Question about Dryers
The dryer turns on and tumbles but the hear is so low it takes 2 hours to dry
  • 5,911 Answers
If your dryer is STILL heating, but your clothes still won't dry, you may want to check the dryer interior cabinet and/or the entire run of the exhaust ducting from where it exits your dryer to the point where it leaves your home to ensure you have no kinks or clogs. The following link explains many of the common problems that can cause poor drying efficiency and longer dry times:
http://www.fixya.com/support/r3578821-dryer_takes_too_long_to_dry
Before assuming you have a problem with the appliance, check your installation to ensure you are providing the dryer with proper exhaust and air flow. This is the NUMBER ONE cause of poor drying efficiency. A dryer in a clogged state or having improper air flow will not dry efficiently and will cause the heating circuits to overheat. Eventually, this can lead to component failures and is the source of many fire hazards. If you have any questions, or if you have already checked the dryer ventilation, please post back with a complete MODEL NUMBER and let me know. I hope you find this information helpful.
Posted on Aug 05, 2010
Dum turns to fast for cloths to tumble, 2 hrs. to dry!!
don't know about the drum turning to fast, but the two hours to dry I do know. Disconnect the vent tube and dry a load of clothes, as there is a restriction in your vent tube. You will need to clean the tube out with a vacuum or leaf blower, you may want to clean the inside of the dryer out,also. Good Luck Tim
Jan 06, 2011 | Maytag Neptune MDG9700A Gas Dryer
Model SDG305DAWW, gas unit...begins to dry and then stops...timer stops and unit continues to tumble but no heat...turn unit off and wait for about 2 hours then can dry again....replaced cycle timer,...
Sounds like you have the same problem I did. You need to replace the flame sensor. Takes about 15 - 30 minutes. You can order the part online here
Feb 06, 2010 | Maytag Dryers
Wed9200sq0 heats, tumbles but does not dry at any heat setting
You are correct. Pull the dryer out and disconnect your venting from the back of the dryer. Turn your dryer on and check to make sure your dryer is blowing air out of the dryer duct. If it is then leave your dryer out at least 2 ft from the wall and run a load of clothes through the dryer. If it dries your clothes normally then you have a venting restriction. Check to make sure your venting is clean, not kinked or smashed, make sure your outside vent is opening an doesn.t have something blocking it. Check your lint screen filter by running water through it. If water is not flowing through it, you have a build up of fabric softener on your screen, blocking air flow. Scrub your screen off and test again. Good Luck, Appliance Specialists
Dec 30, 2009 | Whirlpool WED9200SQ Electric Dryer
I have a neptune drying center and it's taking 3 hours to dry
Check the exhaust duct again. There must be a blockage, a kink, or a disconnected vent pipe.
May 03, 2009 | Maytag Neptune MCE8000AY Electric Dryer
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
Tumble dry is heating but takes forever to dry
check your air exhaust (including the lint filter) from the air duct connector (remove duct if necessary) on back of dryer to the exterior of the building. Somewhere, there must be air blockage.
Jun 17, 2007 | Creda IWD12 Front Load Washer / Dryer
Dryers Logo
Top Dryers Experts
Marvin
Marvin
