Question about Frigidaire Kitchen Ranges
On a Frigidaire slide in range (FES300EBC)how do I remove the front control panel to replace a burner switch?
  • rchilders1 Aug 05, 2010
    Thank you to GODBLESSU, rank Wiz!
    Brigadier General:
  • 3,513 Answers
Hi
The burner switch is not that hard to replace. It is located behind the display panel and comes out by removing the knobs first and then the screws holding the panel in place. I believe there are several screws located on the bottom of the panel and one behind each knob. You will need to open the oven door to see the bottom screws. If you attempt, make sure you turn the breaker off first and use care when taking the panel off. There is a wire harness to the control board that you need to be careful with.
First remove the glass panel by pushing back the 2 black clips at the top end,then remove 2 silver screws at the top and 3 at the bottom also remove 2 black screws behind side panels on the top. Now push side panels slightly up and forward and it fill fall forward and now replace the switch.
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 05, 2010
    Thank you! You were very helpful!
Replacing burner on slide in FES365ECA frigidaire stove
Good Afternoon Friend,
I understand you are trying to get assistance on how to access the burners on your glass-top Frigidaire range, model# FES365ECA. I suggest contacting the manufacturer. They might have some type of diagram that will assist you in replacing the burner. My other suggestion would be to contact your local authorized technician for further assistance. The technicians have been trained to replace parts on your range. Hope this is helpful.
-Best Regards-
WP
May 18, 2014 | Frigidaire Kitchen Ranges
Instructions for replacing the spark module on a DCS-305
In order to replace the Spark Module on your DCS-305, do the following:
  • 1
    Unplug the range from the wall outlet prior to servicing.
  • 2
    Remove the burner knobs from the burner switches on the front of the range. To remove the knobs, pull them straight away from the range. If the knobs are difficult to remove, wrap a piece of wire or string behind each knob for extra leverage.
  • 3
    Take off the bezel plate from each knob. Depending on the model of your range, this plate may be secured with screws, or the plate slides into place.
  • 4
    Remove the two screws that secure the valve panel then pull the panel off of the range. The spark module is now accessible for inspection, repair or replacement.
  • Oct 19, 2013 | Kitchen Ranges
    I have a es400 stainless steel stove. my right front burner stays on. please help .
    You have a problem with the hotplate controller. The controller is faulty and requires replacing. The controller can be accessed by removing the panel behind the controllers.
    Apr 01, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
    Frigidaire FES367ASE Slide in range
    Someone mis-wired the new control. Turn off the power to the range. Open the control console,switch the bake and broil wires on the oven control.
    Sep 22, 2009 | Frigidaire FEB27S5A Electric Single Oven
    Burner over-heating
    burner control for that element is defective
    Aug 13, 2009 | Kitchen Ranges
    How do you replace a burner switch on a Frigedaire Glasstop Stove
    The repair on this stove will be relatively easy then. All you are going to have to do is pull out the stove from the wall and remove the upper part of the back panel where the burner switches are.
    Remove the knob and take out the screws that hold the switch to that front panel. Then from there just match up the wires to the new switch off the old one.
    This repair will turn out to be pretty cut and dry for you. If you have anymore questions please ask.
    Thanks Again,
    Bill
    Jan 10, 2009 | Frigidaire FEF366DC Electric Kitchen Range
    Where is the fuse panel located in Frigidaire Professional Series Slide in Cooktop range?
    I can help , The fuse panel/control board is located behind the digital display in the front of the unit. Some drop in ranges are tricky getting into so be carefull when removing the face , there are screws under the display when opening the oven door look up and there may be a few more on the top side corners reveled when you pull the unit out 12" or so. there is a small glass fuse in the board some of these are not removable so if there is no digital display on your oven and your sure you have 240V to control board you will need to replace the entire control board. Hope this gets you there. Good luck let me know if you have anymore problems.
    Phil
    Dec 31, 2008 | Frigidaire 30" Self-Cleaning Slide-In...
    Help in Removing Frigidaire Smooth Cooktop Burner
    What holds the spring assembly onto the bar assembly is just two small prongs. Use a pliers on the end that protrudes through the bar, squeezing the prongs together, and it should come out fairly easily.
    Oct 14, 2007 | Frigidaire FEF336BC Electric Kitchen Range
    Kitchen Ranges Logo
    324 people viewed this question
    Top Frigidaire Kitchen Ranges Experts
    Ismael Rodriguez...
    Paul Carew
    Justin Duby
    Justin Duby
    Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
