I have model # RMR966PA clock,temp, and have lost the directions for setting the unit, can you help?
Noggin
  • 944 Answers
SOURCE: Clock
here is the link to the manual in english; http://techdocs.panasonic.co.uk/docs/1z46a4f025z3z24291z656ez706466z24z2def662d62b6933e74fc7f95e0899332503cee99/tsn2/data/EUOT/CQC1021NW/OI/769432/YFM284C454ZC_ENG.pdf Check page 1 - right in the top right corner under "Preparation" Hope this helps :)
Posted on Jul 23, 2007
SOURCE: Set Clock
This clock has 2 alarms to set Alarm 1, switch alarm 1 to the "set" position and make sure alarm 2 is pushed to the "off" "radio" or "cathedral" position, press and hold the "alarm" button on top while pressing the "f.fwd" or "rev" button to set the alarm....to set Alarm 2, do the opposite of the set buttons and repeat...to set the time just hold the time button down while pressing "f.fwd" or "rev"...hope that wasn't too confusing.
Posted on Jan 25, 2008
  • 11 Answers
SOURCE: how to set time
Most of the time when setting clock radios you have to press a combo of buttons in order to go through the settings. Many times you just need to press and hold the clock time button for a few seconds(normally between 3-6 seconds) and then the clock display will flash. When this happens you should be able to go through the hour and second numbers to set the time. After that you would probably need to hold the clock button again to stop the flashing to keep the setting you just did.
If this method does no work try a combo method by pressing the clock button and another button together for a few seconds to see if that works.
Posted on May 14, 2008
SOURCE: Have a radioshack atomic wall clock model #
1. Hold down WAVE/SET for about 2 seconds to enter the setting mode.
2. The time zone and DST (Daylight Savings Time) blink. Press + to select your time zone. Press - to turn DST On or Off. The default setings are PST and DST On.
3. Press WAVE/SET again to confirm the setting and enter the year setting mode.
4. The year digits blink. Press + or - to select the year.
5. Press WAVE/SET to confirm the year setting and enter date setting mode.
6. The date digits blink, press + or - to select the time.
7. Press WAVE/SET to confirm the date and enter time setting mode.
8. The time digits blink, press + or - to select the time.
9. Press WAVE/SET to confirm time setting and enter the clock and temperature setting.
10. The time format and temperature blink. Press + to select between 12Hr and 24Hr format. Press - to select between Celsius and Fahrenheit.
11. Press WAVE/SET to confirm whole setting.
SIGNAL: To aquire the signal for the first time, place the clock near a window facing Fort Collins, CO. If it fails, it will try again every 3 hours.
I hope this helps. I work for radioshack and i had a few extra minutes while at work.
Brett.
Posted on Apr 30, 2009
hmerchant110
  • 7191 Answers
SOURCE: I have lost the directions
For detailed instructions regarding setting the SkyScan 86722 atomic clock, click here:
http://skyscan.info/content/manuals/25-model-86722.html
On the page which opens, scroll down to view the complete instruction manual.
Hope this solves your problem. Thanks for using FixYa.
Posted on Mar 15, 2011
Where can I get a temp. transmitter
Depending on which model of clock/temperature display unit you have, you can purchase them directly from the manufacturer or a reseller like Amazon. Another option is to purchase another clock/temperature display unit which ships with a transmitter. That would double your displays and give you a useable transmitter which should work with both as long as the channel is set properly on all devices. Additional information is required for a more specific answer. Hope this helps!
Dec 02, 2014 | Home
How do i get the outside temp. to work
If you have a outside sensor add betteries.Wait for it to connect to the base. You may have to "reboot" ,remove batteries from base and outside temp sensor and replace both, Patiently WAIT I have a similar device and once a year I replace the batteries It takes a while for the devices to re-connect and set , the atomic clock as well. That said, How far is the Temp Sensor from the base unit? I set my outside sensor near the base to connect and move it on th outside porch (30' away) out of the direct sun and rain. I not sure if this is necessary but that the way I reset them.
Nov 04, 2012 | Sharp Spc315 Atomic Dual Alarm Clock
LG DVD Recorder- Clock settings Model RH277H
The clock settings will only be retained if you power down the unit via the On/Off button on the remote or on the unit i.e. put the unit into standby mode. If you switch off mains power the clock settings are lost as there is no backup battery in the unit. Power consumption on standby is negligible.
Dec 28, 2008 | LG RH299 DVD Recorder/VCR
Cant get the Unit to respond to the remote control
My remote won't work. It will work once, maybe twice and then no response from it. New batteries, haven't dropped it, etc.. HELP !!
Aug 19, 2008 | Audio Players & Recorders
LivingSolutions AM/FM alarm clock radio with ipod dock
You have to use the remote. You press alarm and then you select the time from there.
Jun 27, 2008 | Audio Players & Recorders
How to set time
http://www.emersonradio.com/owners Copy this web link and paste it into the address bar of your browser. The link will take you to the Emerson customer support clock Radio Owners manual directory. Here you can find you Type of radio and open the link and find you model. Open the model link and then you can follow the instruction given in the manual to set the clock. I hope this information helps you with your problem.
May 09, 2008 | Emerson Smartset Clock Radio
k24674
jasbo
jasbo
Marvin
Marvin
