Question about Russell Hobbs 13968 Iron
Iron is coming on but not getting hot. - Russell Hobbs 13968 Iron
2 Suggested Answers
jonsnell4
  • 27199 Answers
SOURCE: Hi. I have Russell Hobbs iron not getting hot but the power light is coming on but the iron not getting hot
Faulty element could cause that.
Posted on Apr 26, 2018
Should the cable from the machine to iron get hot
If the iron is a steam-iron with a steam tank in the base-unit, then steam is carried up the connecting pipe & it will get hot in normal use.
If you put water into the iron itself, then there is only an electric cable connecting the base & it should never, ever get hot. A little bit warm maybe, but never hot.
Best of luck.
Mar 09, 2018 | Irons
Water coming out of steam holes
Either: the iron is not hot enough to heat the water to steam temperature or the internal water-flow valve is leaking so that too much water is getting through. Check the iron is getting hot enough first. If it is then run some de-scaler (as used in kettles) through the iron to try to clean all the passageways. Always ensure that you fully re-flush the iron after de-scaling or you'll damage your clothes with any acidic residue left in the iron.
Good luck.
Dec 04, 2016 | Irons
My Rowenta pro precision iron steam station gets hot but doesn't steam. How do I get the iron to produce steam?
There are two cause. One the boiler resistance doesn´t turn of because of snap disc or bimetal thermostat fault or because a coil in the working valve (security valve). But if you can heard a click of opening movement of valve when you push the button it is able to be a thermostat.
Apr 12, 2016 | Rowenta Irons
Can't seem to prime iron to get the steam coming
  • if your having trouble getting the water in the iron to steam, try turning the heat setting all the way up and then add cold water to the resivoir. your iron may not be getting hot enough
Oct 11, 2014 | Irons
Team international steam iron
Make sure the valve between the base and iron is open.
Nov 23, 2013 | Irons
Gravity feed steam iron
If you have been using tap water in your iron, and your water has lime or calcium in it, then the iron is probably clogged up. You might try using a product like "Lime Away". Read the warnings on the bottle first. Don't get it on your skin or in your eyes. Don't breathe the mist or steam. The bottle I looked at also had warnings about how it would mess up some counter tops or sinks.But if the iron doesn't work anyway, carefully pour some into your iron maybe about one fourth full, then carefully shake the iron to get the stuff all over the insides of the iron holding the iron like you would if you were ironing. Let the iron sit for a bit, then shake it again, maybe a couple more times like that. pour it out into an old bowl that it wont ruin, and see if there are a lot of minerals in the liquid. If there are, that may have cleaned it enough to start working again. Pour enough water in the iron until it is half full, plug it in and turn the temperature up to where it will produce steam, but don't iron any clothes yet because there is still cleaner in the iron. turn the iron so it is like you are ironing, but don't let it touch anything. Hold it over something like some old rags. If steam comes out, don't breathe it, but let it come out for a little while. Pour out that water and refill with fresh water and let it steam over the rags again. Pour that water out and all the chemicals should be flushed out of the iron. Carefully wipe the hot plate off to get any chemicals off the plate. Good Luck
Nov 02, 2013 | Irons
Iron does not get hot
Mine just did the same thing, I think the controller fried. There is aburnt smell coming from it
Aug 03, 2012 | Euro-Pro Shark GI490 Iron
PI8000 the lights come on but the iron will not get hot.
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Dec 05, 2009 | Black & Decker Professional PI8000 Iron
Iron leaks water while ironing
Seal on iron is disolved. replace iron
Aug 31, 2009 | Rowenta DX6700 Iron
Russell Hobbs 13968 Iron Logo
49 people viewed this question
Top Russell Hobbs Irons Experts
 Mikey
Mikey
NOEL
NOEL
Are you a Russell Hobbs Iron Expert? Answer questions, earn points and help others
