
    Has the printer been working uptill now or is it new printer?
    Do you have the software that came with the printer?
    Get back to me then i can assist you further ok but need make and model number please
    Hi the best thing to try first is check the lead from printer to comp is fitted properly then if the printer has cd that came with it then reinstall this and should solve your problem.
    We need more info regarding your problem as i cant tell if its software problem or actual fault with the printer please clarify and let us also know make and model please then i can assist you further.
    If the problem is when you select print then it gives error or dont print then when the print box opens up check your printer is the one in the name of printer make sure your computer know what printer is installed as this can cause the problem your having.
    Please get back to us then we can assist you further ok
Why has PIXMA MX410 printer stopped working? Re-installed Canon PIXMA MX410 All-In-One Printer on hp pavilion 23 widow 8 x 64, system would only print but menu solutions would not. Then printer stoppe
Driver issue. Uninstall and reinstall driver for win 8 64 bit - should work if same worked before. Did you try a system restore to time when printer was working properly?
Sep 11, 2017 | Canon Office Equipment & Supplies
Printer stopped working
Please check it power cable or power board, if power section ok or working.
Then check you printer connection or not.
Check printer cartridge shot or not detect.
Check it printer head, if header not working then not print coming.
Check it your printer driver installed or not, if installed may be some problems then your printer not working. So old driver delete or new driver installed.
If other issue please tell you.
I hope solved your issues.
Thanks,
HP Printer Problems
Jun 18, 2014 | Brother HL-2040 Laser Printer
Working printer will now not be detected windows xp
Do you have the correct XP driver for the Printer? If yes check that the cable that connects the printer to your system is not damaged. If you have another working system near by you can connect the printer to the system and confirm the printer is working. If the printer is still not working, the printer port may be bad either on the system or on the printer. In this case you need a technician to help you confirm which is the faulty one.
Jun 07, 2012 | HP LaserJet 4 plus Printer
My HP Printer no longer works on my laptop. What
you did not provided any useful information, what operating system you use, what printer, what connection (usb, paralel, network) and what laptop.
general advice only can be provided then.
if windows of any flavour, disconnect the printer, uninstall all software pertaining to this printer. use ccleaner and clean your harddrive including registry.
check printer on another computer if it works. if printer works correctly, problem is with your laptop, not with printer.
follow this procedure, install software, connect printer, switch printer on, windows will automaticaly install drivers and printer software
if this do not work, you need to check if port used for printer work with other hardware, ie, usb stick, check cable between printer and relevant port.
Jul 20, 2010 | HP Computers & Internet
Printer won't resond to command from computer
restart both printer and computer then report back if any changes
Nov 25, 2009 | Konica Minolta PagePro 1350W Laser Printer
Printer will not work with new computor
Be sure that your printer is compatible with your new computer
You have to install the printer on the new computer in order to get your printer working
Run the installation CD or download the printer program from the internet.
If you already have your printer installed and it is not working
Try doing this
disconnect printer from computer
cancel documents in queue
if using a straight USB connection, delete all instances of printer. else remove duplicate printer icons.
reboot & reconnect printer (swap cables if not detected)
Nov 06, 2008 | Computers & Internet
Flashing lights
the printer when i on the swich the flashing light is on but can't work the printer
Feb 24, 2008 | Epson STYLUS CX3900 All-In-One InkJet...
24 people viewed this question
jasbo
jasbo
