Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
I tried to pull out a piece of paper...and I did a bad thing to the cartridge box...now makes a terrible noise and races back and forth. Ow. I need an expert or is there something i can do? A Workforce 30,,,still under warranty...only a month old.
    Genius:
  • 1,478 Answers
This is quite unfortunate, but there are few things you can do, remove the cartridges on the printer, power off the printer, check the inner part to see if there are still pieces of paper left inside, turn the printer upside down and check very well to ensure there are no papers traces on the printer roller or any part of the printer.
Put back the cartridge and power on, if it is still same problem, power off the printer and power on back, while the printer is warming up or loading, pull out the plug from the AC wall and wait a while before putting the plugging the printer back, this hard reset on the printer, it should fix the problem.
If with all this, the is still not solve, i will advice you return the printer to the dealer to fix, since it is still under warranty, that will even put your mind at rest, because, it may be mechanism problem.
Take care.
Posted on Aug 05, 2010
Error code 5100
Hi You can Try 2 things.
ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
May 10, 2010 | Canon PIXMA MP830 All-In-One InkJet...
For Epson NX400 printer. I need to change cartridges. How?
Turn on printer, imediately unplug power when carriage moving. Unplug usb. Move carriage by hand to replacement position.
Jun 24, 2009 | Epson Office Equipment & Supplies
1600n grinding and jamming
hi....take it to a tech to check about the system control chip... the control chip would have gone bad... and they will replace u with a new chip..or else Try manually moving the head carriage back and forth a few times!
Also check, if there isn't some piece of paper lodged inside, if yes try to remove it carefully!..
these are the possible solutions u can try out...
thank u
rate me
Jun 11, 2009 | Dell 1600n All-In-One Laser Printer
Brother MFC-9420CN Paper Jam Error message w/ loud grinding noiz
please try this
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jun 09, 2009 | Brother MFC-9420CN All-In-One Laser...
Will not print / cartridges will not move back and forth
I had this happen to me the other night and I had to restart the printer to get the print job out of the que. You could try that.
While it's restarting, unplug the power cord and the usb cable. That should reset it.
Jun 21, 2008 | HP DeskJet 5550 InkJet Printer
Stuck cartridges
thanks but the ribbon that pulls the cartridges back & forth actually broke,
had to get a new printer
May 28, 2008 | HP DeskJet 932c InkJet Printer
Hp photosmart 7760
Try to see if there're any Paper Pieces left while you were removing the rest of them. If you find there any, remove then retry. If this fails, contact the Service Center.
Sahaja Yoga is FREE OF CHARGE.
Apr 26, 2008 | HP PhotoSmart 7760 InkJet Printer
PAPER JAM THAT REALLY DOESN'T EXIST
make sure the back cover (black panel) is fully closed. If it is, remove the panel and shake gently to make sure nothing has fallen inside.
Mar 12, 2008 | HP PSC 1510 All-In-One InkJet Printer
Terrible noise when printing
turn off, remove the cartridge and turn back on, do you hear the noise? if no then it's the cartridge
hope this helps
Jan 07, 2008 | Samsung CLX 3160fn All-In-One Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
14 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
