Question about Emerson Heating & Cooling
I have an Emerson air conditioner model 10JW12K .I was wondering the btu"s and how much area that would cool.
  • 230 Answers
SOURCE: Amana Portable Electronic Air Conditioner 9000 BTU
Unfortunately I am unable to find the Manual in our system. Here is the information that you can use to contact them directly. They should be able to send you a new one.
Consumer Affairs Address:
7401 Security Way
Houston, TX 77040
To speak with a Heating and Air Conditioning Consumer Affairs Representative from within the United States, please call 1-877-254-4729
Posted on Jun 27, 2008
  • 67 Answers
SOURCE: how large a room does a 10,000 btu air conditioner cool
What size unit do I need for my room? Use the following chart to find the appropriate size air conditioner to use:
AREA TO BE COOLED / CAPACITY (BTU/HR)
100 to 150 square feet = 5,000
150 to 250 square feet = 6,000
250 to 300 square feet = 7,000
300 to 350 square feet = 8,000
350 to 400 square feet = 9,000
400 to 450 square feet = 10,000
450 to 550 square feet = 12,000
550 to 700 square feet = 14,000
700 to 1000 square feet = 18,000
If the room is heavily shaded, reduce needed capacity by 10%
If the room receives a lot of direct sun, increase needed capacity by 10%
Add 600 Btu/Hr for each person in the room if there are more than two people
If the unit is for a kitchen, increase the capacity by 4,000-6,000 Btu/Hr.
if this helps please vote me a fix ya
Posted on Jul 21, 2008
  • 659 Answers
SOURCE: No installation manual for new air conditioner
Here you go...........
http://www.frigidaire.com/support/ResultsPage.asp?strModel=FAS257S2A&User=&Search=Search
Posted on Mar 31, 2009
greenspan
  • 1734 Answers
SOURCE: sunbeam 9000 btu air conditioner
Ask here, they can get virtually every Sunbeam manual
Posted on Jul 28, 2009
  • 5 Answers
SOURCE: i have an amana portable electronic air conditioner wont turn on
try draining the water. Mine did the same thing. Started right back up. There is alot of water be careful.
Posted on Aug 03, 2009
Remove exhaust hose
U need that hose to direct the warm air outside the area to be cooled. If you remove it, the hot exhaust will stay in the room being cooled and negate the cold air being directed into the room.
That is why regular room AC units are mounted on window sill. Cold air in, hot air out.
Oct 08, 2015 | Haier Commercial Cool 8,000 BTU Portable...
Need manual for emerson quiet kool air conditoner model 12HT13?
I found this I hope it helps.
Performance BTU/H Cooling: EER: Voltage: Amps: Watts: Cooling Area (Sq. Ft.): Pints/Hour: Room Air Delivery (CFM): Plug Cap Amps: Plug Type: Dimensions Width: Depth: Height: Net Weight: Shipping Weight: http://www.appliancefactoryparts.com/airconditioners/emerson/12ht13.html#Manuals
Jun 02, 2014 | Emerson Quiet Kool 12HT13 Air Conditioner
The unit is not cooling the room. It is only comforting when you are in direct line of it.
you need to find out the size of the unit.
Rule of thumb - for every 600 sq ft of cooling area (in a well insulated house) you will need 1 ton of air conditioning. 1 ton = 12000 btu.
So, if your cooling area is 600 sq ft you would need an AC which was rated at 12000 btu, assuming your house is well insulated.
If it is not insulated well - you might need a bigger unit, i.e. 15000 btu.
Jun 06, 2011 | Samsung AW0603B Air Conditioner
Hi,what area will a1.5 hp. air conditioner cool.thankyou,terry jenner
The horspower rating does not indicate cooling area, this is usually done in BTU's and therms and tons. What is the rating for these on your air conditioner.
Here is a link to the consumer guide on sizing an air conditioner. If you find this helpful I would appreciate a vote on the thumbs up for the free information. Thanks.
www.consumerreports.org/cro/appliances/heating-cooling-and-air/air-conditioners/sizing..
Apr 08, 2011 | Heating & Cooling
My Ac do not cool enouhg, even it doesnt cool anything, i have my windows close and there is no equipment that produce heat!
Hi Cafe,
Ensure that the the discharge (hot air) is properly routed outside. Take temperature readings of the intake air (room air entering the unit) and the outtake air (cold air coming out of the unit). If the temperature difference is approx 18 to 22 degF, you might need more capacity. I believe your unit is 8,000 BTU. This is considered very small capacity. Not knowing what your situation is, it could be the right size. Below is a link to a site that will allow you to input information regarding the area you are trying to cool. It will calculate the BTU's needed to cool the area.
http://www.consumerreports.org/cro/appliances/heating-cooling-and-air/air-conditioners/sizing-worksheet/index.htm
Let us know if this helps. Good Luck!
Feb 16, 2010 | Midea MPM-08CR-BB4 Portable Air...
Need btu rating ???
Carrier YCB213D Y Series Window Air Conditioner 21000 BTU 230/208V. No Remote Control. High-efficiency energy-saving units. Quiet cooling for living areas.
Please dont forget to rate ;o)
Aug 17, 2009 | Carrier YCB213D Air Conditioner
BTU's on Emerson Quiet Kool A/C
AC Type dtrquestion.gif Thru-Wall/Window Cooling Capacity dtrquestion.gif 10000 BTU/hr Energy Efficiency Rating dtrquestion.gif 9 EER Fan Speeds (Cooling) 3
May 27, 2009 | Emerson Quiet Kool 10GV13 Air Conditioner
Amana window air conditioner 10000 btu
Mine has done this alot, mostly because I live in a state with ALOT of wind, and in an area with ALOT of dirt. Sounds like your coils are dirty. Try cleaning it out, or having it cleaned out. If you spray it with water just make sure your compressor is facing up and you don't use too much pressure. Hope this helps
Jun 12, 2008 | Amana PTC074B25AE Electric Heat Air...
Heating & Cooling Logo
Top Emerson Heating & Cooling Experts
Tim Whalen
Jay Finke
Jay Finke
Are you an Emerson Heating and Cooling Expert? Answer questions, earn points and help others
