Question about Archos TV Plus, 80GB 80 GB Hard Drive
Archor tv plus 250G
My archos tv will not switch on red light just blinks.
  • rewa6 Feb 05, 2009
    My archos tv will not switch on red light just blinks.try to reset nothing is changing
Have you tried the reset button, if that dosent work unplug it and try resetting again
Posted on Aug 19, 2008
Archos tv+ doesn't boot, contantly(steadily) blinking. Can anybody help?
Hi, I had the same problem, no booting but only blinking red LEDs. I noticed the harddisk wasn't making any sound that it was working. I changed the original power supply adaptor (12v) with one producing 15v output voltage. And it's working again.
Dec 25, 2012 | Archos TV Plus, 80GB 80 GB Hard Drive
Archos 5 not working, will not switch on.
Hi I would think the best place to start is with ARCHOS,
give them the lowdown and see what they come up with.
You could use the Archos forum and look through the help files
Apr 13, 2010 | Archos 5 MP3 Player
Archos tv+ has constant red blinking light. Froze
I know this was a while ago, but just in case you never fixed it, or someone else needs help with the same problem, here's a possible solution. I had this same problem recently, but didn't realise it was thanks to Archos's latest firmware being dodgy. I actually took the hard drive out at one point, put it in my PC and backed up all the contents. In fact, you simply press the TV button on the remote when the red light is blinking quickly. That takes you to a recovery menu, where you can attempt to repair or format the drive. If you hook it up a PC via USB, you should also be able to access everything on it to back it up.
Anyway, the repair and format options will tell you to connect your device to a PC, but that's just to load a firmware file onto the hard drive. You can just as easily put this file on a USB pen drive, though, and load it from there. You can get firmware files from http://www.archos.com/support/support_tech/updates.html?country=gb&lang=en&#firm. The latest one is there, but ignore that and install the previous version. Hopefully, that should get the TV+ booting again. It worked for me, anyway.
Nov 15, 2009 | Archos TV+ DTV Receiver / Video Recorder
Red light flashes on power switch, but no picture or sound on tv
tv will not power on. red light on switch blinks. power relay clicks, but no picture or sound.
Jul 28, 2009 | Toshiba DVD Recorder AND Series2 TiVo...
Archos charging the battery takes too long
I found that I have to leave my archos 605 powered on to get a full charge out of it, blinking light and all
Jul 18, 2008 | Archos 605 WiFi Digital Media Player
Kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Feb 13, 2008 | Sony Grand WEGA KDF-60XBR950 60" Rear...
How do I get my Archos to work ont
if you are using an Archos cable, when you plug in to the tv, you should switch to the video 1 or line in source, probably using your tv remote labeled "input"
Dec 05, 2007 | Archos 504 500870 Digital Media Player
Archos 700
1. Connect the archos to the TV ( using the 3 leads red/yellow/white into the TV or DVD player) and the other end of the lad, a single jack into the back of the archos mini set-top box. Plug the single jack into the "RV Output". 2. Then start playing a movie on the archos. 3. Then press down on the flat silver button on the top of the archos device. Your screen should turn black/blank. This means your sending your movie to your TV. 4. Tune your TV to find the Archos movie in the same way you would tune your TV to find another pay TV set-top box ( like cable TV or Satelite). Problem solved.
You can use the same steps to send archos music to your steroe. Just plug the audio leads (white & red) into your stereo instead of your TV.
Oct 09, 2007 | Archos AV700 Digital Media Player
Archos TV Plus, 80GB 80 GB Hard Drive Logo
340 people viewed this question
Top Archos Computers & Internet Experts
fordexpert
Computer Links
Are you an Archos Computer and Internet Expert? Answer questions, earn points and help others
