Question about Maytag Microwave Ovens
My Maytag microwave (MMV4205BAS) display lights are dim. What should I do?
  • Maytag Master
  • 9,098 Answers
It may be a weak VFD tube or it may be that the rear of the display window and front of the display glass are very dusty.
Sometimes you can clean it inside to brighten it up.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Then you can detach the keypad connector (as per attached photo) then remove the control panel screws.
Be careful not to crack the glass display when handling it, or it's a goner.
Then you can use a soft cloth (not a paper towel) and a mild cleaner (not ammonia-based) to clean the front surface of the VFD display glass and the rear side of the clear bezel (display window) that's attached to the keypad.
Direct spraying of cleaners on the keypad and steam from the cooktop can damage the controls.
I always recommend that you spray non-ammonia cleaner on a soft cloth (not a paper towel which can scratch) and gently wipe the keypad.
If that cleaning didn't help, then you have a weak VFD.
On this model, the VFD is not available, so you would have to order a new circuit board for it.
You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
Posted on Aug 06, 2010
How do I change my MMV4205BAS to vent (recirculate) out of the front vent instead of the top vent.
Paul, if you look on top of the microwave before you install it you will see where the fan is located at the back edge. There should be 2-4 screws that hold it in place. Remove the screws and pull the fan up and out of the microwave and rotate the unit 90 degrees towards the front of the microwave and put it back in and replace the screws. That should be all that you have to do to get it to vent out the front.
Jul 29, 2014 | Maytag MMV4205 Microwave Oven
Maytag microwave mmv4205bas key pad is not functioning properly
It could be that the buttons are worn out. You'd need to replace the keypad to fix it, which will likely cost about as much as a new microwave. See if you can get it fixed under warranty, also, try cycling the power, it's always worth a shot.
Aug 14, 2013 | Sharp R305KS Microwave Oven
Maytag mmv4205bas
The problem is more than likely in the keypad control board, pricing on this part should be checked before going ahead with repairs.
Jun 29, 2012 | Maytag Appliances Over-the-Range Microwave...
Maytag mmv4205bas not turning no fan no interior light
The problem is one or two door switches are defective, or the keypad control board.
Apr 23, 2012 | Maytag Microwave Ovens
Screen displays -SE- , none of the keypad buttons work
The word -SE- , means systems error, the cause is a short in the membrane of the keypad. The only solution is the keypad must be replaced.
Mar 05, 2011 | Maytag Appliances Over-the-Range Microwave...
How can I view installation Instructions on a Maytag over the range microwave MMV4205BA
It depends on your full model number:
You can find helpful exploded view diagrams and order parts and accessories by entering your full model number here.
Dec 17, 2010 | Maytag Microwave Ovens
MMV4205BAS no power. Was not using it.
Try checking the fuses under the button panel.
Jun 08, 2010 | Maytag MMV4205 Microwave Oven
How do I mount a maytag mmv4205bas microwave? I bought a floormodel and they did not have the template.
Go to this website:
http://www.servicematters.com/maytag_library/html/index.html
-Once there click the link at the top "Literature by Model"
-Now enter your model number "MMV4205BAS" and hit enter or "go"
-On the page click your model number
-Click on the first row or the row containing the Document Type of Service Manual
-On page 51 of that PDF you will see the installation instructions for your microwave.
Apr 09, 2009 | Maytag MMV4205 Microwave Oven
MAYTAG MMV4205BAS Running but not heating
If the food in the cooking compartment is not heating at all, then you may have one of several components related to microwave energy generation that have failed or became disconnected internally.
Magnetron Tube, HV Capacitor, Filament Transformer or any number of sensors that disable power to the system. The control board could also cause the system to noty function correctly.. You wanted general inputs.. there ya go.. LOL
Not sure I told you anything you didn't already know but you should ask the tech what he did after he gets it going...
Regards,
Rick
Nov 28, 2008 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
886 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
