Question about Sharp Office Equipment & Supplies
I have a EL 9300 that has had the aaa Bateries removed for six years , And now with New batteries installed It won't power Up folling the start up steps in the Manual. Is there some trick to starting it up Rusty
4 Suggested Answers
  • 88 Answers
SOURCE: How can I revive my TI89 after two years of not using it?
It could be that you need to replace the backup battery located behind a little door with a screw in the battery compartment. If this doesn't work, try resetting your calculator by leaving backup and AAA batteries out for about 8 hours and reassembling it. Hopefulyy this will work. Good luck
Posted on Aug 06, 2009
  • 8073 Answers
SOURCE: Won t turn on
To answer the question you asked. No the backup battery does not affect the main batteries. It is there to keep the memory electrically refreshed when calculator is turned off. You will know that the backup is depleted or almost depleted if the screen displays RAM CLEARED, everytime you turn the calculator ON.
Now to the calculator not turning ON. IF THERE ARE NO HARWARE PROBLEMs with your calculator (of this I cannot judge for I am no prophet) , it may be that the screen is too light and you cannot see what it displays. If that is the case, you can darken it as follows.
1. Press [2nd] key and release it.
2. Press [ArrowUp] key and release it.
3. Repeat Steps 1 and 2 in sequence, until screen darkins enough. You may have to repeat the sequence several times.
Hope it helps.
Posted on Oct 14, 2009
  • 8073 Answers
SOURCE: Screen went blank replaced AAA batteries starts up
You may have to force the calculator to boot up. Details are in the article . Read the part on Ti83Plus family.
The article contains links to additional articles.
Hope it helps.
Posted on Oct 29, 2009
Sharp el 9300c
I took the EL-9300 apart to look for cold solder joints on the battery terminals. Found no bad connections. Make sure you remove all retaining screws.
Cleaned the pc board under the reset button. Cleaned the board under the slide switch that is actuated by the metal battery hold down clip. When you go to turn on the calculator install the hold down clip because it makes a connection to the pc board.
When I pushed the "On" button I got a down arrow. Push the "Reset" button when you get the down arrow. Various menus came up and I managed to reset the calculator.
Jun 06, 2013 | Office Equipment & Supplies
New Bushnell Backtrack won't turn on.
I have the same problem with my Backtrack. I unlock back battery cover, unscrew some screws. Then I take the screen, check connection - it's ok. Then I try to close power switch with screwdriver. It started, but doesnt worked. There are some symbols on the screen. It's all I can do. My BackTrack still won't worked. For comments: greenspot@mail.ru
May 28, 2012 | Bushnell BackTrack Handheld GPS Receiver
My ti 83 will turn on when i press the clear thing but when i try to put something in nothing happens
Hi imagenius1,
You need to free up some memory. Try clearing your RAM memory. Your calculator should operate properly afterward.
Press [2nd] [MEM] [7] [1] [2]
If the steps above did not reset the memory to your Ti 83 family calculator try the procedures below.
Please be prepared to re-install the calculator's OS if you run through this process.
If you have a straight Ti 83 without the Plus or, Silver Edition label goto (Procedure 2) below. If your Ti calculator is a Ti 83 Plus or better goto (Procedure 1).
(Procedure 1).
  1. Try a new set of AAA batteries.
  2. Remove one of the AAA batteries. Press and hold the [CLEAR] key. While holding [CLEAR], reinsert the AAA battery and then turn the calculator on. The calculator should display the message "RAM Cleared". Release the [CLEAR] key and, then press [CLEAR] one more time to remove the message.
  1. Remove one of the AAA batteries. Press and hold the [DEL] key. While holding [DEL], reinsert the AAA battery and then turn the calculator on. The calculator should display "Waiting...Please install calculator software now". Follow the instructions for the TI-83 family or TI-84 Plus family to reinstall the calculator operating system.
  2. Steps to re-installing the operating system:
    ~Connect the TI Connectivity cable between the PC and the calculator.
    ~Click on Start >> Programs >> TI Tools >> TI Connect >> TI OSDownloader
    ~Follow the on-screen directions to reinstall the calculator's OS. If you could not install the new OS on your calculator goto step 4.
  3. Remove all of the batteries including the round lithium battery for 5 minutes. After the 5 minute period, reinsert all of the batteries and turn the calculator on. Adjust the contrast if necessary.
  4. If the above process did not reset your calculator. Try re-doing (Procedure 1) and, extend the time in step 4, by 5 minutes to 10 minutes before you put all the batteries back in the calculator.
(Procedure 2).
For a straight Ti 83 without the Plus or, Silver Edition label try the procedure below.
  2. Remove one of the AAA batteries. Press and hold the [ON] key for 20 seconds. Reinsert the AAA battery and then turn the calculator on.
Jan 06, 2011 | Texas Instruments TI-83 Plus Calculator
I have a Hitchi Radio/CVD player KC-92CD and I don't know what batteries I need for the remotre
Take out the batteries and check?Very small long tube battery kind?That the AAA kind of bateries.Long tube battery kind?That the AA kind of bateries.Square battery kind?That the 9 Voltage batteries kind.
Oct 21, 2010 | Hitachi Televison & Video
How do you install new batteries in my Kensington PocketMouse 72214
i have the mini m. for awile want to install in another notebook dont remenber how> helpppp
Sep 23, 2010 | Kensington PocketMouse 72214
1997 chevy blazer s10 cranks but wont start
You have a new battery and it cranks. Turning over is cranking. You are saying it won't start after sitting for six months? What is an old mechanic? Was the cable installed at home during the one year layoff? It sounds as though you failed to hold the old mechanic responsible for installing the correct cable or adjusting the one you have ,so it will start. You have a safety switch issue by the sound of it. Make sure you have the right cable and then find out how to install and if applicable,adjust properly
Feb 07, 2010 | 1997 Chevrolet Blazer
Acer aspire 9300 notebook black screen while in use
If there is power beside you,why not connect you laptop to the family power,it will be good to your acer aspire 9300 battery life .Pay attention to your acer aspire 9300 laptop have been 2 years old,i think it most properly some problem to your acer aspire 9300 battery.
Sep 24, 2009 | Acer Aspire 9300 Notebook
Jul 29, 2009 | Texas Instruments TI-89 Calculator
Acer 9300 bios upgrade failed
Hi!
I have the same problem, and my problem was that I have installed 4GB ram and that ram modules wasn't accepted with the new bios. So I installed the old modules and it all worked again, downgraded the bios to one version older and installed my 4GB ram modules and it all worked.
Hope that's your problem too.
Good luck
Feb 14, 2009 | Acer Aspire 9300 Notebook
I bought a motorola Talkabout, a set of three, and only got 2 batteries.
I put three AAA bateries in it! I still think you should include batteries when you sell a product with rechargeable batteries that you can't buy anywhere!!!! So I wont be able to recharge the regular AAA batteries. Yeah I am still burning over the problem.!!!
Jul 29, 2008 | Motorola Cell Phones
553 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
