Question about Hitachi 43FDX01B TV
Screen has gone dark good sound, suspect lens need cleaning or lamp needs replacing. how do i take the front panel off to get to the lens. that is how the tech did it the last time, can't afford repair call. greatmaw
    Problem Solver:
  • 4 Answers
To remove the front panel, there are 2 screws on each side of the lower gray panel that need removed, than, behind that, there is a wood panel with 6 screws that needs to be removed. I just pulled mine off last night actually!
Posted on Aug 18, 2010
This is an LCD tv . Toshiba 40xv648u .Audio is good screen is dark. was taking longer and longer to come on.
Since the picture died slowly i suspect a capacitor on the powersupply board,if the screen flashes then goes black and sound is ok
could be the inverter board that drives the lamps.
Len..
Feb 28, 2014 | LG Televison & Video
I have a 65 inch syntax brillian TV. The picture is pretty dark, and I'd like to clean the mirrors and lenses. How do I do that?
Shannon, cleaning the mirror or the lens will only drgrade the picture that's reflected onto the screen. A dark picture is most likely caused by the ~300 watt lamp aging and now needs replacement. You can confirm this for yourself by removing the lamp from behind the right hand speaker door and looking at the bulb-shape at the inside, bottom of the reflector. The bulb should be clear, with maybe a small white patch on the top of the inside of the electrod chamber. If it's a large white patch, or the chamber has any black, or even worse has a deformed chamber, the lamp only needs to be replaced.
I did the longevity testing for the 65" TV's. No other component caused the TV to 'darken' as you state....
Jun 19, 2011 | Syntax-Brillian 247T FHD 47 in. LCD TV
Two thirds of the picture has gone dark on 42lg5000-za tv
The problem actually is from a lamp in the unit, it is getting damaged gradually that is why it is two third of the screen that has gone dark. once it gets completely damaged, the entire screen will turn dark.
Try to ***** the lamp of the television and replace it with a new one.
After doing that your television will be in good condition once again.
Take care and good luck
Oct 23, 2010 | LG Televison & Video
Mitsubishi wd 62527 has very dark picture changed
Clean the small front projection mirror. That mirror can get dust on it and will cause the projected image to appear dull and dim and cleaning that mirror will usually restore the brightness and crisp details in the image.
Oct 20, 2010 | Mitsubishi WD-62725 62" Rear Projection...
Sony KDF-E50A10/4 dark picture
Dark picture is indication that tv needs new lamp.
Replace lamp in tv get bright picture, please buy Sony original lamp for good picture in tv.
Jun 17, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
How do you know when the lamp is gone on a Sony LCD Projection TV??
The lamp indicator on the front of the TV flashes when the lamp is busted and must be replaced in that case. The lamp must replaced too if the screen becomes dark or the color looks unusual.
Feel free to tell me if you need guidance in replacing the lamp. Just give me the model.
Dec 03, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Mitsubishi WD-62527 replacement lamp install and brightness low
as i previously posted, my picture was dim, muddy looking after replacing lamp with osram lamp. i fixed mine by taking the screen off and cleaning the small mirror. it had a thick layer of dust on it, cleaned with a microfiber cloth. no water, no glass cleaners. i also used a very fine new small paint brush and dusted the projector lens which also had a dust film. brightness, contrast and clarity returned!
Dec 23, 2008 | Mitsubishi WD-62725 62" Rear Projection...
Discoloration
I don't think you are posting about a LCD flat panel set, since replacing he lamp on these means replacing the panel.. If this is a rear projection set as I suspect it is, there are two likely causes.
1) Pull the lamp back out and clean the dispersion lens/UV filter immediately behind where the lamp goes. Clean it carefully, because it is easy to damage.
2) You have a bad optical block
Jun 28, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Sony KDF-E42A10 Screen is Not Bright
try a lamp first, through best buy their about $150 -250. If that fails it might be the optic block assembly which is about $1,000, and i just recently had replaced, and the picture is as bright and clear as when i got it two and half years ago
Sep 01, 2007 | Sony KDF-E42A10 42 in. LCD Television
Hitachi 43FDX01B TV Logo
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
