Question about Iomega Silver Series 320GB 3.5 External - 7200, 8MB, USB 2.0 320 GB Hard Drive
I have a 320 gb iomega external hard drive it keeps beeping and is not being recognized
  • 6,831 Answers
Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
Posted on Sep 29, 2010
My pc doesn't recognize my iomega external drive. when i turn the drive on it beeps.
Does it work on any other computer?
Beeping normally means a post code error
Nov 28, 2010 | Iomega 1.5TB Desktop USB Hard Drive
My Iomega external hard drive was working this morning but now will not open. Thgere is power and seemingly activity but my desktop either does not see it or does not recognise it. it also sounds as though...
My Iomega external hard drive was working this morning but now will not open. Thgere is power and seemingly activity but my desktop either does not see it or does not recognise it. it also sounds as though the drive is beeping
Aug 09, 2010 | Iomega Silver Series 320GB 3.5 External -...
Need to find drivers to be able to use my portable hard drive
iomega website download the driver there or
you may try control panel /add remove hardware /
it may have retained the driver in c drive
http://go.iomega.com/en-us/?partner=4760
Jun 15, 2010 | Iomega Silver Series 320GB 3.5 External -...
Beeping noise
Check the drivers for the hardware.
Jun 12, 2009 | Iomega Silver Series 320GB 3.5 External -...
Iomega lphd160-u beeping
Your USB port does not have enough power to support the drive. You will need to use an external power source or try a firewire cable if the drive has that option.Travis Cable
Mar 29, 2008 | Iomega (33600) 160 GB USB 2.0 Hard Drive
NTFS hard disk not recognized as 'RAW' iomega hdd160
format this with NTFS to recognize by your computer, RAW means no file system
Dec 02, 2007 | Iomega HDD External Desktop (32660) 80 GB...
Iomega Silver Series 320GB 3.5 External - 7200, 8MB, USB 2.0 320 GB Hard Drive Logo
686 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
