Question about LG 42LC2D 42 in. LCD HDTV
How do I set and display the clock - LG 42LC2D 42 in. LCD HDTV
How to set clock pioneer
1 Use MULTI-CONTROL to select
CLOCK SET.
2 Press MULTI-CONTROL to display the
setting mode.
Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment
of the clock display you wish to set.
Each time you press MULTI-CONTROL, one
segment of the clock display is selected.
Hour-Minute
As you select segments of the clock display,
the selected segment blinks.
Jan 24, 2014 | Audio Players & Recorders
How to set clock in pioneer deh4000ub
here is the link for your manual:
http://www.pioneer.co.uk/uk/support/manuals/DEH-4000UB/index.html
Setting the clock
This function is available only for DEH-4000UB.
Use these instructions to set the clock.
CLOCK SET.
setting mode.
# Press BACK to return to the previous display.
Hour—Minute
4 Turn MULTI-CONTROL to put a clock
right.
# You can also perform the same operations by
pushing MULTI-CONTROL up or down.
Turning the off clock
display on or off
If the off clock display is turned on, the clock
appears on the display when the sources are
off.
OFF CLOCK.
2 Press MULTI-CONTROL to turn the off
clock display on.
# To turn the off clock display
Cheers!
Feb 07, 2010 | Pioneer DEH-P4000UB CD Player
How do i change the time on my deck
Adjusting initial settings
1 Press SOURCE and hold until the unit turns off.
2 Press MULTI-CONTROL and hold until CLOCK SET appears in the display.
3 Turn MULTI-CONTROL to select CLOCK SET (clock)
Setting the clock
1 Use MULTI-CONTROL to select CLOCK SET.
2 Press MULTI-CONTROL to display the setting mode.# Press BACK to return to the previous display.
3 Press MULTI-CONTROL to select the segment of the clock display you wish to set.
Each time you press MULTI-CONTROL, one segment of the clock display is selected.
As you select segments of the clock display, the selected segment blinks.
4 Turn MULTI-CONTROL to put a clock right.
# You can also perform the same operations by pushing MULTI-CONTROL up or down
Jan 09, 2010 | Pioneer DEH-P4000UB CD Player
How do i set my clock on my pioneer deh-p7800mp
Here is the link to your manual:
http://www.pioneerelectronics.com/vgn/images/portal/cit_11221/310077279DEHP7800MPOperationManual.pdf
Setting the clock
1 Use MULTI-CONTROL to select Clock.
Clock appears in the display.
2 Push MULTI-CONTROL left or right to
wish to set.
Pushing MULTI-CONTROL left or right will select
one segment of the clock display:
Hour—Minute
the segment selected will blink.
3 Push MULTI-CONTROL up or down to
set the clock.
Pushing MULTI-CONTROL up will increase
the selected hour or minute. Pushing
MULTI-CONTROL down will decrease the selected
hour or minute.
Notes
! You can match the clock to a time signal by
pressing MULTI-CONTROL.
— If the minute is 00 to 29, the minutes are
rounded down. (e.g., 10:18 becomes
10:00.)
— If the minute is 30 to 59, the minutes are
rounded up. (e.g., 10:36 becomes 11:00.)
! Even when the sources are off, the clock display
appears on the display. Pressing CLOCK
when the sources and feature demo are off,
turns the clock display on or off.
Turning the clock display
on or off
You can turn the clock display on or off.
% Press CLOCK to turn the clock display
on or off.
Each press of CLOCK turns the clock display
on or off.
Note
appears on the display. Pressing CLOCK when
Cheers!
Jan 03, 2010 | Pioneer DEH-P7800MP
I need to know how to set the clock pioneer deh-p6500 thank you
Here is the link to you manual:
http://www.pioneerelectronics.com/pio/pe/vgn/images/portal/cit_11221/50163operation_manual_DEH-P6500_2003117151397330.pdf
Setting the clock
wish to set.
Hour—Minute
set the clock.
hour or minute.
Notes
10:00.)
on or off
on or off.
on or off.
Note
Cheers!
Dec 04, 2009 | Pioneer DEH-P6500 CD Player
How do i set the clock on a pioneer car stereo
http://www.pioneer.co.uk/uk/support/manuals/DEH-2700R/index.html
Setting the clock
wish to set.
Hour—Minute
set the clock.
hour or minute.
Notes
10:00.)
on or off
on or off.
on or off.
Note
Cheers!
Nov 24, 2009 | Pioneer DEH-2700 CD Player
How do i set clock on pioneer deh 1800
here is the link to your manuals:
http://www.pioneer.co.uk/uk/support/manuals/DEH-1800R/index.html
no instruction in there for setting clock!
usually is the same here are the usual instructions:
Setting the clock
wish to set.
Hour—Minute
set the clock.
hour or minute.
Notes
10:00.)
on or off
on or off.
on or off.
Note
Note: on some models you can only set the clock with the clock on display and power off on radio.
Cheers!
Nov 10, 2009 | Pioneer DEH-1800 CD Player
I cant set the clock on my pioneer deh 21001b cd player
1 Press SRC/OFF and hold until the unit
turns off.
3 Turn MULTI-CONTROL to select one of
the initial settings.
CLOCK SET (clock)—AUX (auxiliary input)
# To return to the previous display, press
DISP/BACK/SCRL.
# To return to the main menu, press and hold
DISP/BACK/SCRL.
# To cancel initial settings, press BAND/ESC.
Setting the clock
CLOCK SET in the initial setting menu.
Refer to Adjusting initial settings on this page.
setting mode.
Hour—Minute
right.
Sep 26, 2009 | Pioneer DEH-2100 CD Player
How to set a deh-p4000ub car radios clock
try this:
Using the initial settings, you can customize
various system settings to achieve optimal performance
from this unit.
turns off.
2 Press SOURCE and hold until function
name appears in the display.
3 Press FUNCTION to select one of the initial
settings.
Press FUNCTION repeatedly to switch between
the following settings:
Clock—AUX (auxiliary input)
Use the following instructions to operate each
particular setting.
# To cancel initial settings, press BAND.
# You can also cancel initial settings by holding
down SOURCE until the unit turns off.
Setting the clock
1 Press FUNCTION to select clock.
2 Press c or d to select the segment of
Pressing c or d will select one segment of the
clock display:
Hour—Minute
3 Press a or b to set the clock.
Turning the clock display on or off
display appears on the display.
on or off.
on or off.
Aug 05, 2008 | Pioneer Audio Players & Recorders
Have Pioneer DEH 1900MP CD receiver. Do not know how to set time. Have no amnual. Also information on the remote control
It's on page 12 of the manual. Here you go:
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/372010482DEH1900MPOperationManual1030.pdf
from this unit.
turns off.
settings.
particular setting.
Setting the clock
clock display:
Hour—Minute
on or off.
on or off.
Operating this unit
12 En
Aug 05, 2008 | Car Audio & Video
LG 42LC2D 42 in. LCD HDTV Logo
153 people viewed this question
