Question about Polaris Pb4 - 60 Booster Pump
Polaris 280 booster pump runs for 30 seconds then trips the safety switch.
    Top Expert:
  • Polaris Master
  • 8,915 Answers
Motor overheating replace pump
Posted on May 22, 2016
SOURCE: looking for wiring instructions for the
The diagram on the side of the pump shows how it sould be wired for low volatge. I'm having a problem wiring for high volatge and posted the diagram. Use the link to access.
http://www.poolspaforum.com/forum/index.php?showtopic=19400
Posted on Apr 29, 2009
john224
  • 1378 Answers
SOURCE: polaris booster pump overheats and trips the breaker
The motor may be repairable. Check with local electric motor repair shops in your area. The motor may need to be replaced though and if so, we sell it at www.arrowmotor.net
Posted on Jun 14, 2009
  • 1114 Answers
SOURCE: Pump comes on for about a minute...then shuts off..
Has this pump worked at all -pumped water?
When it's running for about a minute, is it pumping water?
Is this a self priming pump or do you need to prime it?
Posted on Jun 28, 2009
  • 1114 Answers
SOURCE: polaris booster pump turns on for about 3 seconds.
That click you hear is the pump's breaker, or thermal overload kicking in. After about one minute, the pump has cooled down again.
I believe this type of pump is not self-priming, and therefore, it needs to be primed and purged of air. If it is not a self priming pump, there should be a small plug on top of the pump housing. Remove the plug, and add water from the top opening until the water overflows, and then replace the plug. Or, if when you remove the plug, water comes out the top opening, let it flow for a few seconds, and then replace the plug.Then, turn the pump on.
Hope this was helpful...
john224
  • 1378 Answers
SOURCE: polaris booster pump runs for minute but quits. Tries to restart
The motors are usually dual voltage and factory connected for 230V. Are you sure it is properly wired and set for the correct incoming line voltage?
Posted on Aug 24, 2009
Polaris 280 wheels running but not picking up leaves
check side filter at connection if clean check inside Polaris to see if hoses came off
Apr 16, 2013 | Polaris 280 In - Ground Pool Cleaner with...
Polaris pump turns on 10 seconds and then off then on and off
check wiring 220 vs 110 volt see side of motor for schematic check voltage first
Aug 04, 2012 | Polaris 280 In - Ground Pool Cleaner with...
Why is my polaris 280 booster pump is revving much faster than usual?
Thank you for posting your question here on Fixya.com.
The booster pump can not turn any faster than its nameplate speed. If you think it is revving up, it is probably because it is running louder and/or rougher than normal. The pump seal and/or bearings are becoming worn and will need servicing. A local electric motor repair shop should have the parts for you to buy or they could repair it for you. Often times a gasket will need to be replaced as well but all told the repair should be ~$100 or so.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Jan 09, 2010 | Polaris 280 In - Ground Pool Cleaner with...
I installed a booster pump. Attached a one ince
1. debris in the water management system (hoses inside the cleaner)
2. black gears in cleaner need replacing (360/380)
3. belt kit (polaris 360/380) or drive shaft need replacing (180/280)
4. teeth on inside of wheels are worn out (polaris 180/280 only)
Jul 16, 2009 | Polaris 380 In Ground Pool Cleaner
Polaris Pb4 - 60 Booster Pump Logo
144 people viewed this question
Top Polaris Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
David Spradling
David Spradling
Are you a Polaris Pool and Spa Expert? Answer questions, earn points and help others
