Question about Dryers
The belt has snapped - Dryers
  • Dorrian Wilkins
    Dorrian Wilkins Aug 05, 2010
    A model or serial number would be helpful in assisting you. Look inside the door for a serial number or model number and let me now. Belts are not to bad to replace.
  • Dryers Master
  • 8,220 Answers
Belt config 101
More here
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Aug 05, 2010
Put new belt on hotpoint aquarius last one snapped but only turns with 3 items init no more but worked perfect before belt snapped?
A shaft could be seizing which is why other belt snapped, check the bearings and shaft to make sure they turn freely. Possibly wrong belt ? also check for worn pulley's.
Jan 23, 2016 | Hotpoint Washing Machines
What would make a new fan belt snap
2 main reasons.
1. the belt is being over tighten
2. the belt is miss aligned / rubbing against some thing (check the pullies)
Nov 18, 2014 | Citroen Berlingo Cars & Trucks
What if the fan belt break while driving
Dan h described what would happen if your timing belt/chain broke.. fortunately the consiquences aren't as dire if your SERPENTINE belt snaps. Most vehicles have the following systems or devices powered by the front engine accessory drive belt (FEAD belt)
AC compressor
Power steering pump
Alternator
Fan (some vehicles do and some don't)
Water pump
All but one of these things can be lived without, at least for a short time. If your belt snaps and your water pump stops your engine will overheat in no time flat., say you're cruising through a rural area and your belt snaps a mile and a half away from the next town, your car will get you there, but you had better turn it off once you get into town. After a belt snaps you've got 2 miles before you absolutely need to shut your car down to avoid damage.
Oct 11, 2014 | 2006 Mahindra Scorpio 2.6
Fan belt snapped on my renault express diesel changed that but now it now it turns over but wont fire up
check the belt is on correctly if it is it will be tight and around all pulleys,make sure around fuel pump pulley. Also ask yourself why belt snapped in first place was it old/cracked and due to break or did a pulley sieze and cause belt to squeel and burn then snap.
May 01, 2011 | Renault R5 Cars & Trucks
My h2, 2004 suddenly overheated very rapidly, only two days after being serviced. The air conditioning made a high pitched squeaking sound minutes before this happened. Engine then shut down and coolant...
Sounds like the ac compressor locked up and the belt snapped from rubbing on it. Once the belt snaps, the water pump stops and the engine overhears.
Mar 06, 2011 | 2004 Hummer H2
Drive belt snapped what is the cause
There are a couple of reasons for belt snapping.
1-Main drum bearings siezed, thereby caosing excessive friction, and belt to snap.
2-Motor siezed up, again causing excessive frictional wear on belt.
Try spinning drum by hand, it should be free, with no noise from it, if it runbles or feels rough, then drum bearings have failed.
3- Drum pulley loose or cracked, check the pulley for cracks or fractures.
Dec 23, 2010 | Hotpoint First Edition WMA22 Front Load...
My timing belt snapped and I took it to a mechanic. he said that the belt snap the piston head and the bent the valves. I am wanting second opinion, and would like to know if the timing belt is connected...
The pistons will hit and bend the valves if the timing belt snaps because they are very close.The alternator does not connect to the timing belt, there is a separate belt that runs the alternator.
Dec 17, 2010 | 1987 Nissan King Cab
Serpentine belt snapped 2 days in a row, the belt was burning the other day but today it just snapped and my anti freeze started to come out
A burning belt usually indicates a seized idler pulley on those gm cars. You will have to find which pulley is seized and change, it before replacing the belt or the new belt will only burn and snap again.
Sep 23, 2010 | 2001 Oldsmobile Aurora
A belt snapped, leaked antifreeze and no power steering
If it was the timing belt, the car would have quit right then and there.
It's the belt that drives the fan, water pump and power steering.
Probably what they call the serpintine belt.
Apr 16, 2009 | Ford Mustang Cars & Trucks
Snapped timing belt on 1.8t audi tt engine. Belt snapped not possible to mark bottom pully. help
just fixed my Audi TT ... timing belt snapped so the head had to come off to replace valves. used dial guage on top of piston !
if head is on then there is a plug you can remove that allows you to see top dead center..
Jul 14, 2008 | 2002 Audi TT
Dryers Logo
44 people viewed this question
Top Dryers Experts
Marvin
Marvin
