Question about Linksys Computers & Internet
The internet button is on, but I don't get internet from the router, only directly from the modem.
    Sergeant:
    Champion:
  • 277 Answers
This an wire setup gone wrong!
The wire you use to get the internet from on your modem, plugs into I believe a Yellow port at the back of your router.
The rest of the ports are for hardwiring each computer.
So your computer, We say #1, will have a wire from you LAN card at the back of you computer to port #1 on you router.
you will have to go into your windows internet setup to change some settings. So to do this
My computer, Control Panel, Internet setup.Internet wizard setup.
You no longer SAY you use modem for internet, but setup through router.
This will NOT be a new setup but an existing setup
Posted on Aug 05, 2010
Router can't detect wired connection
Try this:
1.turn off power and disconnect all wires and cable to and from modem.
2.re-connect after 2 minutes.
3.do the modem buttons light up, including internet.?
4.now check if you get internet connection. you don;t need the wiz because you are hard wired thru cable from ISP?
GOODLUCK
Jan 24, 2014 | Asus US RT-N65U dualband wirelessn750...
Solid yellow Internet light on D-Link DIR-825
Try a new working LAN cable between your internet modem and the router. Is your internet modem connected and working? You should be able to directly connect using a LAN cable to check the modem connection. Reboot your modem and router.
Nov 16, 2011 | D-Link DIR-615 Wireless Router
I don't know how to reset password for d-link DIR-625
Section 1 - Product OverviewHardware OverviewConnectionsUSB Connect a USB 1.1 or 2.0 flash drive to configure the wireless settings using WCN.Reset Pressing the Reset button restores the router to its original factory default settings.LAN Ports (1-4) Connect Ethernet devices such as computers, switches, and hubs.Internet Port The auto MDI/MDIX Internet port is the connection for the Ethernet cable to the cable or DSL modem.Power Receptor Receptor for the supplied power adapter.D-Link DIR-65 User Manual
If you don't know it you can check our list of default router and modem password list here.
If you have changed it and don't remember it you may have to reset your device to factory default using the reset button on most routers.
Sep 23, 2011 | D-Link DIR-625 (790069292637) Wireless...
Wbr 1310 does not seem to connect to laptop. erthnet cable is connected from modem to wan port on router and another erthnet cable from port 1 on router to laptop erthnet connection. no...
connect your computer to the router and open internet explorer and in the address bar type, 192.168.0.1 and push enter. it might be 192.168.1.1, don't remember. login and setup your internet connection. if you have cable internet set it to DHCP. if you have DSL you will have to get the settings off the providers web site. you can also try resetting the router. with the power on, press the tiny reset button on the back of the router for about ten seconds. you will see the lights go out and come back on. once the router reboots try it again. Good luck.
Aug 14, 2011 | D-Link 802.11g Wireless Router WBR-1310...
Why can't I connect to the internet via my router but when I connect directly to the modem, I have internet access
If you don't reset the modem after connecting the router, the modem is still trying to send data to the MAC address of your PCs network card.
You need to disconnect power from everything, then power up the router first.
Once the LEDs on the router settle down, power up the modem.
Once the modem's LEDs have settled down, power up the computer.
You should now be able to access the internet through the router.
The only time this won't resolve the issue is if the PPPoE negotiation is being done by the PC and not programmed into the modem itself.
This is almost unheard of with modern DSL and ADSL modems today, but if that is the issue, you will need to contact your ISP for the information you will need to program the router to do the PPPoE login through the modem and reconfigure the computer to not do the PPPoE authentication any more.
Jul 21, 2011 | Linksys Wireless-G WRT54G Router
I can connect to the router on both of my computers and my ps3 but i cant connect to ther internet. also if i plug my modem into the router and then plug my computer into the router i cant connect that...
I think you will need to reconfigure the router.
You can access the Internet when you connect the computer to the modem. That means the modem is working fine.
Connect the modem to the Internet port on the router and computer to port 1 on the router. Press and hold the reset button on the rotuer for 30 seconds. Release the reset button and wait for 30 seconds. Power cycle the router and reconfigure it.
Follow this link to reconfigure the router.
Jan 17, 2011 | Linksys Wireless-G WRT54GS Router...
My router shows no connectivity.
Take your ethernet cable from the wan port and plug it into the lan port.
Nov 16, 2009 | Linksys Wireless-G WRT54GS Router...
Internet connection between linksys router
May be your router internet settings has been wrong. you must reset the router settings by clicking the router reset button. Pls locate the button and then put the internet cable into router internet port.
Jan 03, 2009 | Linksys Wireless-G WRT54GS Router...
Use of router in network
Try reset the router & cable modem. There ia a reset (very small) button on the back of the wireless router & the modem. Disconnect the power cords to both. Use a pen & hold in for 10 seconds (router & modem). Re-connect power (router & modem) & restart PC. If your service still has not returned. Chances are it's your internet provider & not you. Double check by connecting your modem directly to your PC.
Luck!
Mike
Apr 04, 2008 | Linksys Wireless-G Broadband Router
Computers & Internet Logo
113 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
