Question about CenDyne Serial Modem for Windows (CDIMM00131)
I need to know the Power Supply specs for this modem
I have a Motorola 2210-02-1002 modem for a D-Link WBR-1310. I need a power supply for the modem. Can you tell me what the power rating is for the 2210 so I can select the right power supply? Thank you very...
You will need a power adapter with 12 Volts DC with .42 amps. The barrel will have to be negative and the tip is positive. It has these specs written on the back of the modem, just above the power port.
Mar 21, 2011 | Arris High Speed DSL Modem
Toshiba a50 specs
hi
if you need the specs for the toshiba a50 here they are. hope this helps please let me know
Motherboard chipset
Intel 855GME
Centrino
Yes
Processor speed
1.5GHz
Processor
Pentium M
Memory/Storage
Amt of RAM
256 MB (max 2048 MB)
Hard drive
40 GB
Optical drive
DVD/CD-RW combo drive
Connectivity
Ports
2 x USB 2.0, FireWire, Ethernet, modem, VGA port,
parallel port, microphone and headphone audio jacks
Bluetooth
No
Infrared
No
Modem
V.90 compliant 56K modem (V.92 ready)
Built-in devices
Type II PC Card slot, 802.11b/g wireless LAN
Wireless LAN
802.11b, 802.11g
Webcam
No
Display
Graphics hardware
Intel 855 GME integrated graphics controller 4x AGP bus
Amt of video RAM
16 - 64MB shared memory
Diagonal screen size
15 inch
LCD technology
Active matrix TFT
Screen resolution (max)
1024 x 768
Multimedia
Remote
No
DVD/MP3 without bootup
No
TV tuner
No
Sound hardware
16-bit stereo SoundBlaster Pro, Built-in stereo speaker
with SRS TruSurround XT Sound Technology
Jacks
mic-in, earphone-out
Software
Operating system
Win XP Pro
Software included
Microsoft Office OneNote 2003, InterVideo WinDVD, Sonic
RecordNow! CD/DVD Writing Software
Chassis
Weight w/battery
2.8 kg
Dimensions
338 x 274 x 38 mm
Power
Supply
Battery type(s) included
6-Cells Lithium-Ion
Mfr-claimed battery life
4 hours
Feb 11, 2011 | Toshiba Satellite A50 Keyboard
I want to know if the power supply i have right now is 450watts can supply all the components below, or do i have to upgrade any? thanks My Specs: 4core dual-SATA2(motherboard) DVD-rom nvidia geforce...
Unless you have problems, your power-supply is totally adequate.
Probably, even a 300W power-supply would be sufficient
(one DVD-ROM, one disk-drive, one video-card).
Nov 15, 2010 | E-Machines eMachines Desktop PC
I need to know that amps that this device needs
If in the USA, this will be plugged into a 120v AC mains supply, the power into the device is 10.5v DC.
It uses less than 6 watts.
I cant see any info for amps, but i would imagine it would be less than 1 amp.
Your manual is here http://www.westell.com/images/pdf/e90_6000_6100_6110_ug.pdf
And your detailed specs here
http://www.dsl-warehouse.com/pdf/westell6100_liteline.pdf
I hope this is of some help to you, please leave feedback
Thank you
Aug 20, 2010 | Westell Wirespeed LiteLine 6100...
I need a power supply for a White 4400 embroidery machine. Do you know what the part number is?
Local computer stores carry Universl power adapters. These spec are very common on off the shelf power adapters.
You power supply specs are:
DC 6V power UL Power supply at 800mA
Or you can order from this site:
http://www.whitesewingcenter.com/index.php
http://www.whitesewingcenter.com/orderform.php
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 10, 2009 | White Sewing White 4400 Computerized...
Please read the problem
Hi there.
The router is around 4-5 years old and is ADSL/1
Here are the power specs for you >>>>
Thanks for choosing FixYa!!
Jun 01, 2009 | Zyxel Prestige 841 (91-004-226010) Modem
2wire gateway
The modem is a Gateway 2Wire model 2701HG-D. Its function is to handle the high frequency data carrier that rides on top of your ordinary telephone wires to provide internet access. It has four ethernet ports and one USB port in addition to the telephone connector. QWest has said there have been problems with it and they recommend that you purchase a newer model for $100.
Ours failed yesterday with a bunch of green lamps glowing steadily without the normal blinking. The lady was about to go downtown to purchase a replacement when I figured out how to open the box with its four springy plastic bending tabs that you can see looking through the cooling apertures.
What I found was an internal operating voltage of about 4 volts which was well below the 5.1V printed on the power brick. When I ran the modem from a laboratory grade 5 volt source it seemed to work drawing about 1 ampere without any connection to the phone line.
Measuring the 5 volt supply that came with the modem I saw 5.2 volts but when loading it to 100 milliamps or so it dropped to 4 volts. It was definitely out of spec. Replacing the brick with another brand rated at 5 volts, 2.2 amperes solved the whole problem.
A failing power supply usually turns itself off but in this case measuring its output with a voltmeter would result in a conclusion that it was OK. Not so. You have to measure it under load which is a bit harder to do.
So. . . Don't rush to buy that new modem the way QWest says. Consider a replacement power brick. Positive 5 volts on the center of the connector with 2 amp capability. The original power converter used a three pin grounding plug for the AC source and the ground was connected to the negative side of the DC output. That's not normally done and does not seem to be necessary. It would make more sense to connect to the telephone company ground but that wire may not be available in the 6 pin telco socket.
Part numbers on the failed power brick
P/N 1000-500031-000
Part No GPUSW0512000GD1S
Input 100-120Vc.a 50/60Hz 0,15A
Output 5.1V DC 2A
Class 2 Power Unit
Made in China
And. . . after cracking the shell of the power brick the input aluminum electrolytic capacitor showed typical deformation of the round aluminum end. That kind of failure is very much a part of my life these days. Sigh.
May 13, 2008 | 2wire (1000-000057-000) Modem
Power supply specs
Manufacturer - 2WIRE
P/N - 2900-800007-000
Model - SAL115A-0525-6G
SWITCHING ADAPTER
Input - 120V ~ 50-60Hz 400mA
Output - 6V 2000mA
Jan 23, 2008 | 2wire 1800HG Router (RG1800HG00)
CenDyne Serial Modem for Windows (CDIMM00131) Logo
Top CenDyne Computers & Internet Experts
Alun Cox
David Payne
David Payne
Are you a CenDyne Computer and Internet Expert? Answer questions, earn points and help others
