Question about Toshiba Satellite M35X-S149 PC Notebook
Can i change the current optical drive (combo) of my m35x-s149 to a DVDRW? thanks
  • Toshiba Master
  • 4,806 Answers
Yes you certainly can swap out the combo drive for DVD/RW. Just make sure you purchase one that is similar to yours and remember to keep the front face of yours just in case you need it.
Regards
Posted on Aug 05, 2010
Testimonial: "that was a very fast reply! thanks! "
Notebook will not power on when on battery, but will run on the battery after it boots
Hello
Booting process take so much current from the battery. If the battery is not capable of supplying enough current to boot up, this may happen. Replace the battery with a new one. the present battery inside it will have insufficiant current for first boot up.
Mar 10, 2012 | Toshiba Satellite M35X-S149 Notebook
How do I remove write protection from a DVD-RW?
Your M35X-S1143 model - assuming it still has the stock drive - has an DVD / CD-RW optical drive - i.e. it will write only to CD's but not DVD's. If you try to burn a DVD, it'll tell you that the disc is write protected (when in fact, the drive doesn't even know how to write to a DVD disc.); if you go ahead and burn a CD, you will not encounter the write protection warnings.
Aug 31, 2011 | Toshiba Satellite M35X-S1143: M35X-S1143...
My screen is black on my toshiba satellite m35x-s149 laptop. What do i need to repair this? I currently use a desktop monitor to see but would like to fix and use the laptop as it should be use. Any...
If you are getting display in an external monitor, it means Laptop is working fine except LCD. Better to replace the LCD. It will not coat you much. Contact Service center or Computer accessories dealer, for used LCD, they used to have from old PC.
Aug 20, 2010 | Toshiba Satellite M35X-S149 Notebook
My toshiba m35x-s149 does not have a hard drive but has the little thing with the holes in it how do you install one?
http://wize.com/pc-laptops/p9910-toshiba-satellite-m35x-s149-psa72u00t00u-pc-laptop
By the reviews I see,not the best choice for a dependable machine...that said,it should have at least a 60GB HD,so I don't know what you mean by NO HD? http://www0.dealtime.co.uk/xPF-Toshiba_Satellite_M35X_S149_P1_50GHZ If it's missing,it easy to install one,but if you are not sure of your mech knowledge,bring it to a shop,maybe $20.00 to install.
Mar 24, 2010 | Toshiba Satellite M35X-S149 PC Notebook
Toshiba m35x-s149 takes a long time to come on. What can i do to speed up the start up?
Hi, go to the Control Panel, In the Programs category, select the "Change the Startup Programs, only start essential programs at "Boot-Up," you can "stop certain "Services," and "Processes in the (Task Manager) from running during start-up aswell. You may need to "Backup Files, and do a Defragmentation of the HardDrive, open the Computer from the Desktop, select Properties, choose the (Tools), you can use "Clean-up Disk" to make more "Space," all of these will improve the perform, and speed-up the "System." If the solution helped, "rating it is appreciated, thanks."
Mar 13, 2010 | Toshiba Satellite M35X-S149 Notebook
How to install wireless lan?
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=835422&rpn=PSA72U&modelFilter=M35X-S149&selCategory=3&selFamily=1073768663
Nov 22, 2009 | Toshiba Satellite M35X-S149 Notebook
Where is the cmos battery located?
It is located on the mother board, under the keyboard.... It is the size of a quarter.... and may be soldered in on your Satellite M35x series machine.
Oct 23, 2009 | Toshiba Satellite M35X-S149 Notebook
Keyboard replacement for toshiba m35x S149
Above the keyboard - between the keyboard and the screen there is a plastic piece that if you take a small screw driver you can pry off just above the keyboard or at the hinges. Be very careful not to scratch. If you are worried about scratching ifixit.com sells a tool called a spudgner that is soft plastic. This is what the pro's use. Once you have that plastic off you can simply unscrew the keyboard.
Be carefull when lifting the keyboard off. It is attached with a thin ribbon. the ribbon is held in with a clip. gently pull on the clip until it release the ribbon. Once you have the old keyboard off simply push the ribbon in the clip and force the clips back down. Then just reverse the previous steps.
Good luck
Mar 21, 2009 | Toshiba Satellite M35X-S149 Notebook
Toshiba Satellite M35X-S149 PC Notebook Logo
46 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
