Question about HP Photosmart C6180 All-In-One InkJet Printer
I have a Kodak ESP 9 All-IN-One-Printer. How do I remove the bottom tray to deal with a paper jam?
SOURCE: Paper jammed in printer - need to remove paper tray
1 This works from HP help link in error message:
Turn off the HP All-in-One.
2 Press in the tab on the rear door to release the door. Remove the door by pulling it away from the HP All-in-One. icon_caution_color.gif Caution Trying to clear a paper jam from the front of the HP All-in-One can damage the print mechanism. Always access and clear paper jams through the rear door.
Posted on Jul 29, 2008
  • 19 Answers
SOURCE: kodak easp 5 paper jam
Greetings Thurnwood,
Sorry to hear about your trouble.
First thing I would do is check the printer to be sure you have removed all packing tape, and that any supply space is clear. If there are more than one resource locations for paper, be sure you have them in their correct positions.
Unplug the printer from your computer, and turn off the power. Leave it off for a couple of minutes then turn it is on. Do not connect to the computer but insert some paper and try printing via the stand alone option. Make sure you have calibrated the printer and that the print head and ink are installed correctly.
If none of this works, please call our 800 421 6699 and our team will make sure you are printing in no time flat.
Good luck, I will be around to see how you make out.
Best Regards,
Ron Baird
the friendly Kodak guy
Posted on Sep 22, 2008
  • 7 Answers
SOURCE: hp m4345 printer tray 2 paper jam
Clean the rubber intake rollers with alcohol and allow to dry for 10 minutes. Take the tray out and you should be able to see the roller inside. Also check to make sure that the printer is default to tray 2. Use the Menu option on the LCD screen of the printer. Set the default tray to tray 2 in the windows driver as well. You should be able to easily get to this by hitting "ctrl+p" when you are ready to print a document.
Posted on Jun 12, 2009
  • 6 Answers
SOURCE: Cannot clear paper jam on L7580.
Ekse, with the L7580 AIO you need to unplug the printer hold down the # and6 along with the on off switch for about 45 seconds but at least 40 seconds release the bottons and reconnect the power cord.
Posted on Jul 06, 2009
  • 295 Answers
SOURCE: kodak printer esp.3 ...paper jammed
u should only use kodak inkjet papers with size plain paper, coated paper, photo paper, iron-on, transparency film, label media, greeting cards, 20 to 24 lb. plain paper. open back access door of printer by pulling out the latch on back of printer. remove paper-jam from the rollers. u can find manual for ur printer onwww.kodak.com/go/manuals.
Posted on Jul 28, 2009
How can I clear a paper jam on Kodak all in one printer?
www.kodak.com/go/aiosupport
Getting help on the Web
For more troubleshooting information:
Paper jam
• Check for paper in the rear-access cleanout area.
• Open the printer access door and gently remove any paper from inside the printer.
• Make sure the paper in the tray is free of tears or creases.
• Make sure you do not overload the paper tray.
For more information, go to
www.kodak.com/go/stepbystep
Jan 03, 2015 | Kodak ESP Office Equipment & Supplies
How do you remove paper that got jammed in printer? I can't seem to find any way to open the printer like I was able to do with my old printer.
Remove any loose paper in the loading tray.
Press the Resume button on the from of the printer.
If the paper jam is cleared, move to Ensure the printer carriage can move freely.
If not, continue to the next step.
Remove lodged paper one sheet at a time, starting in the middle.
Check for any remaining bits of paper.
If not, continue to the next section.
The best custom research paper writing service to learners across the globe
Nov 08, 2014 | Kodak ESP 9 All-In-One InkJet Printer
How do you open the rear door to fix a paper jam on a Kodak 5250 printer?
There are two plastic tips that you pinch inward at the lower back of the printer. A rectangular plastic piece will come out if you give it a god tug and you should be able to remove any jammed paper. I took mine off and never put it back on because it is aggravating to remove. I also had a problem of every 5-6 sheets of paper would not feed correctly through the printer and a paper jam notice would be displayed. I have all but remedied this too by stretching two heavy duty rubber band around the paper dispensing tray close to the bottom to provide more tension on the paper feeder itself. WORKS GREAT FOR ME! GOOD LUCK! Mine is a Kodak esp 3.2 but it paper jams a lot so maybe this will help you some as well?
Aug 09, 2014 | Kodak ESP Office Equipment & Supplies
Paper jammed - can you talk me through how to release from the rear of the printer
1 Remove the paper from the tray. 2 Turn off the printer. 3 Open the rear access area and pull the paper out from the rollers without tearing it.. 4 Reload the paper tray, but do not overfill it. 5 Turn the printer on. 6 Press OK.
Follow this link to download the manual http://www.kodak.com/global/plugins/acrobat/en/service/manuals/AiOPrinters/ESP-5AiOPrinterUG_EN.pdf
Aug 28, 2011 | Kodak ESP 5 Printer
My kodak All-in-one printer ESP9 goes instantly in paper jam. Checked for a paper jam and found no paper jam or any paper anywhere inside machine. Pressed down on "OK" button and printer...
Had same issue with my ESP 9, called up the kodak support lines and spoke to them over the phone, getting a replacement sent out free of charge and I've owned this for 1 year and 4 months and only had one prior printer jam which righted itself in the past. Seems like ESP 9's are prone to the unfixable printer jam.
Best bet call kodak and get it sorted.
Jan 12, 2011 | Kodak Office Equipment & Supplies
Paper jam
You are receiving this error message because there is a paper jam or the top (photo) tray is not securely in position and the printer cannot initialize. This error message can appear for an ESP 7, ESP 9, ESP 7250, or ESP 9250 all-in-one printer.
To resolve a paper jam, we have an easy Step-by-Step Solutions and Repair tool. Within the tool, select All-in-one printer, then Paper jam.
When you clear the paper jam:
  1. Make sure you open the paper output tray and inspect the top tray for photo paper that could be jammed inside or that remains in the nip at the entrance.
  2. Pull out the bottom paper tray and clear any paper jams.
  3. Remove the duplexer from the back of the printer and clear any paper jam.
NOTE: Curled photo paper could induce a paper jam. To prevent curling:
  • Store un-printed paper in a tightly closed plastic bag or in its original packaging.
  • Store sealed packages of paper flat, and not on
  • When you are ready to print, take only the paper intend to use immediately.
To remove curl in photo paper:
  1. Place the paper in a plastic bag or in its original packaging.
  2. Gently bend the paper in the opposite direction of the curl, then insert it into a tube-a paper towel tube works well.
    NOTE: The tube should be larger than 1.5 in. (4 cm) in diameter.
  3. After a few minutes, remove the paper from the tube.
  4. Remove the paper from the plastic bag or packaging.
  5. Verify that the curl has been removed from the paper. Repeat the steps above if necessary.
If the top paper tray is not securely in position and the printer cannot initialize (you may hear a grinding noise, and the top paper tray will not open), contact Kodak.
Nov 02, 2010 | Kodak ESP 3 Multifunction Printer/ Copier/...
How do I clear a piece of paper jammed in my Kodak ESP5 All in one printer
1 Lift the output tray.
2 Open the paper trays and remove any paper.
3 Turn OFF your printer.
4 Wait 30 seconds, and then disconnect the following from the back of your printer: USB cable, Ethernet cable, Fax cable, AC power cord.
CAUTION: Do not use force when removing the paper from the printer.
5 Check inside the cleanout area for a paper jam. If necessary, remove any paper or debris.
6 If paper is not visible, check the printer for foreign objects, such as paper clips or staples. If necessary, carefully remove the foreign objects from your printer.
7 Open the printer access door.
8 Remove any foreign objects from the printhead access area, and then close the printer access door.
9 Connect the following to the back of your printer: USB cable, Ethernet cable, Fax cable, AC power cord.
10 Wait 30 seconds, and then turn ON the printer.
11 Squeeze and move the paper-width guide on the paper tray to the left.
12 Load the paper into the upper paper tray.
13 Squeeze and move the paper-width guide to the right until it touches the paper.
14 Close the paper tray.
Best of Luck
saj
Nov 02, 2009 | Kodak ESP 5 Printer
Kodak esp 7 has a paper jam I cannot remove the paper
If you have tried the Kodak standard instructions for clearing the paper jam problem and it did not help try the procedure below.
1. Open the printing area of the printer (containing the ink cartridges).
2. The Ink cartridge holder should be to right side of track.
3. Look on left side, below the track for the cartridge that is used to
clean the print heads.It can be identified by a square black pad
approx. 1" sqaure that appears to be made of "felt".
If it is visible this is most likely your problem.
4. To correct problem locate the flat latching lever approx. 3/4" wide that
sticks up about 1/2" above the cartridge. It is locacted just behind
the "felt" square. Gently push lever toward rear which should free the
cleaning cartridge and allow the entir cartridge to move slightly
backward.
5. Close the top of the printer and cycle the printer off and back on.
If this is the problem, the "paper jam" error will now be gone.
This is such a simple fix I do not know why kodak does not inform
customers of this problem and how to fix it.
May 09, 2009 | Office Equipment & Supplies
Paper jam error light on kodak esp 5
  1. Remove the paper tray.
  2. Disconnect the power cord, wait 5 seconds, then reconnect the power cord.
    NOTE: The printer will reset and eject the paper. If the paper does not eject, try to remove it manually.
  3. Replace the paper tray.
  4. Press the Print button on the printer to resume printing.
Apr 01, 2009 | Kodak ESP 5 Printer
My Kodak ESP5 keeps saying "Paper Jam please remove paper jam" But there is no paper in it?
My esp 5 gave me this same message. I'm not an expert but here is what worked for me.
I turned off and disconnected both cables (usb and power) then reconnected and turned on.
At this point it still read paper jam, so I took ink cartridges out and paper out.
I then reinstalled ink cartridges and PULLED OUT THE PAPER TRAY to it's FULL capacity, added about 5 sheets of paper, and on the main menu I chose the allignment function and printed a test page and suddenly....no jam!
Hope this works for someone. For some reason pulling the tray all the way out cleared the "jam" message for me. Now if I could just get the new ink cart to work I'd be all set! Good Luck!
Dec 20, 2008 | Kodak ESP 5 Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
112 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
