Question about Velodyne FSR-12 Speaker
My FSR12 oscillates a 1 second intervals with full woofer excursion. I have replaced the main amplifier 4040 chip and still have the problem. Both the 45 volt and 12 volt supplies are stable. Velodyne no longer supports the model but did send schematics. I was told that the accelermeter is attached to the voice coil and does not appear easy to get to without tearing off the dust cap. The ocscillation is not affected by disconnecting the 4 condutor flat cable to the accelerometer. Might the amplifier go full voltage while waiting for feedback from the accelerometer? Is there anywhere to buy an accelerometer for this model? Thanks in advance for your thoughts.
  • 1 more comment
  • fmk1x Aug 06, 2010
    FSR-12 Speaker
  • Scott Kohn Dec 31, 2011
    I have a similar problem. The sub has a strong white noise despite input and volume and cutoff. If I disconnect the accelerometer I get full excursions of the driver. My +45V rail is pretty close to 45V and has less than 0.1V AC ripple when checked without input signal and the speaker and accelerometer disconnected. This section of the PCBA is dark and charred looking and C17 is measuring 1.7kOhm (when it should be a 10uF cap). Hoping that if I replace this cap and maybe some of the other nearby components it will work properly again.
  • Scott Kohn Jun 23, 2012
    I ended up bypassing the feedback portion of the circuit. The audio quality is acceptable. for now. I cut a resistor lead and soldered in a jumper wire to do this.
  • 5,807 Answers
Hi
fmk1x,
Sometime it also ( accelerometer) get loose
Another trick , is to isolate the Main Amp Input to the Preamp
output and check.
• While it is disconnected , Measure the Offset voltages on the
Main Amp Out ( without the woofer connected ).
Here are sample schematics:
and another one
Source:
[PDF] STK4040V AF Power Amplifier (Split Power Supply) (70W min, THD ...
A good amp never produce an over of 0.7V on its output.
Posted on Aug 06, 2010
  • 1 more comment
  • Rommel Cana
    Rommel Cana Aug 06, 2010
    post the DC offset value , to help you further
  • Rommel Cana
    Rommel Cana Aug 07, 2010
    • Have you tried disconnecting the Main input? just to see the results
    If still does , then Check every components on the Main Amp
  • Rommel Cana
    Rommel Cana Sep 02, 2010
    I just hope these answers your problem.
    thanks for choosing Fixya for assistance!
    President:
  • 4,070 Answers
Hi! You may want to inquire at audiolab.com regarding the accelerometer. Have a nice day!
Posted on Aug 05, 2010
  • dj_relly999
    dj_relly999 Aug 06, 2010
    Hi! HOw was it?
My sub woofer making noise like machine gun w out connect toamp
Disconnect the sub-woofer and see if the noise stops, if so the amplifier is OSCILLATING and so produces the noise.This can be related to fault with the pre-amp or audio processing section. Try and heat up the circuit using a hair dryer and if the fault clears then there are faulty electronic capacitors. If leak is seen then the pcb must be washed after the capacitor is replaced which can solve the issue.
Mar 12, 2012 | Infinity BU-120 Subwoofer
Subwoofer is not playing
It is hard to say. The sub-woofer has its own amplifier, although it is supplied the sound data from the main amplifier. It could have a problem with the battery power circuit (Sub-Woofer Amplifier Connector Pin 6, LIGHT GREEN/VIOLET) or it could have a problem with the GROUND circuit (Pin 2, BLACK/LIGHT GREEN) Or it could possibly not be receiving the signal from the main amplifier (Pin 7, BROWN/ORANGE "+"), (Pin 8, RED/BLACK "-"). Or it could be that either the sub-woofer speaker is blown, or the sub-woofer amplifier is defective.
There is also a "High Audio Mute" circuit that connects between the main amplifier and the sub-woofer amplifier.
Mar 06, 2012 | 2000 Lincoln Navigator
Power was given to the Woofer and main board of MX5021 without connecting satellite speakers. There was a sound (may be some device burnt out) and the system became non -functional. The service...
Ideally since this a audio amplifier you can replace with the types that are in the market which can be done up by a competent service engineer.
You can choose the power output based on the wattage of the woofer as some of these companies do not have good support base and spares will be hard to find for a full board replacement. So if your speakers are in order then you can have this choice-- get opinion before you invest or else buy one home theatre amplifier off the shelf that suits the speakers.
Aug 24, 2011 | Altec Lansing MX5021 System
Where on my mixer should I plug the subwoofer into? Or would plugging it in somewhere else be better ?
This will depend on whether your sub-woofer is powered (has it's own built in amplifier) or not. If it is not powered it will need connecting to an amplifier. If it is powered you will need a line level output either on the amp or the mixer.
Many modern amplifiers (and some mixers) have a dedicated output for sub-woofers in which case this is the best place for it because the higher frequencies will have been filtered out.
Some high quality amplifiers like the JAMO MPA 101 have a filter switch and adjustable filter level for powering sub-woofers. You then just connect the speaker to the speaker terminals in the normal way.
Otherwise on a p.a. mixer you could use the main output, one of the auxiliary, monitor or sub-mix outputs. If you are not using the main output you will need to route signal to the appropriate output accordingly. Either way your output signal will cover the full frequency range - your subwoofer may have built in filtering or you may need to use some sort of crossover to split the signal between the sub-woofer and the rest of your speaker system.
Feb 25, 2011 | Audio Players & Recorders
I have a rockford fosgate 1001d and 2 audiopipe dvc 12s need 2 know how wire speakers
Check to determine if your sub woofers are DVC 4OHM or DVC 2OHM SOLUTION 1 If your sub woofers are DVC 4OHM then, from the positive (+) of the amplifier run your cable to the positive terminal of voice coil 1 on sub woofer 1 then continue to connect all the positive voice coils together on both sub woofers. Do the same for the negative from amplifier to all the negative voice coils of both the sub woofers. RECAP: all positives together on the positives and all the negatives together on the negatives. This will give you a 1 OHM load to the amplifier making it deliver all its power but will also run hot. So if you are living in a hot climate take care. SOLUTION 2: Connect the negative on voice coil 1 to the positive of voice coil 2 on sub woofer 1 Do the same for subwoofer 2 now you should have a free negative and a free positive on each of the sub woofers. connect the free positives together and follow through to the positive on the amplifier. do the same for the free negatives sending them to the amplifiers negative. This will give you a 4 OHM load to the amplifier. Not full power in this mode but the most stable working condition for your amplifier. SOLUTION 3 If your sub woofers are DVC 2 OHM then you only have one reasonable wiring solution. Connect like solution 2. This time because of the DVC 2 OHM sub woofers you would have a 2 OHM load to the amplifier. This is also a stable load for the amplifier and does not generate to much heat and still deliver over 50% to 70% of the amplifiers power. good luck and drop me a line if you still have doubts. dreamsystems
Feb 10, 2011 | Car Audio & Video
Amplifier shuts down after 30 secs of loud playing
Could be a couple of different things. It's more than likely the wiring between woofer and amp is the problem. Check the Ohm load on the woofer to make sure it's compatiable with the amp. If your woofer is wired at 1 Ohm, and the amp can only take a 2 Ohm load, it would cause this problem. Also, are you having any issues with the voltage of your car? If your car's current electrical system can't keep up with your higher power demands, then it might also casuse this problem. I would check the wires first.
May 27, 2010 | Solid Audio F15D 1-Channel Amplifier Car...
Power not running constantly through amplifier
You might check your ground cable for poor connection. If it is attached to the painted chassis of the automobile, the paint needs to be scraped off a little. Or go to a local audio shop or Walmart and buy a cheap capacitor. It is supposed to hold power in itself providing the amp constant power for just this reason.
Dec 07, 2009 | Infinity Reference 7541a Car Audio...
Can't take the amplifier board from cabinet
The reason the woofer is pushed back is the power amplifier is sending DC voltage to it. This means that you have some kind of failure in the amp and need to have it serviced before you burn up the woofer, if you haven't already.
Mar 13, 2009 | Fostex PM-1 MKII Main / Stereo Speaker
Fried Woofer
The problem are worsen that before. It is wisely to replace both left and right amplifier
IC, but make ensure that the power supply feed a good amount of voltage to amplifier,
Also a strong good signal. Be sure to measure it.
r_ic7
Jun 22, 2008 | Alesis M1-Active MkII Main / Stereo...
Amp light is on but no power to my subs!
Hi There.
When you say the 40 Amp fuse blew. Was it your mains battery fuse or was it the fuse on the amplifier? If it was the fuse on the amplifier then you may have hurt the amplifier. The Kenwood KAC-8101D is a 1000 Watt monoblock amplifier. Therefore if you say that 1 of your woofers is not playing, then it is almost certainly blown if you are sure it is connected correctly. Try disconnecting it and only running the woofer that tries to play. If this woofer is still working correctly, you will notice a drastic drop if the sound of your bass. The reason for this is because you have changed the impedance load on your amplifier due to the fact that the other woofer is not working. Have your working woofer checked and replace the faulty woofer then you should be banging again.
Hope this helps!!
Jan 30, 2008 | Kenwood KAC-8101D Car Audio Amplifier
289 people viewed this question
Top Velodyne Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
 Grubhead
Grubhead
Are you a Velodyne Audio Player and Recorder Expert? Answer questions, earn points and help others
