Question about Microwave Ovens
I need to buy the filter of Turboair cooker hood made in Italy. Model: KTEOREMA, 220V50Hz 340W. Do you know where I can get it? Thanks
I have a Rangeaire Stove Vent/ Hood. I am having a hard time locating the model #. It was probably made around 1982. Ideas how to find the model # as I need replacement parts. Please & thanks!
I reckon it will be in one of two places. At the place where the mains wire goes in (rear), or under the hood where the filter or light is.
Jul 05, 2016 | Microwave Ovens
CAN a ZANUSSI gas cooker be converted to utilize NG ? Without affecting its programs and controls ?
usually any gas cooker can be converted as long as the gas jets are changed to the right size. they also have to be the right fitting. it would involve a lot of work as you will need to get into the nitty gritty of the gas lines inside the cooker and if you make a mistake it can cost to get it fixed.
Jul 02, 2017 | Microwave Ovens
My new panasonic microwave model NN ST 340w has the internal light on when I heat up food. However when I open the door to put food in or take it out, the internal light does not turn on. What can I do?...
Your oven light is busted or damaged. You can buy the replace at the any electronic shop. Just open the top cover then you will see the light you will going to replace
Aug 15, 2011 | Panasonic NN-H664 Microwave Oven
Hi can u pls send me installation manual for Whirlpool for Ikea 90cm cooker hood HOO D10S with carbon filters. Thank you :)
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies as required.
The information is normally free of charge.
I hope this helps.
Mar 09, 2011 | Whirlpool Microwave Ovens
We turned the fan and light on our TURBOAIR S88 90 ST/ST 90CM CURVED STAINLESS STEEL CHIMNEY HOOD there was a flash from behind the buttons and now doesn't work is there a fuse that needs to be changed...
Sounds like the lamp has failed and maybe damaged the power switch. This, if installed correctly, will be fed from either a fused plug or a fused spur.
If it has been fitted incorrectly, no idea.
Jan 23, 2011 | Microwave Ovens
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
