Question about Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac
My power blower will start but only runs a few seconds & dies. We put a new spark plug in it which didn't help because it starts fine. We recently had to mix a new container of gas for it with the 2-cycle oil/gas mixture & wonder if there could be a problem there but we put the right combination in it. I'm not sure how old it is but we have never had this problem before.
    Problem Solver:
  • 5 Answers
If fuel left in system for any length of time.. more likely the fuel lines and primer bulb. And 9 out of 10 times not the limiter adjustments.
Posted on Jan 01, 2011
    President:
  • Poulan Master
  • 1,545 Answers
These little engines require maintenance just like your car does....even more than just a spark plug change. They have issues with parts in the carburetor going bad, carbon build up in the engine and muffler and sometimes even ignition problems. A good bet most of the time is a fuel delivery issue so you have to start with your fuel mix (you said was good) go to the fuel tank (where there is a fuel filter)...the fuel lines (which deteriorate over time and tend to mess up the carb when they do)...etc. Start with the basics and continue on. Rebuild kits are available for the carb and its not too hard...that may be what's needed as the new ethanol laced gas we have is hard on the small carb parts.
Posted on Aug 10, 2010
Have an '89 FXR Harley 80 cu in new motor. Today I fire it up and it only runs for a couple of seconds and dies. Starts right back up and dies few seconds later.
Mate ever motor needs spark and fuel to run. My opinion spark is ok so fuel, When did you last put fuel in it... If very recent then water in fuel, Maybe even air filler dirty, Definitely fuel problem.... Good luck
Mar 18, 2016 | Motorcycles
My craftsman 25cc leaf blower wont start
pull the plug, plug into wire, touch head of plug to metal on engine. hold by rubber boot while touching pull starter, see if you get a spark across the plug gap, its small but you can see it. if no spark check switch. if plenty of spark clean fuel system and check primer
Nov 04, 2014 | Garden
I have a Red Max HBZ2600 Z Power blower that starts runs a few minutes then slowly dies. Fixable?
Install a new spark plug
Clean or replace the air filter
Use only gas that is no more than 2 months old
& add fuel conditioner such as Sta-Bil or B&S,
unless you have to mix fuel for a 2 cycle motor
Once running & fully warm,adjust carb screws for
fuel mix at idle & fast rpm, then set the idle
Check for spark with a small engine tool avail for that
It looks like a spark plug with a clip on it & avail many places
May have to remove the carb,clean it & install a new kit,if
you still have problems
Jun 09, 2014 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Unable to start my craftsman blower/vac model 358 797931
check your fuel filter, and make sure your gas is no older than 6 wks old. you may have a slug in your carb, you may have to clean your carb
Nov 14, 2011 | Garden
Snow blower 1 year old, was using it ran out of gas , put in new gas, went to start, it ran for few seconds then dies,, prime it it runs few seconds dies, has NEW gas ans new plug, only runs for seconds...
If it has a fuel filter on it change it and that should get you going again. If not the dirt that was in the tank is prob in the carb cleaning the fuel bowl and jets should get you up to par. Hope that helps
Feb 02, 2011 | Sport & Outdoor - Others
What is wrong with a Toro GTS5 that starts well but dies 5-10 seconds later. I have changed the spark plug, air filter and oil. New gas too. Any suggestions? Thanks.
I had a similar problem. I'll bet I took off the carb. 5 - 6 times and cleaned it with no success. Very fustrating! One time while checking the fuel level I accidently left off the gas cap, I started it and while running I put the gas cap back on and started to mow and about 10 seconds it died. I thought could'nt be! So I loosened the cap, restarted and it kept running. Any way the small vent hole was plugged. Thats my story!. Good luck.
Aug 20, 2010 | Toro Lawn Mower With Toro Power Tools
1987 Bayliner capri 85hp force starts and idles fine,after it
if u have a seperate onboard tank i bet its the vent valve is closed
Feb 21, 2010 | Raymarine Linear Feedback Unit For...
Runs 10 or 20 seconds and simply dies
Hello. I recommend that you install a new spark plug and put some carbeurator cleaner in with your gas. i like a product called seafoam. just follow the directions on the container.
Nov 24, 2009 | Husqvarna Forest & Garden #965102302...
My Toro lawn mower won't stay running. It will start every time and then just die.
You need to check a few things. The spark first, you need to check if it is running correctly, does it have spark, by doing this: take out the spark, put it against a metal surface and pull the pull start if it spark, your good if not you need a new spark plug. Clean out your airfiilter it migth help too. Buy some carb and choke cleaner squirt it up theough the airfilter hole, and start the engine, this will clen the carb. yOU MIGHT NEED TO TAKE OUT THE CARB AND CLENA I OUT THROUGHOULY!!! Try that and it whould work after all these steps!
Apr 10, 2009 | Toro Lawn Mower With Toro Power Tools
Starts and runs fine when cold, dies after 10 to 15 min.
i would try first change gas make sure its a mix of gas and 2 cycle engine oil,second new spark plug third make sure theres nothning in the gas line hope this helps
Apr 06, 2009 | Homelite Leaf Vac Attack
Poulan/Weed Eater #Wt200 711724 24cc Gas Blower/Vac Logo
350 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
