Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
I start the system, it starts working normal then completely stops and the service light lights up but no code,lcd screen is blank.
  • 297 Answers
Service light is dealer problem only.
Customers can not fix it
If it is under 2 years old and you still have your receipt you can call intex
they will e-mail you a form
fill it out and fax it back
a new system will be at you door in a few days
Posted on Aug 05, 2010
After windows screen it goes blank, i know the lcd works because i can choose F2 or F12 and read and choose anything there however when i command it it just goes blank, no cursor, just blue / black ..blank
If the system will not complete boot, try the F8 boot menu and select safe mode and see if the system will boot to windows.
If the system boots to windows, you could have software issues or a startup item causing the system to hang at boot, try turning off the startup group items in MSCONFIG (Start, run, MSCONFIG) and see if the system will boot in normal mode.
If that is not help, hold the Fn Key while pressing the power buttong this should start PSA diagnostics on the system, see if any hardware fails
Jun 30, 2011 | Dell Inspiron 5100 Notebook
Problm with viewsonic va712b
sounds like the operating mode is at a frequency or refresh rate that is outside the viewsonic operating specifications when in normal mode. possible solution: in safe mode access control panel, system, devices (hardware) and look for display. do a right click and uninstall. repeat right click and "scan for hardware changes". That might reset the monitor operating modes but it also gives you a chance to reinstall drivers. If this does not work, try other monitor crt/lcd to see what happens.
May 29, 2009 | ViewSonic VA721 17" LCD Monitor
ViewSonic LCD (VA1912w) Went Blank
I am using this great LCD for about an year. But few times in the past my LCD didnt show up the display though the Green light was still ON, turning off the LCD and opening it again always solved the problem. But now My LCD completely went blank. Turning off/on didnt work at all now. I've tried couple of other tweaks mentioned on this site but they didnt work. I am just seeing a blank screen with green light ON. and ya theres a very low hissing sound coming from the LCD.
Feb 18, 2009 | ViewSonic VA1912w 19" LCD Monitor
Satellite 1115 blank screen at start up.
Try using an external monitor. If an external monitor works then the issue may be backlight if not then the issue is the LCD screen. the way to test that is after you have used an external monitor to verufy booting and the the system works. then if the machine is out of warranty you remove the bezel anf the screws holding the lcd in place. lean the lcd forward. with a flash light on turn your system on and flash the light through the display if you see your post and or windows with the flashlight then the baclight is bad. if not lcd is bad. If you can not get teh external monitor to work, then your motherboard is bad or graphics card.
Dec 02, 2008 | Toshiba Satellite A100-S8111TD Notebook
Blank white screen
It seems to be ur lcd stops working..Take this to service center...
Nov 29, 2008 | Samsung J700 Cellular Phone
Pc does start but monitor is blank but its light is on
What connection are u using? DVI to DVI? VGA to VGA? or are u using DVI+ adapter to change the source to VGA?
Nov 21, 2008 | LG L1717S-BN 17" LCD Monitor
Nokia 6230i my screen keeps going blank
remove MMC from ur mobile,then switch on ur mobile then press restore key that is *#7370# after inserting this u have to enter 12345 as factory code, then it will start
Jun 16, 2008 | Nokia 6230i Cellular Phone
LCD screen is blank (Dell Latitude C610)
I would say that it is a faulty backlight. The CCFL is a huge pain to replace on its own, but is much cheaper than replacing the whole LCD assembly, which does come with the inverter.
Apr 23, 2008 | Dell Latitude C610 Notebook
Sony Ericsson W850i Cellular screen has stopped working
3 things could be.. replace lcd, or replace flex, or the display ic.... and maybe loose connection flex from board to lcd... gotta go to service center ... you cannot fix it...only professinals can do that..
Apr 16, 2008 | Sony Ericsson W850i Cellular Phone
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
514 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
