The asio4all v2 has solved my problems with my previous driever (ASIO DirectX Full Duplex Driver) that was given me problems with patchy sound and drop outs... but now when i try and record through my alesis i02 express, it isnt registering in cubase. i checked my VST setup for input and output, and the only choice i am given is realtek hd audio. it means i can playback tunes i managed to record previously, but it plays throug my speakes. wiht my interface plugged in i can hear my guitar thourhg my headphones, but it doesnt register on cubase. is there a way to have both? using the interface to record in and using my pc speakers to playback? thanks
  • 10 Answers
SOURCE: Nature of Problem:Realtek HD Driver Instllation failure
see first the auido file is playing or not. if it plays then it is the problem of hardware due to power supply it may not audioable connect near by hardware engg
or else ask me on ramu4all31@gmail.com
if u cannot play it. it will shown that audio drivers are not present an atlernet way of installing is by downloading driver detect and finding the correct drivers form internet so that u can download it
try to install in background mode by typeing the a statement cmd in command prompt by opening the filename.exe /s
or else update the drivers from intermet
Posted on Mar 15, 2008
SOURCE: Realtek HD Audio Troubleshhooting?
calulator is deleted
Posted on May 21, 2008
  • 3 Answers
SOURCE: No sound in playback (but can hear click track)
This might seem simple, but just to check: you have switched off the monitor on the track when you go to playback? With track monitor engaged, you will not hear playback, but will continue to hear the live monitor.
Posted on Oct 19, 2008
SOURCE: Low Sound for my laptop - Windows vista, Realtek HD Audio Manager
Try Start>Control Panel>Hardware and Sound>Sound>double click on Speaker icon>Enhamcements tab>tick the Loundness Equalisation box.
Posted on May 09, 2009
drunknmonkey
  • 136 Answers
SOURCE: I have an M-Audio Producer
Is your mic 1 or 2 channel? If it's two then make sure your settings allow that, if not then maybe something else is getting in the way, so check any audio devices connected to your computer and which inputs/outputs, and try to trace the connection to the inputs/outputs in fl studio, you'll probably find something simple and easily overlooked somewhere. It definitely sounds like it's a setup issue rather than something not working.
I'm not an expert with this stuff, just have an interest in recording (mainly because I play guitar), and haven't used fl studio in a while and even then not very much. I use Linux now instead of windows and so I use other programs and at the moment don't even use asio, although I have and I had similar problems, just needed to learn how to use it properly (in my case) and how to trace faults in the software connections.
Sorry if I'm not much help and I hope ya get it sorted asap.
Posted on Feb 26, 2011
When I record with my m-audio mobile pre USB, there is no latency issues with recording but there is a delay in the headphones if I turn them up to hear myself while recording. How do I fix this? I'm using...
Have a read at this article. I assume you are using ASIO4ALL if not then you should.
http://www.image-line.com/support/FLHelp/html/recording_audio_USBmic.htm
Specifically this part:
Note about latency: USB microphones generally only allow you to hear the sound being recorded after it has passed through FL Studio. As the latency of USB microphones depends on the ASIO4ALL latency settings, there may be a troublesome delay between the sound made and it being reproduced from your speakers or headphones. For example, low latency monitoring is particularly important to vocalists as high latencies cause a distracting echo effect. The only solution to this problem is to lower your buffer length settings (there are limits) or obtain a new soundcard with direct-monitoring.
Feb 15, 2015 | M-Audio Computers & Internet
Reason software can it produce sound without the internet
Reason Software produces sound through your computers sound card & speakers, but your system must meet the minimal system requirements listed below:
Mac OS X
Core Audio compliant audio interface or built-in audio hardware
Windows
Audio Interface with ASIO driver
Instructions to install ASIO driver if required:
download installer from this link:
http://tippach.business.t-online.de/asio4all/downloads_11/ASIO4ALL_2_11_English.exe
double click the installer & follow instructions, please ensure you restart your computer after installation.
Jul 14, 2014 | Propellerhead Reason 5 Educational Version...
ASIO driver for xp
If you're not using ASIO4All then do, if you are getting a time out on the download the problem is with the site or your ISP most likely. Try another site.
Nov 17, 2013 | Behringer Ucg102 Guitar Link USB Audio...
I have an error message that says: Error wile trying to synchronize Audio and MIDI Sample Rate 38441 reciognized. Check conflict between GarageBand and external device. Any suggestions?
what you need is a "FULL DUPLEX ASIO DRIVE",which you get with programs like cubase sx, this is like a universal driver which has always synced any audio equipment i've hooked up to my computer, internal & external.make sure it's the full duplex & not the asio4all v2.
But really you shouldn't be having much trouble if your using a USB midi interface.unless your computers sound card is ****.
try resetting the sound cards sample rate to 44100HZ which is the standard rate for most audio,or 48000HZ for digital.
May 16, 2011 | Tascam US122 Audio/MIDI Interface with...
I've got a new Blue Snowball mike that worked great out of the box, but now, a week later, it just gets a "device not recognized" message when I plug it in. I've tried rebooting, and...
I had the same problem with my PC and went to http://www.asio4all.com/ where I downloaded and installed the driver and it worked!! I found the site by reading this FAQ (see below) at Blue under Snowball.
(But I still have the same problem with my MAC).
"If you should experience any problems getting the program to recognize the mic, Adobe recommends the following: If the device does not allow you to record, then your microphone is not being detected as a valid input device in Premiere Elements. You can use an open source program called ASIO4ALL, which is a device driver that essentially wraps existing WDM devices, like USB microphones, as ASIO-compatible sound devices. Use the following steps to utilize this tool:
  1. Quit Premiere Elements.
  2. Visit the following web page and download the latest available version of ASIO4ALL: http://www.asio4all.com/
  3. Install the software, and restart the system if asked to do so by the installer.
  4. Make certain that your microphone is plugged in.
  5. Launch Premiere Elements. Go to the 'Edit->Preferences..>Audio Hardware' menu option. For the Default Device, choose the ASIO4ALL option. Click the ASIO Settings button, then select your microphone from the list of devices, click Exit, and then click OK on the Preferences dialog. Close and then restart Premiere Elements."
Dec 28, 2010 | Blue Microphones Snowball Professional...
ASIO Driver give chopper sound in fl studio
You might wanna try to increase the ASIO buffer size (perhaps a lot) ...
And if that doesn't help, you might wanna try the www.asio4all.com driver
Jan 03, 2009 | ASUS Intel 440LX Chipset P2L97-DS...
Not soppot asio in fl studio
Try a different ASIO driver. I would say that the sound card that you are using does not come with an ASIO driver so the software can't use the card correctly. I recommend ASIO4ALL. It is free to download and works with almost all soundcards and audio devices in Windows. You can get it from www.asio4all.com.
Best of luck.
Cheers
Dec 30, 2008 | Creative Labs Ensoniq ES1371 Sound Card
It says I can not record pick the asio duplex but i don't know how
What recording software are you using? What version of Windows are you on? The ASIO driver for the Lambda should have been installed when you loaded the software that it came with, and if so there should be a control panel that will allow you to select that. The other option is to use ASIO4ALL. It is a free ASIO driver that works really well for most sound cards and software instruments and recording software like Cubase, Nuendo or the many other programmes out there.
If you need more help let me know.
Cheers.
Dec 22, 2008 | Lexicon Lambda Usb Desktop Recording...
Just get clean tone through NI Rig Kontrol 2
you need an asio driver for your rig kontrol.. you are probably set to use DirectX drivers, which will give you latency of 50ms and waaaayy beyond... By contrast, ASIO drivers will give you sub-10ms latency... Most people can play at around 7ms, but im picky, and no more than 5ms will do for me..
Go download the drivers from NI site, and try those.. if that doesnt work, there is ASIO4ALL... google and read.,. this will help ya
keep playin
DJYoshaBYD
Sep 29, 2008 | Native Instruments GUITAR RIG
Computers & Internet Logo
66 people viewed this question
David Payne
David Payne
