Question about HP Officejet Pro L7680 All-In-One Printer
When using scan feature in my HP 7680 printer any document I scan never scans to its original size, it always shrinks by at least 30%; how can I scan documents to original size?
Try checking your setting. press scan menu (over by the fax buttons) then choose paper size. you may have it on a smaller size. i have mine on automatic. See if that works.
Posted on Aug 05, 2010
How do i get my hp officejet j6480 all in one scan both sides and print
To automatically scan and print, you need to use the automatic document feeder (for letter-sized documents) and have the HP Automatic Two-sided Printing Accessory installed.
Then to use the duplex printing feature, you need to set the printer properties to use the duplex feature. In Windows, open a document to print then click on File Print. Choose Setup and then Properties or Preferences (depending on your OS). Then click on the Features tab and set Two-sided Printing to Automatic. (This is a drop-down menu on the Features tab.)
You also need to set the scan settings for two-sided in the HP Solution Center. (If you just want to copy the document, you can set this from the Control Panel on the J4680.)
If you want to do this manually, you can scan each side of the pages. Then print them one page at a time. Then when the ink is dry, put the page back into the paper tray. (Note: this could result in paper jams.) The printer prints on the underside of each page put into the paper tray with the top of the page printing on the forward part of the page.
I hope this helps.
Jun 19, 2012 | HP J4680 Office Jet All-In-One Printer
How do I reduce file size for scanned documents?
You're probably scanning at a high DPI or resolution. Try scanning at a lower DPI or shrinking the actual dimensions of the image in an image editing program.
File format is important also. .jpg files are compressed and take up far less space than .bmp files, for instance.
Sep 21, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
I'm trying to scan an A4 size sheet(document). I was getting the same size of the scanned sheet, but now its shrinked its size so that I can not getting the same size as in the sheet. Please help me...
Hi
Try the HP software rather than the Scanner itself.
HP Solution Center > Settings > Scan Settings > Scan Document Settings > make sure it is set to Scan Document as Image (no OCR) > Apply > OK.
I hope this helps.
Aug 24, 2011 | HP ScanJet 2400 Flatbed Scanner
Scan letter
Most scanners in my experience do not scan to "precisely" 8 1/2 X 11 inch letter size (assuming that was the original paper size).
A workaround is possible with some graphic programs. After importing the original incorrect scan of the document into the software a combination of resizing and/or cropping (depending on how your program works) will allow getting the exact dimensions. Then save as a new image document. Make sure to adjust for sufficient resolution (a larger document) if you plan to reprint.
Jul 25, 2009 | HP Officejet 5610 All-In-One InkJet...
HP Color Laserjet 2840 will not completely scan legal size docs
have you downloaded the scanfix that is own the HP support site?
May 22, 2009 | HP LaserJet 2840 All-In-One Printer
I have the officejet 6310 but cant use the scan feature, how do I get it to work
this is how you use the scanning features of your printer.
To use the scan features, the HP all-in-one and computer must be connected and turned on. The HP all-in-one software must also be installed and running on the computer prior to scanning. To verify that the HP all-in-one software is running, look for the HP all-in-one icon in the system tray at the lower-right side of the screen, near the time.
NOTE: Closing the HP Windows system tray icon can cause the HP all-in-one to lose some of its scan functionality and result in the No Connection error message. If this happens, you can restore full functionality by restarting the computer or by starting the HP Image Zone software.
For information about how to scan from the computer, and how to adjust, resize, rotate, crop, and sharpen scans, see the onscreen HP Image Zone Help that came with the software.
Scan an original
Follow these steps if the HP all-in-one is directly connected to a computer through a USB cable.
1.
Load the original face down on the right front corner of the glass.
2.
In the Scan area, press Scan To . The Scan To menu appears, listing destinations, including applications, for anything that is scanned. The default destination is whichever one was selected the last time this menu was used.
3.
To select an application to receive the scan, use the arrow buttons to highlight it and then press OK or Start Scan . A preview image of the scan appears in the HP Scan window on the computer.
4.
Make any edits to the preview image in the HP Scan window. When finished, click Accept . The HP all-in-one sends the scan to the selected application.
Send a scan to an HP Instant Share destination
1.
Load the original face down on the right-front corner of the glass or, if using the document feeder tray, in the document tray.
2.
Press Scan To on the control panel of the HP all-in-one. The Scan To menu displays.
3.
Use the Up Arrow and Down Arrow buttons to highlight HP Instant Share .
4.
Press OK or Start Scan to select the destination and scan the image. The image is scanned and sent to the selected destination.
NOTE: If an original is detected in the automatic document feeder, one or more pages are scanned. If no original is detected in the automatic document feeder, a single page is scanned from the scanner bed.
NOTE: For Windows users, the HP Image Zone software opens on the computer, and the HP Instant Share tab displays. A thumbnail of the scanned image will display in the Selection Tray. For more information on the HP Image Zone, see the onscreen HP Image Zone Help that came with the software.
Stop scanning
To stop scanning, press Cancel on the control panel.
May 16, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Scans @ 75-80% of original size..how do I get it to scan @ 100%
the only thing I can think is the scan or print settings on the printer itself. there should be a way to adjust the size from either the printer or the preferences on you computer in the print screen.
Feb 27, 2009 | HP Officejet 6310 All-In-One InkJet...
Hp psc 1215 wont scan with vista
Introduction Some products do not have full scan functionality in Windows Vista. This is because full-featured Vista drivers are not available for all products, especially older products. However, the Windows Vista operating system installed on your computer includes a basic print driver. This driver allows you to scan an original and save it as an image using workaround methods. You cannot use the advanced scanning features that you might have used with your product before you installed Microsoft Windows Vista. Scanning an original and saving it as an image Follow these steps to scan an original document, and then save it as an image. Step one: Load the original Follow these instructions to load the original in the product.
  1. Raise the top cover of the product.
  2. Place your original print-side down on the glass.
    NOTE: The engraved diagram next to the scanner glass shows exactly where to place the document (usually on the right-front corner or the left-front corner).
  3. Close the scanner lid.
Step two: Workarounds for scanning an original and saving it to the computer Select one of the following three workaround methods to scan an original and save it as an image. Method one: Scan with Windows Photo Gallery
  1. Click the Windows (c01319360.gif ) icon.
  2. Click Programs .
  3. Click Windows Photo Gallery . The program opens in a new window.
  4. Click File , and then click Import from Camera or Scanner .
  5. Click Import .
  6. Click Scan .
Method two: Scan with Windows Fax and Scanning
NOTE: This feature and the following instructions work only with Vista Ultimate, Vista Business, and Vista Enterprise versions of Windows.
  2. Click Programs .
  3. Click Windows Fax and Scan . The program opens in a new window.
  4. Click New Scan .
  5. Click File , and then click Scan .
Method three: Scan using Paint
  2. Click Programs .
  3. Click Accessories .
  4. Click Paint . The program opens in a new window.
  5. On the Paint toolbar, click File , and then click From Scanner or Camera .
  6. Click Scan .
Nov 30, 2008 | HP PSC 1215 All-In-One InkJet Printer
How do I scan a bunch of originals from the tray and get 1 file for each page?
Loading originals to scan
Use these instructions to load originals into your device for scanning. For the best quality
scans, use the flatbed scanner. See Selecting media for the automatic document feeder
(ADF) for guidelines on choosing original documents for scanning.
Loading originals onto the flatbed scanner
1. Make sure that the automatic document feeder (ADF) input tray is free of media.
2. Lift the flatbed scanner lid.
3. Place the original document face-down on the flatbed scanner with the top, left corner of
the document at the lower-right corner of the glass.
4. Gently close the lid.
5. The document is ready to be scanned.
CAUTION To prevent damaging the device, do not allow the scanner lid to fall onto the flatbed scanner
surface. Always close the scanner lid when the device is not in use.
Loading originals into the automatic document feeder (ADF)
input tray
Note The ADF capacity is up to 50 sheets of 75 g/m2 (20 lb) media (depending on the thickness of
the media), or fewer sheets if the stack fills the ADF.
The minimum size for media in the ADF is 127 by 127 mm (5 by 5 inches). For smaller sizes
use the flatbed scanner. The maximum size for media in the ADF is 215.9 by 381 mm (8.5 by
15 inches).
1. Make sure that the flatbed scanner contains no media.
2. Close the flatbed scanner cover and put the top end of the stack of originals into the ADF
input tray, with the media stack face-up and the first page to be scanned on top of the
stack.
3. Slide the stack into the ADF input tray until it does not move any farther.
If this helps you, let the Boss, FixYa.com Know...
May 13, 2008 | HP LaserJet 3030 All-In-One Printer
Lexmark X7350 Scan feature
well you are able to scan multiple documents.. but the file size is more.. the way lexmark software writes the pdf file.. the file will be huge for PDF... but not sure if this is a case with any other all in one manufacturer like HP also... but i would assume it would be the same.. so scan the file to MS WORD or any other application that supports multiple pages... so u have it as one file... but if u want only pdf files, then u have to do a little work around like writing the MS WORD Document to pdf format. If the PDF Writer is not installed with your copy of MSWORD then try any free pdf writer software available on the internet.
Aug 31, 2007 | Lexmark X7350 All-In-One InkJet Printer
HP Officejet Pro L7680 All-In-One Printer Logo
168 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
