Question about Fagor 3FCA-68NFX Stainless Steel Refrigerator
How do i make my fagor fridg colder - Fagor 3FCA-68NFX Stainless Steel Refrigerator
I have a fagor refrigerator that freezes everything. any advice
Make sure your filters are clean also nothing blocking air flow check and clean front vent
Sep 21, 2017 | Fagor Refrigerators
Bush fridge freezer need coldest setting for fridge 1_7
freezers settings are the larger the number the colder the freezer as against fridge settings where the smaller the number the colder the fridge
Aug 29, 2016 | Bush Refrigerators
New Westinghouse fridge cannot seem to adjust freezer lower than 0' except if power freeze on getting colder ?
read the user manual or get a technician out under warranty
from 10 down to 0 on a fridge is getting colder with the smaller numbers
with a freezer 0 to 10 gets colder as the numbers get bigger
Jun 05, 2016 | Westinghouse Refrigerators
My Fagor Innovation fridge freezer is very noisy
The condenser core is dirty is my bet and the pump is worn out.
May 24, 2016 | Fagor Refrigerators
Unblock the water drain in fridge
switch off fridge for 4-5 hours, use hair drier and wire coat hanger
Oct 03, 2014 | Fagor Refrigerators
Fagor refrigerator (3FCA-68NFX): no cold air in the refrigerator
u may have a duct that goes from the freezer to the fridge that is closed off or u may have a stopped up freon line and if thats the case ur probably going to have to call a tech but check the duct first if u have one in that particular fridge
Mar 01, 2010 | Fagor 3FCA-68NFX Stainless Steel ...
Eaton viking fridge needs to be colder
when you turn the knob anticlocwise it will be warmer and clockwise will be colder. some thermostat switches when you turn it anticlockwise untin it clicks turns off your fridge completely.
Sep 06, 2009 | Refrigerators
What is the colder setting on a fridgare fridge 1 2 3 or A B C?
Colder than the hotter. I have a Phillips (Pillocks) replacement fridge where there is ice in the fridge compartment depite it being on the hottest setting. When a two month old fridge gave up the ghost it took Phillips 17 days to repair it. by the time it was repaired we had learned to live without a fridge.
Apr 08, 2008 | Refrigerators
Fagor 3FCA-68NFX Stainless Steel  Refrigerator Logo
48 people viewed this question
Top Fagor Refrigerators Experts
Oscar Netto
Oscar Netto
Marvin
Marvin
Trippy Tripp
Are you a Fagor Refrigerator Expert? Answer questions, earn points and help others
