Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
On the clutch and brake peddle the clutch engadges at the very end of the peddle. The brake is working fine but as you let the peddle out on the last 1/16 of an inch the drive engades. this makes it where you can't get close to anything. I put a new belt on it and it is still out of ajustment.
    Brigadier General:
  • 3,911 Answers
If you replaced the belt then you know there is a tensioner/guide pulley and another pulley which goes in and out with the clutch pedal movement to take slack out of the belt. I would closely examine both of those as well as the linkage and return spring on the clutch pedal.
Posted on Aug 05, 2010
Blades wont engadge belts on
This would be either the clutch relay, pto switch or pto clutch, check the relay first, then the pto switch, and lastly, check the clutch, if the clutch tries to engage with switch, then the switch and relay are good, and the clutch will need adjusted or replaced
Oct 16, 2013 | Mtd Garden
Niose when clutch is engadged
That would be the clutch release bearing (also called the throwout bearing).
The bearing is a sealed unit that eventually wears out and needs replacing.
Unfortunately, the only fix is to pull the transmission and replace the bearing.
And while you're at it, you might as well put in a new clutch and pressure plate while it's apart. Or not, depending on your budget. The release bearing runs in the neighborhood of around $40. If you can stand the noise, the bearing may last for quite a while, but eventually it may sieze and leave you stranded.
Good luck.
Nov 25, 2011 | 1998 Ford Escort
1991 GMC Sonoma manual transmission won't shift into gears, won't move, is it the clutch?
Usally when the clutch is bad, you still can shift gears. Check the slave cylinder or air in the fluid line. Good luck
Dec 11, 2010 | 1991 GMC Sonoma
The clutch peddle will not come up it stays on the floor
Check on the upper part of the pedel to see if the clip that connects the pedel to the clutch master cylinder has poped off If the clutch pedel is on the floor this is a likely sulition and relitively easy repair you just reattach the clip
Nov 06, 2010 | 1992 Honda Accord
Rear brake lights always on
you have a badbrake light switch
Feb 10, 2009 | 1992 Daihatsu Charade
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
132 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
