Question about Denon DVD-2910 DVD Player
Dvd and cd's will not read on player - Denon DVD-2910 DVD Player
  • 1 more comment
  • ppamelz May 06, 2008
    the GPX D1816 dvd player will not play any dvd's i put in it.It always reads, " bad disc" Help!!! i baught the damn thing yesterday.
  • laisha_18us Nov 10, 2008
    it won't read my dvd/cd. it kept on saying no disk. I don't know what to do because my dvd player is only 3 months old
  • sabe101478 Nov 11, 2008
    Mine reads no disc. I 've not had this dvd player long. Should have never purchesed this!
    Problem Solver:
  • 6 Answers
Http://forum.videohelp.com/topic350059.html
Some Home dvd players may not have any adjustment abilities, but you would find such things not too far away from the lense, if they don't exist, get a new unit.
There are two tiny surface-mount potentiometers (could be capacitors also) sitting in the small circuit on laser assembly.
this is exactly response I would like to hear - an expert opinion!
What I did with help of 1mm-wide screwdriver:
1) There were two surface-mount potentiometers marked with C1 and D. I tried first D. Turned it clock- and counterclockwise by about 45 degrees.
2) After each turn I opened and closed tray to force the player read DVD disc.
3) It did not help, "NO DISC", then I tried the same with C1, and again, no luck.
4) Finally, I came back to D and turned it by about 180 degrees in one direction. IT WORKED!!!
Moreover, seem that now player reads content of the DVD discs faster then before. Probably manufacturer did not really adjust it properly and upon the time something has degraded, so it failed eventually.
Posted on Nov 27, 2008
The player will read dvd but will not play cd
Richard: This is what EHow.com said: "
  • Turn on the DVD player. It generally takes a few seconds to get going. Take out the DVD if there's one in the drive already.
  • 2 Make sure the disc isn't scratched or dirty. Use a soft rag to clean the disc if you see any smudges. Insert the CD into the DVD player's disc drive and close it.
  • 3 Press the "Play" button on the DVD player or remote control. Some DVD players will begin reading the disc automatically. Pushing the button works just as well.
  • 4 Use the "Scene Selection" buttons on your remote to select a track. Some DVD players have odd ways of ordering the buttons on the remote. You might have to play around a bit before you find all the right buttons to work the CD playing function of your machine.
  • 5 Crank it up and enjoy your music. The DVD player will act just like a CD player and play the tracks of the CD through the TV.
  • Read more : http://www.ehow.com/how_2036285_use-dvd-cd.html
    May 28, 2015 | Televison & Video
    It's not reading cd, or DVD
    Check for scratches on the disk surface - these can inhibit the player from reading a disk correctly.
    Some players will read olny certain type(s) of disks. This is an issue mostly for disks created on a computer, not those that are prerecorded and available for purchase or rental that contain movies and music.
    As stated above, dIsks created on a home computer may not always be readable on a home player. Re-writeable and recordable types that are not listed as being compatible will not work. Check your manual to see which types are acceptable and not. DVD types are: DVD-R, DVD-RW, DVD+R, DVD+RW and DVD-RAM CD Types are CD-R, CD+R and CR-RW. Older home CD and DVD players generally work with "-R" types and the newer players with both "-R" & "+R" types. "-RW" and "-RAM" types are the least likely to be readable in home players.
    Additionally, most players require that disks created on a home computer be "finalized". This is an extra step that isn't required by most CD / DVD drives in computers. Just because it works in your computer doesn't mean it will work in your home player. If you're using compatible media and still not able to read disks, check your CD / DVD recording software options to enable finalization.
    Jan 03, 2013 | Televison & Video
    Cds wont play in dvd-rw player
    The only discs that a DVD player is guaranteed to read are DVD discs. Support for CD-ROM, CD-R, and CD-RW may be included, but is by no means guaranteed.
    CD-R was designed to be read by an infrared 780nm laser. DVD uses a visible red 635nm or 650nm laser, which aren't reflected sufficiently by the organic dye polymers used in CD-R media. As a result, many DVD players can't read CD-R media. Some DVD players come with two lasers so that they can read CD-R.
    But as I have already stated that Most DVDs today have the tendency of playing CDs. So if your DVD player is new then it must have that support. Have a look at the quality of your CDs also.
    Oct 31, 2012 | HP Compaq Presario CQ60-249US Notebook
    Rotel dvd player not reading dvd but will read cd
    if it doesnt read any kind of dvd discs at all it only means you have been rip off. It happened to my sony dvd player that I bought from this website. I tested it and it only reads cd or audio cd. Good thing my couzin fixes electronics, He checked on the lens and it turned out that the lens has been replaced with an audio/cd lens like the one we use for our car stereo. Too bad!!!
    Jan 05, 2010 | Rotel RDV-1040 DVD Player
    My player wont read any CD at all, or DVDs
    This DVD player unfortunately does not support most of the Copied DVD /CDs.
    it works stemless with only genuine / original CD and DVDs..
    If your DVD or CD originallly recorded by manufacturers but still can not read ,
    than I recommend you to obtain and apply it to clean your laser eye of the DVD player.
    Hope it will solve your problem.
    Please remembr to vote me too..
    Regards
    Compatible disc formats: DVD, CD, CDR, CDRW, Video CD
    Sep 28, 2009 | Sony DVP-NS400D DVD Player
    In SONY CD/DVD Player, it is able to read CD where as DVD is not able to be read. Saying NO disc. What could be possible reason and remedy for the same.
    Some dvd have a multiple laser function for dvd and use a single laser for cd. common fault on not reading dvd is dirt on laser or fault on multiple laser that cannot read dvd. If cleaning doesnt help only repair tech can fix. Just check that the dvd is working in another dvd player to ensure it is not disk
    Aug 14, 2009 | Sony Televison & Video
    Cd/dvd cannot be read by the player
    EITHER CLEAN or replace THE OPTICAL LENS , try first to clean it directly with a DRY Q-tip ,and test player again. if it doesnt read , then replace the optical lens, hope this helps , AJ
    May 19, 2009 | Televison & Video
    The dvd player does not read every cd or dvd.
    No-disc errors are usually caused when the DVD or the laser-lens pickup has become dirty and causes the DVD player to not be able to read the DVD.
    http://www.ehow.com/how_2036277_fix-error-dvd.html
    Dec 26, 2008 | Toshiba SD-140E DVD Player
    DVD+RW make compatable with other dvd players
    Just like with CD players...not all Players will read the CD-RW format..but they will read the CD-R's. Check your manual to see if your DVD-Player is compatible with DVD+RW formats.
    Feb 27, 2008 | Televison & Video
    Denon DVD-2910 DVD Player Logo
    292 people viewed this question
    Top Denon Televison & Video Experts
    Jonathon summesfield
    Are you a Denon Televison and Video Expert? Answer questions, earn points and help others
