Question about Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television
PICTURE PROBLEM THERE ARE BLACK STRIPES GOING DOWN THE SCREEN. DOES NOT MATTER IF IT IS WATCHING PROGRAMMING OR MOVIES. IS DEFINITELY THE TELEVISION
  • Anonymous May 17, 2008
    no matter what your watching, (tv,cable,dvd,digital,vhs) the picture is sort of yellowish. We are sort of used to now, it but when ever people come over, its the first thing that they point out.
    Also when you turn the tv on, the start up screen which used to be pure medium blue, now has blck bands/blotches across the screen.
    All of these probles first started when we put some big speakers behind the tv. could this have any thing to do with it?
  • lui_v_w Jun 23, 2008
    I have a samsung 46"dlp and no matter what i'm wathcing theres black and white stripes going up and down the screen but theres still sound need help??
    President:
  • Samsung Master
  • 1,779 Answers
Sounds like your Light Engine has gone bad. Not a cheap repair.
Posted on Apr 26, 2008
  • 549 Answers
Try this link to Samsung help website.
Your tv appears to be quite new.
I am sure they can help solve this issue.
I use a USB when watching movies. The movie I was watching tonight did not finish, the screen went black at around 01:28:05 and restarted from the beginning, why did that happen?
It doesnt really matter as of how many movies are there in the USB. There is a chance that the movie might be corrupted. Just check it in your computer and see. The movie file itself must have been corrupted.
Dec 22, 2014 | Haier 32" 720P Le32 Led Hdtv
I have digihome tv has sound but no picture and nothing on virgin
is this happened either watching a tv channel or even watching dvd movies?. and then does the display only white screen or a totally black screen?.
Oct 16, 2012 | Digihome LCD TV
How to zoom in on info
When TVs first appeared, they had an picture ratio of 4:3, which matched that of most movie screens at the time. Terrified of losing their business, movie studios struck back with "widescreen" films using 1.85:1 or 2.35:1 ratios. When widescreen TVs started appearing, they emulated those same ratios, but many TV shows (and some movies) were still in 4:3---and we were eventually left with a bit of a mess. Canny manufacturers, including LG, have solved the problem by allowing you to adjust the picture ratio on the TV to fit the program you're watching. If it's not set properly, however, your image will look distorted or cut off. A quick bit of troubleshooting can fix the problem easily.
  1. Press the "Menu" button on the remote and scroll down to the "Option" title (it should be second from the bottom ). Then select "Aspect Ratio." You should see a list of ratio options. You simply need to pick the one which fits the show you're watching.
  2. Choose the 4:3 ratio for older movies and TV programs. You should see a pair of bars on the left and right side of the screen. (That's okay: the bars keep the program in the same proportion in which it was filmed.)
  3. Select the 16:9 ratio for widescreen movies and for more recent shows to match their longer width. For some movies, you may see black bars and the top and bottom of the screen. Again, that allows the movie to be shown in the manner it was filmed.
  4. Pick "Set By Program" to automatically switch the LG TV between 4:3 and 16:9 to match whatever show is on at the time.
  5. Select "Horizon" to horizontally expand the image onscreen. It will fill the whole screen---eliminating the black bars to the left and the right---but it may look distorted.
  6. Use the "Zoom 1" option to zoom the image forward. That will eliminate the black bars at the top or the bottom of the screen, though you will cut off the edges of the image.
  7. Pick the "Zoom 2" button to select a midway point between "Horizon" and "Zoom 1." The picture is stretched, but not as much as with "Horizon," and fills the screen, but doesn't cut off as much as "Zoom 1."
  8. Use the "Cinema Zoom" button to enlarge the picture to fit the screen. This option allows you to adjust the proportion to your liking, rather than use the set proportions of the other aspect options.
  9. Exit the menu when you are done and watch your programming normally.
Feb 04, 2011 | LG Televison & Video
Picture is stretched on wide screen a circle looks egg shape
Hello
This is an issue because most television programming is produced in a 4:3 aspect ratio. The minority of programming is high definition, which is produced in a 16:9 aspect ratio. Because televisions are made in either a standard (4:3) or widescreen (16:9) format, there is always a conflict with an image being stretched vertically or horizontally. In the case of widescreen televisions, the stretching is horizontal.
Picture Modes
Luckily, most if not all widescreen televisions have a picture mode that allows the user to toggle between a wide (16:9) and standard (4:3) mode. This means that a person can watch non-HD programming in the 4:3 picture mode, and then go to widescreen when watching HD programming. Some TVs have a picture mode that will automatically adjust to the correct aspect ratio. Other people will watch all programming in the wide picture mode, and learn to adjust to watching a stretched picture.
A stretched picture is when a 4:3 image is pulled on the sides to fill the entire screen. People and images end up looking fatter/wider and shorter.
So, what's the big deal?
Some people don't like a 4:3 picture stretched or distorted because it does reduce the overall visual and picture quality. Some people don't like the bars on the side of the screen when a widescreen is in a standard (4:3) picture mode because it looks different.
Solution
There is no fix-all solution for this issue, unless you own a TV that will automatically adjust to the intended aspect ratio. The stretching of the picture is a side-effect, the price we are paying for the better resolution that is digital and high definition. This is definitely something to consider when buying a television, but keep in mind that there is no right or wrong within this issue. It is just the way it is, and there is no way around it unless you buy a 4:3 aspect ratio television.
Hope these lines will clear the issue, if so do rate the solution
Jan 04, 2011 | Televison & Video
TV picture not available.
IF YOU HAVE A SOLID BLACK LINE RUNNING VERTICALLY THEN YOU HAVE A FAULTY MATRIX INVERTER. IF CENTRAL THE MAIN VERTICAL INVERTER NEEDS CHANGED. LEFT = LEFT VERTICAL INVERTER RIGHT=RIGHT.........
ANOTHER WAY TO GET THIS FAULT IS WORN OR DAMAGED RIBBON/PLASTIC GOING FROM THE SCREEN MATRIX TO THE INVERTER
Hope this help....
Jun 21, 2010 | Vizio L37 Television
Polaroid FLM-3734B 37 in. HDTV LCD Television has a black smudge in the picture. The smudge never moves and is there no matter what we are watching. I fixed the sound problem, but now we have this.
Without actually seeing the problem, I can't be 100% sure, but this sounds like a defect in the LCD panel itself. Is there any possibility that you can post a picture of the problem? That would allow me to confirm the problem. Please note that if the panel is the problem, the set is not worth the repair as the replacement panel costs $2209.15 plus shipping.
Dan
May 05, 2009 | Polaroid FLM-3734B 37 in. LCD HDTV
Scrolling Green color on screen
If the lines are like pin stripes going from left to right then you most likely have a defective green crt
Jan 08, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Black Bars on all blu ray movies
Hi icmjrtdr,
Having black bars displayed when watching a Blu-Ray disc is a common occurrence, even with a widescreen television.
You may have heard or seen aspect ratios of 4:3 or 16:9. 4:3 is the ratio of a traditional television that is nearly square. 16:9 is the ratio of most widescreen televisions currently marketed. The reason that even with a 16:9 television Blu-Ray discs are displaying black bars is that many of these discs contain footage that has not been reformatted for television. The screen in a movie theater is even wider than 16:9, and rather than trim the ends, most Blu-Ray discs maintain the entire picture.
Depending on the options available in your particular television, you may be able to find a zoom setting that trims the ends and removes the black bars. It is up to you if you would rather see black bars with the entire picture or lose a small amount of the picture on each side for a full-screen experience.
Hope this helps,
Jason,
Go Ahead. Use Us.
Jul 22, 2008 | Samsung BD-P1400 Blu-Ray Player
LCD Philips 26pf8946 after about 45mins right hand 1/3rd picture not viewable
Hi Darnez,
It sound like to me that one of the boards that power the bad side of the screen is getting hot and quitting. The boards are not too expensive to replace but getting them is generally the big problem. ( At least for our company). The set would be worth tkaing to a local shop and have it looked at, but replacement costs are going down every day it seems.
Good Luck
I hope in some way this has helped
Ed Meshechek
NC Electronic
Mills, Wyoming
307-266-4675
May 27, 2008 | Philips 26PF8946 26 in. HD-Ready LCD...
Samsung DLP HL-P4663W 46" Rear Projection HDTV-Ready Television Logo
50 people viewed this question
Henry  Thomas
Henry Thomas
