Question about LEGO interactive LEGO Creator Harry Potter for Windows
Function F2 does not load a second player - LEGO interactive LEGO Creator Harry Potter for Windows
Cf-30 disable touchscreen
On all Panasonic Toughbook Notebooks,
you must get into the BIOS by pressing
the F2 Function key when you turn on the
Toughbook as it is booting. Press F2 repeatedly.
This must be done in the 1-2 seconds before
Windows starts to load. Then you will see
Touchscreen usually on the 2nd page with the
word "Enable". Simply select enable and press
"Enter" and the choice between enable and disable
will appear. Then select "Disable" with the cursor
and then press Enter. Finally you need to
"Save and Exit" the changes in the BIOS.
That is it. Good Luck to you.
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989
Nov 13, 2012 | Panasonic Toughbook CF-30 Notebook
Wireless capability Switch is off on dell vostro 1400.Is there another way to turn on switch.
There are three ways to toggle the wireless switch on/off, 1st, Fn + wireless button (F2 or F5), 2nd, the wireless switch on the side of the laptop, 3rd, it can be enabled or disabled under BIOS setup (Tap F2 when turned on the laptop).
Jun 30, 2011 | Computers & Internet
The f2 doesnt work on dell inspiron9300
do you mean the keyboard F2 key does not work? Change keyboard and test? Otherwise, it may be a two function keyboard where you need to hit a special colour key to get the function keys working. This special key is usually off to the side and may have some graphic indicating toggel between the first and second level of definitions of that physical key. This is true if you see more than F2 on that key.
Jun 13, 2011 | Computers & Internet
Hello Technicians, The save files are not correctly saving. In a two player game, I play a barbarian and my brother plays a scout, we go to save the game and all is fine while we keep playing. However,...
check for scratches on the disc. the disc is probably scratched or cracked where the saving element is and you should get it repaired or get a new one. var fctb_tool=null; function FCTB_Init_e2212100dc3e4bfc9c4502928464ab5e(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_e2212100dc3e4bfc9c4502928464ab5e(document['FCTB_Init_071859b8f64249cd9a238510a1e5a9d6']); delete document['FCTB_Init_071859b8f64249cd9a238510a1e5a9d6'] var fctb_tool=null; function FCTB_Init_5f5351a7c9cc4b92b4af842812505d93(t) { fctb_tool=t; start(fctb_tool); } FCTB_Init_5f5351a7c9cc4b92b4af842812505d93(document['FCTB_Init_51915d6728d9418fb47ddb0ce4bf19b1']); delete document['FCTB_Init_51915d6728d9418fb47ddb0ce4bf19b1']
May 05, 2011 | Sony Untold Legends: Dark Kingdom
Plays only 2 seconds of each song
Press the emergency reset button located on the side of the player. You will need a small pin or paper-clip to insert into the tiny hole. When the button is pressed, the player will turn off. Don't panic - turn it back on and it should function normally.
Sep 17, 2009 | Audio Players & Recorders
Oven not working Message E0-F2- showing
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question&&&&
Apr 20, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Keyboard F1 to F12
F1 - F12 Function Key Usage
Printer Friendly Version
F1:Help. Click F1 Key can load the help file of the program.
F2:Rename. Select a folder or file, click F2 to rename it.
F3:Search. On desktop, click F3 to load the search form.
F4:In Internet Explorer, click F4 will list the URL Address field.
F5:Refresh. Use it to refresh the web page in Internet Explorer.
F6:In Internet Explorer, click F6 will jump to address bar.
F7:It can be used to insert ^C in command prompt.
F8:When windows startup, it can load the startup menu.
F9:In Windows Media Player, it can increase the volumn.
F10:In Windows Media Player, it can decrease the volumn.
F11:In Internet Explorer, click F11 will switch to Full Screen mode.
F12:In MS-Word, it will show out the "Save-As" dialog.
Take this link u will get all the Function Keys description
http://www.computerhope.com/issues/ch000306.htm
Aug 31, 2008 | Computers & Internet
Laptop wont boot
Press F2 and try to Load the default values and reboot.
May 20, 2008 | Acer Aspire 5100 Notebook
Function Keys Don't Work
Have you loaded compaq easy access button software?
LINK
Apr 25, 2008 | HP Compaq Evo Notebook N410c
Can not down load videos
Put your player in MSC USB mode, convert your videos in MTV format with the video converter, then drag and drop them in the MOVIE.DIR file of you player.
Jan 06, 2008 | Coby MP-C7085 MP3 Player
LEGO interactive LEGO Creator Harry Potter for Windows Logo
190 people viewed this question
Top LEGO interactive Video Game Consoles & Games Experts
James Wishart
Marvin
Marvin
Are you a LEGO interactive Video Game Console and Game Expert? Answer questions, earn points and help others
