Question about 3Com NBX® V3000 (3C10600BUS)
We had a power outage last night and I have not been able to successfully restart my 3Com V3000 server. I have powered it down several times, waited several minutes before restarting, but it just shows blinking lights and it never starts successfully.
  • 58 Answers
After you power it up LEAVE IT ALONE for at least 45 minutes. When the NBX loses power abruptly it will do a disk scan upon reboot. The disk scan takes anywhere from 15 minutes to 45 minutes (depnding on the size of the database). You can connect to the console and see it doing a disk scan when you boot it back up. It will go through 6 phases and then boot up normally. Each time you pull the plug you risk database corruption (or hard drive failure on an older system).
Posted on Aug 09, 2010
  • NBX_Tech
    NBX_Tech Jan 24, 2012
    You can verify the disk scan process by looking at the S1 and S2 lights on the front of the NBX. They will be blinking (alternating back and forth) while the scan is in progress. If this is happening just be patient and DON'T pull the power again until they stop alternating. As I mentioned before, this can easily take up to 45 minutes.
Power interruption and now my plug,n go seems to be frozen. Cannot set time or clear anything. Screen reads 9.80 or something close
I had a similar problem with my Bosch wall oven after a recent power outage-restart-outage-restart cycle that lasted only about thirty seconds altogether. The difference would be in that while I could reset all the things like day, date, time, etc., the oven would arbitrarily go off on its own and make up the day, time, date, year, etc., with no apparent correspondance to reality. Here's what I did: I completely shut down the oven at its outside breaker (you will need to do whatever it takes to remove the power from the 'plug-n-go'). I waited five or ten minutes before turning the power back on and resetting the various items. Two days have passed and there have been no more mind-of-its-own excursions into another time zone. Problem solved, unless/until another power outage cycle comes along. Hope this helps, or at least gives you an idea about where to start.
Dec 15, 2014 | Hardware & Accessories
I have a Panasonic plasma, & we just had a power outage today... every time we have one, it won't power back on. The call center is closed for the night, & I can't remember what they told me to do the last...
First, unplug the TV, wait 30 seconds to 1 minute, then plug back in & try it. This allows the unit to reset.
Be sure you AC outlet breaker has not tripped.
could also be the TV fuse or power supply PCB.
You should be sure to put a good surge protector in line with this TV as these constant surges are going to severely shorten the life of the unit.
Jul 24, 2014 | Televison & Video
I get the message: 3Com Model 3102- Wait for NCP M We have never seen this before and it is after a power outage. Our server is running. What is NCP?
Hello.
NCP stands for Network Call Processor. There is a problem with communication. Since your server is running, reset your router (disconnect power, wait a few minutes, then reconnect) that supports your IP phone.
Hope this helps.
Aug 29, 2011 | 3Com NBX 3102 IP Phone
We have a 3Com NBX V3000. The building our office
This was a rather simple fix. When I was speaking about the NBX V3000, I was talking about our 2U NBX Chassis which holds the line card. When our phone system was installed I wasn't shown the 1U NBX V3000 "Brain". I thought everything was contained in the chassis. Long story, short, I restarted the 1U "Brain" and the system came back up with 5 minutes.
Feb 15, 2010 | 3Com NBX® V3000 (3C10600BUS)
A power outage caused server to shut down. It
The power outage is suspected to corrupt the RAM. Get in touch with the vendow and get it replaced.
Nov 09, 2009 | HP Server Tc2120 (335874-001)
Air conditioner compressor runs for about 1-2 min, then cuts off
well when u have outages the voltage drops obviously, the one that suffers are the capacitors the capacitor for the compressor might need to change, change it with the same capacity as the old one example if labels say 55 microfarady ( mf ) ( 55 mf ) get one of the same I am not saying it is a 55 mf capacitor vary depending on motor and brand. So check the label
Jul 23, 2009 | Danby Portable Air Conditioner
Power Issue?
unplug the satellite cables and restart the dvr. if the dvr powers up plug in the cables when u see searching for satellite.
Oct 11, 2008 | Directv HR10-250 DTV Receiver
HARDDRIVE FAILED
Get a new V3000 hard drive. They are cheap. That hard drive is corrupt.
Aug 14, 2008 | 3Com NBX® V3000 (3C10600BUS)
Random crashes of 3Com NBX V3000...
Call 8008763266. Also check 3Com Primus Knowledgebase for savecore procedure.then check nboss.log.
3Com NBX Support Team
Feb 12, 2008 | 3Com NBX® V3000 (3C10600BUS)
3Com NBX® V3000 (3C10600BUS) Logo
440 people viewed this question
Top 3Com Computers & Internet Experts
micky dee
didi2005
john smith
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
