Question about Maytag Appliances Over-the-Range Microwave Oven
Mmv4205aaw turns off - Maytag Appliances Over-the-Range Microwave Oven
  • Maytag Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Posted on Aug 07, 2010
Why turntable will not turn
You either have a bad turntable motor, or else a bad (broken) shaft coupler.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
May 08, 2014 | Kenmore Microwave Ovens
Change Motor but turn table does not turning?
test the following steps and fix it. God bless you
Turntable Motor
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Touchpad and Control Panel
If the microwave turntable doesn't turn the touchpad and control panel might be defective. This is not common. Test the turntable motor first.
Touchpad
If the microwave turntable doesn't turn and the touchpad has a button to turn the turntable on and off the touchpad might be defective. Check the turntable motor first, that is more likely.
User Control and Display Board
If the microwave turntable doesn't turn the turntable motor might be worn out. This is a common problem and relatively easy to replace. If the motor is good, the user control and display board may be defective.
Main Control Board
If the microwave turntable doesn't turn the turntable motor is usually the problem. If the motor is good the main control board might be defective
Jun 16, 2013 | Microwave Ovens
My rollers don't turn
may sound stupit but are the rollers clean and does the pice in the middle that turns them turn when its not in or is the wrong playe in there or your belt could be broken that turns it
Sep 28, 2012 | Microwave Ovens
Hi. I accidentally ran my Maytag MMV4205AAW on high power for about 15 minutes with nothing in it. After I stopped it, it wouldn't come back on. No surface light - nothing. My circuit breakers are...
i personally do not recommend to a consumer to work on microwaves. they retain alot of voltage!
but will refer you here....
http://www.appliancepartspros.com/repair-help/maytag-microwave-mmv4205aaw-repair/mmv4205aaw-wont-start.html
Jan 14, 2018 | Maytag MMV4205 Microwave Oven
I have an over the stove microwave. It was working and then went out. I changed the 20amp fuse and still nothing. there is power to it from the outlet. the clock and all the buttons do not work. model...
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 17, 2011 | Maytag Appliances Over-the-Range Microwave...
HOW TO REPAIR MAYTAG MMV4205AAW MICROWAVE NOISY FAN
unplug and take apart and more than likely something is hitting the blade or it has slid down the shaft and is hitting the motor or the cover if u pull the blade off and plug in and it dont make the noise then the blade is hitting something if the motor is still making a noise then the motor needs replacing
Jan 11, 2010 | Maytag Appliances Over-the-Range Microwave...
Maytag Microwave Oven (MMV4205AAW) won't power on.
You will need to replace the 20 amp. ceramic fuse inside the unit. This is real easy and the fuse only cost around $10.00 You will find a break down of your unit at www.partselect.com just enter your model number and a break down will come up. Your part number is PS2052772. You can also locate where the part goes. Good luck.
Oct 15, 2009 | Maytag MMV4205 Microwave Oven
Turn table doesn't turn
Is the plate engaging the drive?
Jun 15, 2009 | Kenmore 63792 Microwave Oven
MICROWAVE WILL NOT HEAT
check the connections on the h.v side because the unit works on 4500 volts and if there are any bad connctions it will not reach its working voltage and will not energize.remove all the connections 1 at a time and tighten all the terminals and try it again.you will not be able to test the components with a digital multimetre as it does not have the range.you need an analoge unit with a 10k scale and a 9 volt battery inside or it will give you falsr readings.teh diode which is thge little black unit with 1 side down to earth should read half way with the laeds on 1 way then when you put it on the opposite side it should not move.the capacitor will make the needle of the multimetre flick up when put onto the terminals both ways.the magnetron should have a short reading on the terminals but with 1 connected to the terminal of the input and 1 to the case it should not read at all,hope this helps regards les
May 15, 2008 | Maytag MMV4205 Microwave Oven
Function of thermostat-switch
We have *critical* safety, disassembly, and troubleshooting info at our
site, and our link is at our listing here on FixYa:
http://tinyurl.com/yzjozk
Once you\'ve looked those over, here are some links on part testing:
http://www.microtechfactoryservice.com/cap_test.html http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
You can usually find helpful exploded view diagrams and order parts by
entering your full model number here: http://tinyurl.com/gv383
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Jan 08, 2008 | Maytag MMV4205 Microwave Oven
Maytag Appliances Over-the-Range Microwave Oven Logo
75 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
