Question about LG Studioworks 57M Monitor
When I connect the input supply of monitor it goes off after a few second a sound of relay operation comes.its front indication light glows green but no light on screen. the CRT filaments glows. please guide and also provide a circuit diagram of the monitor on my e-mail thanks
SOURCE: Sony Trinitron K29 inch CRT TV screen shows green shade!
i have the same problem with my sony trinton tv 36 inch if you know how to fix this please email me on amir.dhawan@gmail.com
Posted on Jan 03, 2008
SOURCE: monitor LG FLATRON E700SH
Sir,
I hve read all above statement which shown as above. but in my case monitor take time to ON and display the screen, its take at least 45 minutes to start up and display the window screen. So please to send me solution about my Query.
Thank's
Posted on Oct 11, 2008
  • 1684 Answers
SOURCE: Screen comes up for about 10 seconds, then goes blank
Hello Robert,
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
Over 21 years of computer and printer support/repair
Posted on Jun 19, 2009
SOURCE: LG Studioworks model (500G)CRT Monitor flickers most of the time
lg 500g studioworks green color
Posted on Sep 03, 2009
paulbtorrent
  • 34 Answers
SOURCE: My monitor shuts off(goes blank for a few seconds
The monitor is doing a self test a finding an error.
The lcd has three parts, the screen plate(windows)/the logic(vga)/the inverter(power plug). Parts that go are the backlight ccfl's, behind the plate, and parts of the inverter, ie capacitors, all three take a bit of power from the inverter. The self test check that all the lights are ok and the inverter is ok, else it switchs off, ie if 3/4 light work it will switch off(my own case), hence the on chech error then off, However sometime there are stages of on/off ie on/ but no screen display, if that is the case the following may be of help...if you put bright light at an angle close to lcd can you see a windows shadow, text icons etc, ie still logic power passing,then .... (from a.n. other) after two weeks searching I finally find doctor living stone http://www.aplusperfect.com/articles/lcd_capacitor_repair more fun with paulbtorrent
the takening the case bit off is like opening your wallet a second time after buying a new LCD, but you must! smallest two screw driver's flat headed, practice using two pennies stuck together()with your fingers after, one little () move and inch and {} again, with the case , it does not break, just need to lever open
[once open you realize they somehow put that old briefcase clip inside!] also note the bright light test to do first to see if can see a windows screen , and that capacitors are one for a number of things that a make a inverter work! there a transistors as well, given that however, to replace all the capacitors on my inverter, was 11 capacitors, cost me $11 (uk ebay) and already had the iron and solder. So only cost me me $11 to try and see but no luck , still fun and I still can see the screen for 2 sec' at a time plus I have a spare set of caps now in the event that the new one do go burst! you have to laugh really, what next , a new on/off button, as you work though the whole inverter mmmMMMMmmmMMMMmmmMMMMTim Berners-leeMMMMMmmmmMMMMMmmmmcome back all is not wellMMMMMMMMMMnnnnnnweek later land sight mmmmmMMMMMMMMMmmmmgggggggg(from
another a.n other)Generally, if the screen went out quickly, it was the inverter. If it went out over a slow period of time (flickering etc..) I would bet it is the lamp.replaceing the lamp should be pretty challenging. as that requires complete breakdown of your LCD, extraction of your dead lamp, and soldering in your new lamp... but I would like to say that I it did this after realizing it's 2 x kitchen strips inside [========] with wires that can connect back to the inverter with out any desoldering(ie kit assembly/dis) with the outter case remove (glass plate safe away) I could reconnect and see that 3/4 were working (i!i hardcard ) cause the inverter to switch off after a secound ! order bult and replace and going
to cheap and see if I can get away with fitting a 15" in my 19' as it a 1/3 of the price ! the market as drop out there, hope the inverter does not miss the length, or the screen out put.http://www.lcdparts.net/howto/troubleshooting/LaptopCCFL1.aspx OR MONITOR
Posted on Feb 08, 2010
I have a Mitsubishi VS-50501A Rear projection TV. When I push the power button the green comes on for a few seconds then goes out. The TV will not power on.
This one may or may not have the self check:
when green light goes out on front of set press menu and input (device) buttons at same time and hold for at least 5 seconds and let go: if it has self check power light should blink a two digit error code and repeat it several times.
If no response it indicates some problem in main power supply (set is in shut down)
I need to know what skills you have; what I have seen mostly in these early sets is bad solder connections that develop on main boards; I can tell you where and what to look for but it involves getting at the boards and being able to solder.
Before you rate this information let me know what you find and remember I am here to help you.
SD TECH
Aug 15, 2011 | Mitsubishi Televison & Video
Getting a P1391 error code on my 01 Caravan, Changed PCM Sensors, wires, plugs, EGR, Whats Next? Please
P1391 Glow Plug Circuit Low Input (Bank #1)
  • DTC P1391 or P1393 will set when the monitor indicates that all four glow plugs are not being powered on that bank. An open in the glow plug circuits, glow plug relay, glow plugs or monitoring circuit could be the possible causes.
    Both DTCs P1391 and P1393 together will set when the monitor indicates that all eight glow plugs are not being powered. An open in all glow plug circuits, the glow plug relay, glow plugs, fusible links or all three monitoring circuits could be the possible causes.
  • Possible causes:
    • glow plug relay
    • glow plug shunt
    • open in glow plug circuit(s) or monitoring circuit(s)
    • glow plugs
    • PCM
__________________
May 19, 2011 | Dodge Grand Caravan Cars & Trucks
When you plug its power supply, the indicator light green color will appear, then it goes out after a few seconds..
If you don't have a computer connected to it that is powered ON then thats normal, its going into stand by.
Jan 18, 2011 | ViewSonic VA712 17" LCD Monitor
The Dell AS 501 monitor display comes and goes off in seconds. If I switch off and on again, the display comes back and goes off again in less than a second. I repeat this as many times the same monitor...
This sounds like the power inverter is failed.. It's what pumps up the power for the light in the monitor.
You could try unplug the sound bar from the back of monitor if you have the sound bar installed. Just a maybe..
To fix the inverter (replace) is usually better to buy newmonitor unless you do it your self.
The defective LCD Backlight inverter will cause the following symptoms:
  • No Display, but Power Indicate light stay on green (Or Blue).
  • Screen flash on and off and the power indicate light stays on green (or Blue).
  • Dim Display
Go here to start looking if you want to try yourself. http://www.lcdparts.net/DI3D.aspx
Dec 27, 2010 | Dell Computers & Internet
Screen Goes Blank
Ive seen this on other monitors. Look for a 1 and 2. Some monitors do NOT auto detect a signal, and this one might not. Look for a way to set the monitor from Digital input to VGA input. Try that and see.
Jul 21, 2009 | Dell E173FP 17" LCD Monitor
After monitor is turned on, it goes blank after a few seconds...
Sounds like the cable that connects the monitor to the computer hass a loose wire connection in it.
When it turns green, try flexing the cable near the connectors and see if the color changes on the monitor. I suspect that you have a wire in the cable that was not soldered properly by the manufacture.
If it changes color, I'd contact who you bought it from and have them replace it.
Hope thid helps. Bud
Jan 08, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Plasma screen
supply problem. check the power supply of the controlling unit. not stable.
Jan 14, 2008 | Gateway FPD2275W LCD Monitor
No power up
http://i133.photobucket.com/albums/q68/rwlib3/DSC_0426.jpg
IT might be blown capcitor
If a capacitor blows out, then it is probably having a higher voltage
on it than it is rated for. You don't say what the voltage rating was
for the original capacitor or what the voltage rating was for the
replacement. Did you try to measure the voltage in the 10 seconds
before the replacement blew??
Dec 23, 2008 | Sylvania 6842PE 42 in. HD-Ready Plasma...
LG Studioworks 57M Monitor Logo
19 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
