Question about ASUS Computers & Internet
When I start my computer its only says bip bip bip
  • 1 more comment
  • goranbrenden Aug 05, 2010
    Hi and thanks for answe. The memory cards are working, I have tested in other computers. The beeps when I start the computer sounds like this beep 4 sec rest beep 4 sec rest and it never stops.
  • goranbrenden Aug 06, 2010
    When I start my computer it Beeps 1 sec /rest 4 sec/ beeps 1 sec /rest 4 sec and it is continued as long the computer is on. I have tried a new Grafic card, tried memorycard, nothing helps.
  • goranbrenden Aug 07, 2010
    Hi
    I have get an answer from you but it did not solve my problem.
    When I start my computer I don´t get picuture on my screen. The computer only beep for 1 sec and 4 sec rest, then beep and rest all time. It stops only when I turn the computer off
  • ASUS Master
  • 4,806 Answers
Three beeps indicates that there is a memory error. Take the system memory from the motherboard and clean the brass contacts on the memory and also clean slots that the memory clips into. Make sure you clean all of the dust away from them.
Put the memory back into the slots and try turning the computer on. If you have more than one memory module put them back one by one turning the computer on after each try.
If it still won't switch on and you get the beeps you will be looking at new memory for the computer.
Regards.
Posted on Aug 05, 2010
  • Lee Hodgson
    Lee Hodgson Aug 05, 2010
    It's not the memory cards. It's the system memory inside the computer that needs to be checked.
Kenmore washing machine big troubles?
Please list the model number of that machine. IT could be made by several manufacturers for Sears.
Mar 17, 2014 | Kenmore Washing Machines
Stitching loose
hi i have a juki 8700-7 whit computer CS-910-a and it showing
error 007 as sun i turn the machine on tarth bepeng like bip bip bip
can you please help me
Dec 31, 2013 | Juki DDL-8700
Will not power on
if all fan are spin up.
see your RAM, maybe its broken.
a computer need a routine checking all RAM, if its not good, your computer will freeze.
try pull out and put it again. if its doesn't work. replace it.
PS. when you pull out your computer with all RAM pulled out and doesn't heard any BIP BIP BIP (BIOS POST CODE) noise. I can Assume your Mainbpard or ypur processor is broken. maybe its sound scary but its not. see for computer service center to help, they can give you good advice.
May 09, 2012 | HP KT334AA Pavilion Media Center M8530F...
While starting its get bip sound upto window will start
Bip sound contiously might caused by 1.Fan stops working 2.Sticky key on keyboard
Try cleaned those two part, specially the heatsink ( something might blocked the fan )
akee_akee@live.com
Aug 17, 2011 | Acer Aspire 5738Z-423G32Mn Notebook
Computer didn't start
The bip-bip sound means that a necessary input/output device is missing or not working. Go to dell.com/support enter your service tag number download the manual (LINK included) if you have questions of how to search Dell Fourms. Please rate me mysleuth
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central?~ck=ln&c=us&cs=19&l=en&lnki=0&s=dhs
Apr 29, 2009 | Dell OptiPlex 330 Desktop Desktop Computer...
Toshiba qosmio E-10 noises keyboard and start up
Sound like you have a stuck key and the bip noise is the keyboard buffer pverloading.
If you can't unstick this key, you need a new keyboard.
Apr 13, 2009 | Toshiba QOSMIO E15-AV101 Notebook
Non si vede niente dal monitor
tre bip lunghi potrebbe essere un problema della tastiera.
Nessun bip = difetto di alimentazione, problema alla CPU o alla scheda madre, periferiche in blocco.
* Un bip = tutto funziona normalmente.
* Due bip = errore POST/CMOS.
* Un bip lungo ed uno breve = problema con la scheda madre.
* Un bip lungo e due brevi = problema video.
* Un bip lungo e tre brevi = problema video.
* Tre bip lunghi = errore tastiera.
* Lunghi bip ripetuti = errore di memoria.
* Brevi bip ripetuti = difetto di alimentazione, problema alla scheda madre.
* Continui alti e bassi bip = surriscaldamento CPU.
guarda anche questo sito
http://www.sergiogandrus.it/index.php/2007/08/22/hardware-significato-dei-bip-beep-del-pc-allavvio/
Dec 31, 2008 | Intel D945GCCR Motherboard
What does the bip sounds sounds mean on my pc
Its probably bad ram chip. Check that it is seated correctly. Then use another PC to do a google search on beep codes and isolate the actual problem by you PC bios type..
May 08, 2008 | Tiny Computers B1996 19" CRT Monitor
Moniter won't come on
hi
check your ram.put ram away and check your bip is comes on or not .if u get long bip your cpu is ok.and your ram pro.
clean your ram and fix it again.
clean oyur processor case.
clear your bios .
pls take step one by one.
Mar 24, 2008 | AOpen F90JS (Black) 19 in. Flat Panel LCD...
Computers & Internet Logo
158 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
